Beringer Disc Brake Kit for Schemm-Hirth gliders - experience and effectiveness?
Old October 15th 17, 03:26 PM posted to rec.aviation.soaring
Dan Marotta
Default Beringer Disc Brake Kit for Schemm-Hirth gliders - experience andeffectiveness?
Is there a Cleveland wheel, disk, and caliper that would work? They're
used all over general aviation.Â* I don't know for sure about the wheels
and disks, but my Stemme uses Cleveland calipers.Â* I'll be replacing the
pads next week for under $50 for four pads.
On 10/14/2017 4:31 PM, wrote:
I have a Beringer wheel on a JS1 and it is a nice piece of kit and has worked and braked fine however, having had my eyes opened by helping a colleague to change the tyre on a colleague's Antares, I wouldn't get one again. If the tyre gets damaged and needs replaced you need to source the expensive 10 ply tubeless aviation tyre and need to have the tyre changing kit (plywood frames + metal spacer to compress the tyre) + lube + new O ring kit. I recently bought all that to take on an expedition to South Africa at total cost in UK over £350 and it took a few weeks to source separately. Without it if I burst a tyre I reckoned I would be stuck on the ground for a long time.
It's fine if you are aware of those aspects and have spares available or can wait to get them if a problem arises.
I would opt for a Tost Penta while which is lighter than standard Tost wheel system (but heavier than a Beringer) and has a hydraulic disc brake but takes normal tubed tyres.
Dan, 5J
Old October 15th 17, 03:34 PM posted to rec.aviation.soaring
Default Beringer Disc Brake Kit for Schemm-Hirth gliders - experience and effectiveness?
I have a Beringer wheel on a JS1 and it is a nice piece of kit and has worked and braked fine however, having had my eyes opened by helping a colleague to change the tyre on a colleague's Antares, I wouldn't get one again.. If the tyre gets damaged and needs replaced you need to source the expensive 10 ply tubeless aviation tyre and need to have the tyre changing kit (plywood frames + metal spacer to compress the tyre) + lube + new O ring kit.. I recently bought all that to take on an expedition to South Africa at total cost in UK over £350 and it took a few weeks to source separately.. Without it if I burst a tyre I reckoned I would be stuck on the ground for a long time.
Dan, 5J
Possibly, but someone has to engineer the conversion, produce and supply parts and do the required work to generate "approved data", commonly done by STC.
Much better to pay for someone else to do this work.
UH
Disc Brake Retrofit kit from Wings & Wheels -- LS7 installation Gianni Isotope Soaring 6 September 26th 17 11:56 AM
Disc Brake Modification Brian Iten Soaring 0 July 7th 04 04:51 AM
Simicon Disc UAV robert arndt Military Aviation 0 March 11th 04 07:19 AM
no disc 4 Hector Relva Simulators 2 October 1st 03 03:01 AM
no disc 4 Hector Relva Simulators 0 September 21st 03 11:26 AM
