I just bought the same extractor for my ASW-19 and am waiting to install it. Mine will require a small modification to the block of wood under the opening so the front edge lip will slide in.
Did you cut the vent holes in the aft bulkhead? Paul A. |
Pretty nifty looking bit of kit!Â* But I'd think you'd have to make a
cover to close off the ring bulkhead aft of the vent. On 10/16/2017 10:46 PM, Paul Agnew wrote: http://ljpanels.co.uk/test/index.php...traction-ducts FYI -- Dan, 5J |
I didn’t cut the holes, but mine has a fold down wood bulkhead with a pretty gap (about 1/2 inch) around the perimeter. That gap was large enough that I though I’d give it a try before cutting the holes. I was happy with the result, so I’ll probaby not cut the holes. The fiberglass bulkhead has a tighter fit, so you may ne d the holes.
John |
ASW19 for sale | [email protected] | Soaring | 2 | September 12th 16 10:07 PM |
ASW19 Inner Tube | [email protected] | Soaring | 1 | September 21st 15 03:54 PM |
Air extractor for sustainer and motor gliders? | [email protected] | Soaring | 12 | August 26th 15 07:41 AM |
Air Extractor: Better than a Plastic Jesus? | [email protected] | Soaring | 23 | December 18th 13 08:48 AM |
asw19 airbrake kit | steve[_2_] | Soaring | 2 | April 7th 11 08:32 PM |
