Is there a nose hook modification for a standard cirrus
Old October 18th 17, 02:01 AM posted to rec.aviation.soaring
Andreas Maurer
Default Is there a nose hook modification for a standard cirrus
On Tue, 17 Oct 2017 01:47:08 -0700 (PDT), wrote:
So, Andreas, do we conclude the the physics and maths of tow hook placements are wrong or that there is always someone who sometime can manage to do something especially stupid?
Well...
let me put it this way:
As you probably know, the test flights that proved that the nose-up
momentum of a CG hook have been made by a German Akaflieg (project
pilot was a friend of mine, btw). And of course these flight tests
(using a Ka-8) proved that using a CG hook indeed made a huge
difference.
But:
Based upon these flight tests Germany introduced a law that aerotows
on CG hooks were only allowed if the pilot had recent aerotow
experience (3 aerotows during the last 6 months), and of course new
gliders had to be equipped with a nose hook.
Many people assumed that these limitations would affect aerotow safety
in a positive way. But it turned out that there was no influence of
these new rules on aerotow safety, not was there ever a hard
statistical proof that gliders with a CG hook had a higher aerotow
incident rate than gliders with nose hook (the odd man out being some
notorious gliders with problematic geometry and CG hook, especially
the Ka-6).
So last year this law was removed.
My conclusion:
In theory and flight test the maths and physics are correct, but in
practics they are not related to incident numbers.
p.s.
I usually fly an open class double seater with only a CG hook, and my
club's ASK-21 and Duo Discus XL. When teaching upset aertow situations
in the ASK-21 I never noticed any useful stabilizing effect of the
nose hook, nor did Iever in the Duo Discus. The same goes for the
DG-300 with and without nose hook which I had many chances to compare.
Old October 18th 17, 04:39 PM posted to rec.aviation.soaring
Dan Marotta
The only real advantage I can see to a nose hook is to the ground
crewman who doesn't have to lay on his back to attach the rope. :-D
Well...
difference.
But:
the Ka-6).
My conclusion:
p.s.
Dan, 5J
Old October 23rd 17, 06:12 PM posted to rec.aviation.soaring
kirk.stant
Gliders with CG hooks are kinda like airplanes with tailwheels; if you know what you are doing they are no problem and can be more fun (i.e. need more skill) than nose hooks or nose wheels.
BUT
They both can setup situations that can rapidly escalate out of control. Crosswinds, unbalanced wings dropping, poor aileron control at low speed, tall grass - you have to be aware of the system dynamics and prepared to cope.
Now if we had CG hooks on towplanes..!
Kirk
66
Old October 24th 17, 01:08 AM posted to rec.aviation.soaring
Frank Whiteley
BUT
Kirk
66
I have seen a concept sketch for a specialty tow plane, automotive powered, large prop driven by a reduction drive, and cg tow tow hook and twin boom tail. Only a few hurdles to overcome, like FAR's (allow experimental to tow) and/or certification (difficult) and limited market. Break even point would be about 200 builds. It could equal or beat on of these as a tow plane
https://en.wikipedia.org/wiki/SIAI-Marchetti_SM.1019
Keep the CG hook and buy a winch is easier and cheaper.
Winter's coming;^)
Frank Whiteley
nose section from salvaged standard cirrus. Scott Williams Soaring 1 May 27th 17 04:58 PM
Jantar standard SZD-41A C.G. hook Žiga Munda Soaring 3 November 24th 15 02:00 AM
Standard Cirrus C-Hook Randy[_2_] Soaring 26 September 26th 08 10:24 PM
Hook up an mini headset to a Vertex Standard VX150 or 210 radio Peter Soaring 2 July 3rd 06 04:49 PM
Nose hook addition Jack Soaring 2 April 29th 06 08:08 AM
