I've read that the Discus b and Discus CS are "identical" except that the CS is manufactured under license in Czech Republic. Both are, of course, available in the used-glider-market. Are there any differences in reliability, manufacturing qualty, etc that would favor one over the other?
Tom |
As well as building the Discus the Czech SH factory builds other gliders for them - all Duos were being built there and then fitted out in Germany when we got one in 2001. Earlier I had a half share in a German built Discus BT that, after being broken by a partner, ended up with a new Czech wing and the older German one. The only difference was a slight difference in the spar stub GRP colour.
There was a major issue around 15 years ago when some Czech built wing spars were found to have inadequately bonded top caps and there was a big program of internal inspection and repairs if indicated. Assuming that any Discus CS from that era had the inspection done and recorded properly then I wouldn't have any other concern about relative original build quality of B and CS models. The CS was offered with some standard features that were optional on Bs - the main one being a tilting panel which is a very desirable. |
On Tuesday, October 31, 2017 at 6:48:54 PM UTC-7, wrote:
I've read that the Discus b and Discus CS are "identical" except that the CS is manufactured under license in Czech Republic. Both are, of course, available in the used-glider-market. Are there any differences in reliability, manufacturing qualty, etc that would favor one over the other? Tom Thanks jpg, very helpful. Tom |
For the last few years of production most of (all?) the Discus b gliders
were built in Czech republic anyway (S/N 551+). Our Discus bT has a German Fus and Czech wings. The Gelcoat on the wings is in far better condition than the fuselage Regards At 16:06 01 November 2017, wrote: On Tuesday, October 31, 2017 at 6:48:54 PM UTC-7, wrote: I've read that the Discus b and Discus CS are "identical" except that the= CS is manufactured under license in Czech Republic. Both are, of course, = available in the used-glider-market. Are there any differences in reliabil= ity, manufacturing qualty, etc that would favor one over the other? =20 Tom Thanks jpg, very helpful. Tom |
I've read that the Discus b and Discus CS are "identical" except that the CS is manufactured under license in Czech Republic. Both are, of course, available in the used-glider-market. Are there any differences in reliability, manufacturing qualty, etc that would favor one over the other? Tom I'm a little confused here - is the CS the same design as the earlier Discus, or later Discus 2? |
On Thursday, November 2, 2017 at 2:14:24 PM UTC-5, Jeff Morgan wrote:
I'm a little confused here - is the CS the same design as the earlier Discus, or later Discus 2? Early Discus, Jeff. The CS is different manufacture of the Discus B. |
On Tuesday, October 31, 2017 at 9:48:54 PM UTC-4, wrote:
I've read that the Discus b and Discus CS are "identical" except that the CS is manufactured under license in Czech Republic. Both are, of course, available in the used-glider-market. Are there any differences in reliability, manufacturing qualty, etc that would favor one over the other? Tom No meaningful difference except CS likely to be newer. But the best example you can find of either one. UH |
Discus 2b versus LS-6c | [email protected] | Soaring | 14 | September 20th 17 01:31 PM |
304 versus Discus B | Del Jensen | Soaring | 7 | March 2nd 17 01:19 AM |
Discus verus Discus 2, LS8, ASW 28 | Roger | Soaring | 45 | October 31st 06 03:43 PM |
Discus CS and Duo Discus Wing Inspections | Nolaminar | Soaring | 0 | October 24th 03 01:15 AM |
[LBA] Schempp-Hirth - Discus bT - Discus | Frederic FUCHS | Soaring | 0 | September 17th 03 08:42 AM |
