Discus b versus Discus CS
Old November 1st 17, 08:54 AM posted to rec.aviation.soaring
Default Discus b versus Discus CS
As well as building the Discus the Czech SH factory builds other gliders for them - all Duos were being built there and then fitted out in Germany when we got one in 2001. Earlier I had a half share in a German built Discus BT that, after being broken by a partner, ended up with a new Czech wing and the older German one. The only difference was a slight difference in the spar stub GRP colour.
There was a major issue around 15 years ago when some Czech built wing spars were found to have inadequately bonded top caps and there was a big program of internal inspection and repairs if indicated. Assuming that any Discus CS from that era had the inspection done and recorded properly then I wouldn't have any other concern about relative original build quality of B and CS models.
The CS was offered with some standard features that were optional on Bs - the main one being a tilting panel which is a very desirable.
Discus 2b versus LS-6c [email protected] Soaring 14 September 20th 17 01:31 PM
304 versus Discus B Del Jensen Soaring 7 March 2nd 17 01:19 AM
Discus verus Discus 2, LS8, ASW 28 Roger Soaring 45 October 31st 06 03:43 PM
Discus CS and Duo Discus Wing Inspections Nolaminar Soaring 0 October 24th 03 01:15 AM
[LBA] Schempp-Hirth - Discus bT - Discus Frederic FUCHS Soaring 0 September 17th 03 08:42 AM
