I am surprised that in all the replies nobody has mentioned the
phrase that I kept being told when I returned to gliding after a long break - “We don’t do it that way any more”. Pre-takeoff checks, CBSIFTCB. No, it is now CBSIFTCBE. Raise my index finger and call “take up slack”. No, not any more. Religiously comply with the maximum winch launch speed at all times. Not any more. Now extra speed is accepted/preferred during the initial part of the launch. 15 knots above the placard speed is not a problem. Once the glider is established in the climb, keep pulling the stick back to maintain 50 knots or 48 knots if you are really trying for maximum height. No, we DEFINITELY do not do that any more. Flying the circuit, turn 90 degrees from downwind to base leg. No, now it is two 45 degree turns. All gliders were moved by hand, now they are towed. Gliders were landed back at the launch point, aiming for two or three wingspans from any glider waiting for a launch. Launches were not delayed by gliders overruning the launch point. To achieve a fast launch rate, the strop / weak link was not changed between launches - K21, K13 and Ka8 were all launched using the same weak link. We DEFINITELY do not do that any more. A downwind landing was frowned upon. Now it is an acceptable option following a failed launch or other contingency. What other changes to procedures have returning pilots noticed? |
On Sun, 19 Nov 2017 19:23:27 +0100, John wrote:
Dunflyin wrote: I am surprised that in all the replies nobody has mentioned the phrase that I kept being told when I returned to gliding after a long break - âWe donât do it that way any moreâ?. Pre-takeoff checks, CBSIFTCB. No, it is now CBSIFTCBE. Raise my index finger and call âtake up slackâ?. No, not any more. Religiously comply with the maximum winch launch speed at all times. Not any more. Now extra speed is accepted/preferred during the initial part of the launch. 15 knots above the placard speed is not a problem. Once the glider is established in the climb, keep pulling the stick back to maintain 50 knots or 48 knots if you are really trying for maximum height. No, we DEFINITELY do not do that any more. Flying the circuit, turn 90 degrees from downwind to base leg. No, now it is two 45 degree turns. All gliders were moved by hand, now they are towed. Gliders were landed back at the launch point, aiming for two or three wingspans from any glider waiting for a launch. Launches were not delayed by gliders overruning the launch point. To achieve a fast launch rate, the strop / weak link was not changed between launches - K21, K13 and Ka8 were all launched using the same weak link. We DEFINITELY do not do that any more. A downwind landing was frowned upon. Now it is an acceptable option following a failed launch or other contingency. What other changes to procedures have returning pilots noticed? It costs more. Gliders have a lot of electronic kit. Your airfield is under pressure from from "developers" who want to turn it into a housing estate or a "retail opportunity". Your club has a Child Protection Officer. Some of the private gliders have jet engines while others have two-bladed folding props on each side of their nose. The flying list at the launch point has been replaced by a booking system. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
"Pilots" now want cell phone mounts and cup holders.
On 11/19/2017 11:50 AM, Martin Gregorie wrote: On Sun, 19 Nov 2017 19:23:27 +0100, John wrote: Dunflyin wrote: I am surprised that in all the replies nobody has mentioned the phrase that I kept being told when I returned to gliding after a long break - âWe donât do it that way any moreâ?. Pre-takeoff checks, CBSIFTCB. No, it is now CBSIFTCBE. Raise my index finger and call âtake up slackâ?. No, not any more. Religiously comply with the maximum winch launch speed at all times. Not any more. Now extra speed is accepted/preferred during the initial part of the launch. 15 knots above the placard speed is not a problem. Once the glider is established in the climb, keep pulling the stick back to maintain 50 knots or 48 knots if you are really trying for maximum height. No, we DEFINITELY do not do that any more. Flying the circuit, turn 90 degrees from downwind to base leg. No, now it is two 45 degree turns. All gliders were moved by hand, now they are towed. Gliders were landed back at the launch point, aiming for two or three wingspans from any glider waiting for a launch. Launches were not delayed by gliders overruning the launch point. To achieve a fast launch rate, the strop / weak link was not changed between launches - K21, K13 and Ka8 were all launched using the same weak link. We DEFINITELY do not do that any more. A downwind landing was frowned upon. Now it is an acceptable option following a failed launch or other contingency. What other changes to procedures have returning pilots noticed? It costs more. Gliders have a lot of electronic kit. Your airfield is under pressure from from "developers" who want to turn it into a housing estate or a "retail opportunity". Your club has a Child Protection Officer. Some of the private gliders have jet engines while others have two-bladed folding props on each side of their nose. The flying list at the launch point has been replaced by a booking system. -- Dan, 5J |
So....some want an "athletic supporter"?
Never mind...... Maybe they don't like how teams are selected...... Never mind......different thread.......errrrr....threads.......Wilbur.....or ......errrrr....never Frikkin mind. Ignore this post......ugh..... Sigh.....is it Monday yet? |
Women soaring pilots - need some advice | [email protected] | Soaring | 5 | October 1st 15 03:28 AM |
German friend ask for advice about soaring in the US this summer | Terry Pitts | Soaring | 12 | December 6th 12 09:34 PM |
returning to flying after 29 years | Qzectb | Piloting | 22 | May 1st 08 01:14 AM |
50 years of space (Not related to soaring) | Bill Daniels | Soaring | 3 | August 10th 07 11:20 PM |
Soaring advice | Marc | Soaring | 3 | June 18th 04 11:26 AM |
