CG Trimming after Tail Boom Repair
Old November 23rd 17, 07:20 PM posted to rec.aviation.soaring
Default CG Trimming after Tail Boom Repair
A new weight and balance, after a tail boom repair, shows that several tens of pounds of trim weight needs to be added to a forward location in order to move the CG back into acceptable range. This fixes CG issue, but are there other concerns with doing this? Would be interested in experience of others.
Tom A
Old November 23rd 17, 07:28 PM posted to rec.aviation.soaring
Tim Taylor
Tom A
Please specify the glider type. We assume you mean that the c.g. needs to be moved forward into the correct range.
Some gliders have ballast weights that can be placed in the nose or near the front bulkheads, others will have lead epoxied into the nose.
Old November 23rd 17, 07:42 PM posted to rec.aviation.soaring
[email protected][_1_]
You should investigate the potential of some ballast hidden somewhere in the tail. Or perhaps your CG calc's and/or measurements. A boom repair should not require that much ballast in the nose to get the empty airframe in CG range.
Old November 24th 17, 02:32 PM posted to rec.aviation.soaring
AS
I have seen boom repairs just short of having 2x4s inside, so if it is one of those, that much lead in the nose may be indeed required.
Uli
'AS'
Old November 25th 17, 03:24 PM posted to rec.aviation.soaring
Dan Marotta
Uli
'AS'
You mean like this?
https://www.dropbox.com/s/gy3qkujmyy...26.49.jpg?dl=0
Old November 25th 17, 05:29 PM posted to rec.aviation.soaring
AS
Uli
'AS'
You mean like this?
Yep - pretty much like that. Still, my vote for the top price for the most terrible repair would go to a Ka6e with a Bondo'ed on cuff over one side of the all-flying elevator after an off-field landing mishap. I wonder how much lead in the nose that one required - provided a W&B was even done after that 'repair'.
Uli
'AS'
Old November 25th 17, 03:19 PM posted to rec.aviation.soaring
Dan Marotta
You mean like this?
Uli
'AS'
Dan, 5J
Old November 23rd 17, 09:02 PM posted to rec.aviation.soaring
Mike C
Tom A
Other than the max allowable weight of non lifting parts there should not be any other issues if the repair was solid. Added weight in a tail boom repair (long tail moment) takes several times the added weight when added to the shorter nose moment. Having to add so much weight forward of the cg though shows that a sloppy and probably excessive repair was made.
Mike
Old November 25th 17, 01:04 AM posted to rec.aviation.soaring
Dan Marotta
I think I see the problem...
Tom A
Mike
Dan, 5J
Old November 26th 17, 01:53 AM posted to rec.aviation.soaring
My memory is a little hazy but I recall seeing Rudy Alleman's 301 Libelle at the 1981 15M nats in Minden with glassed on external longerons. I could have my facts wrong but apparently the tail boom had been broken a few times and he decided he didn't want to go thru that again.
Chip Bearden
tail boom repair CTEX Soaring 9 December 22nd 12 02:29 PM
shuttle landing BOOM BOOM muff528 Piloting 0 March 27th 08 12:38 AM
Window trimming techniques Jim Burns Owning 7 August 18th 05 06:35 AM
spinner trimming technique Dick Home Built 0 January 25th 05 11:57 PM
Trimming down Task Manager in XP for best PC performance... John Hellingsworth Simulators 3 September 20th 04 02:31 AM
