Glider cockpit size
Old November 25th 17, 09:22 AM posted to rec.aviation.soaring
Craig Lowrie
Default Glider cockpit size
Try an HPH Shark... It probably has the most roomy cockpit out there...
6'4" will fit ok... Craig
At 04:03 25 November 2017, Michael Opitz wrote:
At 03:26 25 November 2017, Steve Muhli wrote:
Hi, New to this forum, thought I 'd pose a question..... I have a
glide
rating
from years ago, I was wondering if anyone can suggest a list of
glider
that
are more "roomy" inside since I am 6'4" . I am planning on going
to th
SSA
convention in Reno in 2018 to check out the new stuff....I've sat in
an SZ
55, that's about it.... Thanks
Discus-2b and Ventus-2b should be comfortable up to ~6'5" with
a normal chute. Genesis is also roomy, but not many around or for
sale. A lot depends on your wallet, experience level, and what you
are trying to accomplish. Most of the older gliders were not built
with a 6'4" pilot in mind. The Discus-2b and Ventus-2b fuselages
were the first where Schempp-Hirth said that they wanted to design
a cockpit which almost anyone could get into comfortably. Other
manufacturers have gradually over time enlarged the insides of
their cockpits in order for taller people to fit as well.
Most glider seat belt attachment fittings are the limiting factors
for weight in the seat. For most, the max weight is 242 Lbs or
110 Kg.
You will probably get a bunch of other suggestions from this forum.
Good luck...
RO
Dg600 cockpit size [email protected] Soaring 2 September 21st 16 11:09 PM
Discus 2a cockpit size EdByars Soaring 1 March 18th 10 03:37 AM
Discus 2a cockpit size Stephen[_3_] Soaring 7 March 17th 10 05:57 PM
Cockpit size of Libelle? Kevin Morris Soaring 4 July 15th 04 11:32 PM
