Std. 2 Jantar - CG Tost hook?
Old November 26th 17, 03:00 AM posted to rec.aviation.soaring
Frank Whiteley
Default Std. 2 Jantar - CG Tost hook?
On Saturday, November 25, 2017 at 6:03:44 PM UTC-7, wrote:
The manual mentions that a CG hook can be mounted on the landing gear. Does anyone have instructions from the factory on that process?
Thanks
Phil
Can't comment on that approach. I had a share of a Jantar Std 2 in the UK several years ago. It would back release at about 700agl during a winch launch. The BGA senior inspector rotated the hook 2-3 holes. After that it went to the top of the launch.
Frank Whiteley
Old November 26th 17, 04:06 AM posted to rec.aviation.soaring
That’s an interesting approach to the problem. I mounted a Tost hook on the landing gear of my HP18 and that worked great. Since this is a certified aircraft I’ll have to check with our AME. I anticipate that the factory will have the mounting info given it was an option. Thanks for input.
Phil
Looking to buy Tost hook [email protected] Soaring 2 March 4th 17 01:02 PM
Tost tow hook STC for C-182 ? [email protected] Soaring 6 September 27th 16 01:13 AM
Jantar standard SZD-41A C.G. hook Žiga Munda Soaring 3 November 24th 15 02:00 AM
Cessna 185 with a Tost hook? Nimbob Soaring 1 September 29th 09 12:43 PM
Tost hook on Cessns 180 Paul Soaring 6 October 18th 04 10:32 PM
