On Wednesday, November 29, 2017 at 6:19:27 PM UTC-8, Craig Funston wrote:
They're incredibly simple to pick. In a pinch it can be done with a bent paperclip and a small blade type screwdriver. Use the screwdriver to put a light amount of torsion in the unlock direction and then take the lock pick (bent wire) and run it along the tumblers, pushing them away from the centerline of the lock. The tension will keep them from slipping back into place. 15 seconds work if you're experienced. I'm sure there's a YouTube that shows all the gory details Craig 7Q https://www.youtube.com/watch?v=cjuT_63Ioig |
used trailers | [email protected] | Soaring | 9 | July 29th 17 06:11 AM |
open trailers | [email protected] | Soaring | 1 | December 5th 06 04:41 PM |
F/S: Pik-20 and PW-5 trailers | DB | Soaring | 0 | August 9th 05 02:44 PM |
Trailers | Don Johnstone | Soaring | 2 | July 13th 05 09:30 PM |
Pic trailers | culverflyer | Soaring | 1 | May 5th 04 01:37 AM |
