Arcus vs
Old December 19th 17, 09:45 PM posted to rec.aviation.soaring
Dave Walsh
Default Arcus vs
At 20:30 19 December 2017, wrote:
Hi,
How does Arcus compare (any and all aspects) to other
modern two seaters?
Does anyone have any experience with Arcus EL?
Very, very few electric Arcus were ever built. I know of one
that was crashed in the French Alps, it was spun-in, so that's
one less.
You may wait a long time for first hand information on the
Arcus E. However lots of generally good things are said about
the Arcus, Arcus T and Arcus M: there are lots of them at
Sisteron in the summer. The two stroke self launch Arcus M
and the Arcus E both have much higher wing loadings, opinion
on whether this is a real problem depends on who you ask.
Lots of information out there on the Lange Antares 20E/23E
electric propulsion system, this is pretty much the same as the
system in the Arcus E. In climb you've probably got 11 -13
minutes total engine run time so if you use 6 minutes climbing
out you've got 6 minutes of run time left; this is NOT going to
get you back from the far end of a failed 500K. This is probably
a significant factor for many buyers? On the plus side you have
a reliable electric motor not a complex smelly petrol engine.
I'd guess Dave Nadler would be your best source of
information.
Dave Walsh
Old December 19th 17, 10:16 PM posted to rec.aviation.soaring
Default Arcus vs
So it looks like ASG-32 is the only electric powered two seater made nowadays?
Should make any decisions easy if electric engine is the base factor
S
Old December 19th 17, 10:47 PM posted to rec.aviation.soaring
Dave Nadler
Default Arcus vs
IIRC only 3.
...one was crashed in the French Alps...
wing-tip into a rock-face, bad way to go...
Arcus E.
There's one rented in Africa; google by whom and contact
them for information. They'll sell it to you ;-)
Yup!
ArcusM handles the weight just fine; not a big problem
even in pretty weak weather.
information.
Bummer.
First flight of Jet Arcus [email protected] Soaring 7 September 30th 16 02:38 AM
Arcus owners not monitoring the Arcus newsgroup... Dave Nadler Soaring 14 August 30th 16 05:54 PM
Hybrid Arcus [email protected] Soaring 13 April 2nd 15 06:34 AM
FS: Arcus T [email protected] Soaring 0 February 22nd 13 10:50 PM
Arcus - first impressions Andreas Maurer Soaring 1 July 7th 09 01:35 PM
