As a flight instructor with several young female students (Yeah! Some more women in soaring maybe!) I'd be a lot more interested in hearing any women pilots address this, because I think the problem for guys is simpler and better understood.
I fly a Discus B, and my solution for it is really simple: I carry an empty plastic Snapple ice-tea bottle, with cap. There's room between the control stick and me, angles work OK. This doesn't work for me in every glider -- in particular it sure doesn't work in a friend's DG-101 with the parallel stick mechanism that leaves no room to my crotch. I don't often get close to its usable capacity (which is about half the bottle volume) but the solution for that is either the foresight to carry a second bottle, or with some caution I have learned how to put it out the side vent and get enough fore-arm out so that I can stick the bottle far enough down so that the urine will go cleanly underneath the wing -- I acknowledge that this maneuver is tricky, and needs some practice (perhaps with clean water) before it is reliable, and may not work for everybody in every glider. If you want to try this maneuver here's the method: 1. speed up to about 60 - 70 . (Slower than this is likely to have urine hitting the wing ... faster may generate enough turbulence in the bottle to extract droplets before you want to.) I need to release my left shoulder strap to proceed: 2. stick the bottle out through the vent-window open mouth first and angled well forward and up about 60 degrees. 3. Lean so you can get your elbow close to the vent -- that you can do this is easy to test on the ground; if you can't do this, this dump technique won't work cleanly for you. 4. move your hand down as far as you can (so the urine will go under the wing), twist your wrist to point the mouth outboard and then down -- voila .... it's gone. If the speed and technique are right nothing comes out until you want it to, and it doesn't hit you or the wing. |
On Thursday, December 21, 2017 at 7:01:55 PM UTC+3, wrote:
As a flight instructor with several young female students (Yeah! Some more women in soaring maybe!) I'd be a lot more interested in hearing any women pilots address this, because I think the problem for guys is simpler and better understood. There are any number of devices on the market for female athletes, hikers etc etc https://menstrualcupreviews.net/best...nnels-reviews/ I don't know how hard it is to get a good seal. I fly a Discus B, and my solution for it is really simple: I carry an empty plastic Snapple ice-tea bottle, with cap. There's room between the control stick and me, angles work OK. This doesn't work for me in every glider -- in particular it sure doesn't work in a friend's DG-101 with the parallel stick mechanism that leaves no room to my crotch. Whether this works is also heavily dependent on whether you're a "grow-er" or a "show-er". We grow-ers have a more difficult job, assuming we're not all that excited at the time. |
My solution: External catheter. Use a little bit of talcum powder on the .... sensitive area.. first, so it comes off more easily. Connect to last year's camelback bladder, which goes down near your legs. This has two liters of capacity, way more than hospital urine bags. It's hands off, it's simple, no littering the countryside or bags caught on the leading edge, no pee - rust damage on the glider.
John Cochrane |
On Thursday, December 21, 2017 at 10:35:13 AM UTC-6, John Cochrane wrote:
My solution: External catheter. Use a little bit of talcum powder on the .... sensitive area.. first, so it comes off more easily. Connect to last year's camelback bladder, which goes down near your legs. This has two liters of capacity, way more than hospital urine bags. It's hands off, it's simple, no littering the countryside or bags caught on the leading edge, no pee - rust damage on the glider. John Cochrane Pee'd into uninary leg bags for a long time, now over-board line ending at the edge of a gear door (you see me lowering my gear, better run). Had to empty a very full cold leg bag through the window at Parowan at altitude once. The pee froze immediately against the outside of the canopy, not pretty. Herb |
On Thursday, December 21, 2017 at 12:45:42 PM UTC-5, wrote:
On Thursday, December 21, 2017 at 10:35:13 AM UTC-6, John Cochrane wrote: My solution: External catheter. Use a little bit of talcum powder on the ... sensitive area.. first, so it comes off more easily. Connect to last year's camelback bladder, which goes down near your legs. This has two liters of capacity, way more than hospital urine bags. It's hands off, it's simple, no littering the countryside or bags caught on the leading edge, no pee - rust damage on the glider. John Cochrane Pee'd into uninary leg bags for a long time, now over-board line ending at the edge of a gear door (you see me lowering my gear, better run). Had to empty a very full cold leg bag through the window at Parowan at altitude once. The pee froze immediately against the outside of the canopy, not pretty. Herb Location of the dump point at the aft end of the gear door seems like it should work well. It has 3 important shortcomings. 1- Urine does get into the landing gear box and rudder hinge area with this method. Anybody who has worked on gliders much has seen rusted landing gear parts as a result of this. I had to cut the rudder horn fairing off one glider to get at the lower hinge bolt due to rust. 2- Freezing. The long length and path can lead to freezing, especially at low points. 3- Cleaning. It is hard to clean out well. The probe out the belly solution avoids these issues. Another opinion. UH |
On Thursday, December 21, 2017 at 11:12:56 AM UTC-5, Bruce Hoult wrote:
On Thursday, December 21, 2017 at 7:01:55 PM UTC+3, wrote: As a flight instructor with several young female students (Yeah! Some more women in soaring maybe!) I'd be a lot more interested in hearing any women pilots address this, because I think the problem for guys is simpler and better understood. There are any number of devices on the market for female athletes, hikers etc etc Williams Soaring has a system on their website at https://www.williamssoaring.com/cata...-supplies.html ; about a third of the way down the page - 'female relief systems'. |
IGC Flight Recorders using Flarm firmware - New DLL file forvalidating IGC flight data files | Ian Strachan | Soaring | 0 | July 20th 14 07:28 PM |
New 18m Class ship - First Flight - The JS1 starts proving flight phase | [email protected] | Soaring | 2 | December 14th 06 02:06 AM |
NEW FLIGHT SCHOOL - Best in Flight Aviation Academy - Morristown,New Jersey | Dave Vioreanu | Piloting | 0 | April 22nd 05 02:55 AM |
NEW FLIGHT SCHOOL - Best in Flight Aviation Academy - Morristown, New Jersey | Guy Elden Jr | Piloting | 0 | April 21st 05 04:37 PM |
Does anybody know a link to a real picture of the X-43 in flight sans Pegasus or better yet a video clip of the flight? | Scott Ferrin | Military Aviation | 0 | April 3rd 04 08:47 PM |
