I still use quart sized zip lock baggies. If you catch the urge early enough, there is time to pee and NOT fill the bag. Long flights, most of us should pee a few times, more if it gets cold (read up on cold weather dehydration......).
Part clue is, zip the used bag about 90% closed, thus it empties on the way down. Don't need close to a quart of liquid at terminal velocity hitting the ground or anything else. I like to try and "go" when up on a street, trim to about 60MPH, then hands off the stick while "taking care of business". If I'm doing a ridge run, pee before getting on tree tops, maybe during a gap jump when it's smoother. I remember a "well known" pilot saying he used to put a finished apple core in the baggies before filling......sorta interesting. If I get back to more flying long flights, I shall look at an external catheter, most comp ships I fly have a system in place for that. Note, if you keep bags in the ship, "air test" them for leaks before filling. Stuff in the little side pockets can wear/punch a hole in the bag. Sucks to find a leaking bag due to liquid leaks...... A small hand towel is also nice to clean any spills. Women pilots....sheesh, adult diapers are likely the easiest because of their "plumbing" and most glass seating positions. |
![]() A small hand towel is also nice to clean any spills. Women pilots....sheesh, adult diapers are likely the easiest because of their "plumbing" and most glass seating positions. Right. But that isn't the whole story. I always laughed when relief continued to be mentioned "every" weekend over almost 20 years. Dealing with new students and new owners, all the options were discussed. Repetitively. I always started by saying - it must be addressed if you want to be a more than 2 hours aloft pilot, cross-country or not. As a physiologic issue, it becomes a safety issue if 'ignored'. On one of my early planned max-flight time straight outs, I proved that TWO diaper layers were not enough. I was happy to have a change of lower halfs on board. Since my landing was on an airfield seven and a half hours later, it was simple to clean up in the restroom and use fresh clothes. I had tried the Willliams option of a soft funnel to an external bag and could not make it comfortable in a singleseater. Others might find it okay, depending on cockpit layout (trim location handles, stick boots, seat pan depth), chute straps and belts, and torso lengths. Finally, when I began doing some long-duration wave flights (23 hours airborne in 36 hours), I found that self catheterization to a leg bag pair of 4 liters capacity was the right combination. I entered the cockpit with hose and shutoff down the interior of my pantsleg. Hookup to bags happened before seatbelts on and cockpit closed. For flights at multi-hours in Flight levels... the bags often froze, but not the leg lines. Towel for disconnect kept the glider clean. Considering the additional inconvenience of having to have prescriptions for the equipment, per-flight expense,the discomfort, the potential for infection/etc. - I don't have much sympathy for worries of trimming hair, adhesive removal or failure of glue joints. You folks with hoses have it significantly easier. If a gal wants to talk with me about it all, send her to me. Cindy B |
Thank you from a female perspective. I only know a few females that do longer flights, Doris Grove, my mother and a few female juniors from HHSC and Valley Soaring, I know there are others, I just don't know them. I never really had good options for any of them, the "adult diapers" was my only suggestion, sorta based on the glider. Sitting sorta upright can be a challenge (2-33 or 1-26), glass can be a real PITA, even for guys.
Lots of complicates solutions... I just use biodegradeble bags, one inside another, and toss them out of the window. No problems since 20+ years, even while flying a ridge.
On 23/12/2017 05:12, Charlie M. (UH & 002 owner/pilot) wrote:
Thank you from a female perspective. I only know a few females that do longer flights, Doris Grove, my mother and a few female juniors from HHSC and Valley Soaring, I know there are others, I just don't know them. I never really had good options for any of them, the "adult diapers" was my only suggestion, sorta based on the glider. Sitting sorta upright can be a challenge (2-33 or 1-26), glass can be a real PITA, even for guys. The deluxe all-singing-and-several-thousand-dollars-dancing variety has been produced for the US military (your taxes at work) and is called AMXD - Advanced Mission Extender Device. http://www.omnimedicalsys.com/index.php?page=products -- GC |
On Saturday, December 23, 2017 at 11:49:07 PM UTC-8, wrote:
On 23/12/2017 05:12, Charlie M. (UH & 002 owner/pilot) wrote: Thank you from a female perspective. I only know a few females that do longer flights, Doris Grove, my mother and a few female juniors from HHSC and Valley Soaring, I know there are others, I just don't know them. I never really had good options for any of them, the "adult diapers" was my only suggestion, sorta based on the glider. Sitting sorta upright can be a challenge (2-33 or 1-26), glass can be a real PITA, even for guys. The deluxe all-singing-and-several-thousand-dollars-dancing variety has been produced for the US military (your taxes at work) and is called AMXD - Advanced Mission Extender Device. http://www.omnimedicalsys.com/index.php?page=products -- GC One-stop shopping for all your hydration and relief needs! Probably cheap, since we already paid for it. Jim |
In my Duo I drilled hole into seat at critical point and straight down through the Hull as well. Installed guide tube about 2cm ID,glassed to the inside of the Hull ending up at Seat level with loose wind closing flap on outside of Hull. Used a small teflon coated aluminium Tube about 50-60cm long to push through the guiding Tube. At the business end of the alu tube,connected piece flexible tube with a quick one way walve connection to the Condom. Also put a stopper (lid) on the guiding tube when not in use.
1. No contamination on glider as evacuation is quite some way away from Hull i.e. 40cm 2. No chance of freezing as tube is kept in the glider 3. Suction is so great that every last drop is removed from Tube ie. no mess 4. Use the Tube only when required, ie do not leave permanently in during flight. However a word of advice when using this System, the Condom should not be fitted to close to the Tip if you are not circumcised as the Suction could pull your Foreskin and block the outlet on the Condom. |
I started with a short section of thin walled plastic tube. Probably 5/8 inside diameter or pretty close to that. Drilled a hole large enough to fit the tube in the glider belly, just behind the stick. Drilled the same side hole in a small wood block, maybe 2x2x1. Push the tube through the hole in the wood block and out the belly, and glue the wood block to the floor (below the seat pan). Drill a hole in the seat pan, and trim the tube so that’s it’s flush with the outside of the glider and maybe 1/4 above the seat pan. Now you have a a sturdy channel to route your “pee tube” through. Make sure your “pee tube”is long enough to extend below the glider about 6 or 8 inches. If you don’t extend the far enough below the glider everything you send out will find its way back in via the wheel well, even with the doors closed.
On 23/12/2017 05:12, Charlie M. (UH & 002 owner/pilot) wrote: Thank you from a female perspective. The deluxe all-singing-and-several-thousand-dollars-dancing variety has been produced for the US military (your taxes at work) and is called AMXD - Advanced Mission Extender Device. http://www.omnimedicalsys.com/index.php?page=products -- GC Thank you GC for the real data.... I had to contact Omni Medical and find out more. This thing should whistle Dixie, Battle Hymn of the Republic or your downloadable choice - Rain by Beatles? Have You Ever Seen the Rain Fogarty? Maybe Enya - Water Voices. CSK-2-F-1 or 2 –Female Control Starter Kit Contains: Female Control Unit, 2-Rechargeable Battery Packs, Charger, Power Adaptor, Training Video, User’s Manual 1 Removable Hose RHA-21B-2-F 2- Drainable Collection Bags 1200mL CCU-10-RU-12 3- IFP-16-2-2 Female Pads 2-FG Female Undergarments and 16 oz Bottle of cleaner (H2O2 3%) Quote good for 30 days and includes shipping = $2975 USD. (sharp inhale) They were extremely quick in answering my email. I know the male version has been used in gliders. Probably the nicest thing I can say about it is that the container is not transparent. They probably tested it enough to be assured it functions well(for the F-35. etc.). The thing that concerns me the most? Another set of batteries to charge, or get cold and fail. And there's something creepy about electrical contacts that close to me. Probably less creepy for you fellows, again. Their literature suggests that with good hygiene and peroxide, you can expect to get about five flights or fifteen days from the pads. That backs out to $100 per Aaaaahhhh, at 15 uses. This thread just won't wilt. Happy New Year, Cindy B |
I know the Air Force used to use "Piddle packs" with a gel fill. Then they lost an F-16 when a pilot stepped on a rudder to get more extension from the pilot side relief unit. Result: Pilot ejected from out of control aircraft. No mention of any possible flail injuries.
Perhaps this over engineered and expensive system is a result of the "piddle pack" mishap. On Thursday, December 28, 2017 at 12:25:56 PM UTC-8, CindyB wrote: On Saturday, December 23, 2017 at 11:49:07 PM UTC-8, wrote: On 23/12/2017 05:12, Charlie M. (UH & 002 owner/pilot) wrote: Thank you from a female perspective. The deluxe all-singing-and-several-thousand-dollars-dancing variety has been produced for the US military (your taxes at work) and is called AMXD - Advanced Mission Extender Device. http://www.omnimedicalsys.com/index.php?page=products -- GC Thank you GC for the real data.... I had to contact Omni Medical and find out more. This thing should whistle Dixie, Battle Hymn of the Republic or your downloadable choice - Rain by Beatles? Have You Ever Seen the Rain Fogarty? Maybe Enya - Water Voices. CSK-2-F-1 or 2 –Female Control Starter Kit Contains: Female Control Unit, 2-Rechargeable Battery Packs, Charger, Power Adaptor, Training Video, User’s Manual 1 Removable Hose RHA-21B-2-F 2- Drainable Collection Bags 1200mL CCU-10-RU-12 3- IFP-16-2-2 Female Pads 2-FG Female Undergarments and 16 oz Bottle of cleaner (H2O2 3%) Quote good for 30 days and includes shipping = $2975 USD. (sharp inhale) They were extremely quick in answering my email. I know the male version has been used in gliders. Probably the nicest thing I can say about it is that the container is not transparent. They probably tested it enough to be assured it functions well(for the F-35. etc.). The thing that concerns me the most? Another set of batteries to charge, or get cold and fail. And there's something creepy about electrical contacts that close to me. Probably less creepy for you fellows, again. Their literature suggests that with good hygiene and peroxide, you can expect to get about five flights or fifteen days from the pads. That backs out to $100 per Aaaaahhhh, at 15 uses. This thread just won't wilt. Happy New Year, Cindy B |
IGC Flight Recorders using Flarm firmware - New DLL file forvalidating IGC flight data files | Ian Strachan | Soaring | 0 | July 20th 14 07:28 PM |
New 18m Class ship - First Flight - The JS1 starts proving flight phase | [email protected] | Soaring | 2 | December 14th 06 02:06 AM |
NEW FLIGHT SCHOOL - Best in Flight Aviation Academy - Morristown,New Jersey | Dave Vioreanu | Piloting | 0 | April 22nd 05 02:55 AM |
NEW FLIGHT SCHOOL - Best in Flight Aviation Academy - Morristown, New Jersey | Guy Elden Jr | Piloting | 0 | April 21st 05 04:37 PM |
Does anybody know a link to a real picture of the X-43 in flight sans Pegasus or better yet a video clip of the flight? | Scott Ferrin | Military Aviation | 0 | April 3rd 04 08:47 PM |
