Relieving in flight
Old December 24th 17, 02:18 PM posted to rec.aviation.soaring
JS[_5_]
Default Relieving in flight
On Saturday, December 23, 2017 at 11:49:07 PM UTC-8, wrote:
On 23/12/2017 05:12, Charlie M. (UH & 002 owner/pilot) wrote:
Thank you from a female perspective. I only know a few females that do longer flights, Doris Grove, my mother and a few female juniors from HHSC and Valley Soaring, I know there are others, I just don't know them. I never really had good options for any of them, the "adult diapers" was my only suggestion, sorta based on the glider. Sitting sorta upright can be a challenge (2-33 or 1-26), glass can be a real PITA, even for guys.
The deluxe all-singing-and-several-thousand-dollars-dancing variety has
been produced for the US military (your taxes at work) and is called
AMXD - Advanced Mission Extender Device.
http://www.omnimedicalsys.com/index.php?page=products
GC
One-stop shopping for all your hydration and relief needs!
Probably cheap, since we already paid for it.
Old December 24th 17, 03:13 PM posted to rec.aviation.soaring
Muttley
In my Duo I drilled hole into seat at critical point and straight down through the Hull as well. Installed guide tube about 2cm ID,glassed to the inside of the Hull ending up at Seat level with loose wind closing flap on outside of Hull. Used a small teflon coated aluminium Tube about 50-60cm long to push through the guiding Tube. At the business end of the alu tube,connected piece flexible tube with a quick one way walve connection to the Condom. Also put a stopper (lid) on the guiding tube when not in use.
1. No contamination on glider as evacuation is quite some way away from Hull i.e. 40cm
2. No chance of freezing as tube is kept in the glider
3. Suction is so great that every last drop is removed from Tube ie. no mess
4. Use the Tube only when required, ie do not leave permanently in during flight.
However a word of advice when using this System, the Condom should not be fitted to close to the Tip if you are not circumcised as the Suction could pull your Foreskin and block the outlet on the Condom.
Old December 25th 17, 01:01 AM posted to rec.aviation.soaring
I started with a short section of thin walled plastic tube. Probably 5/8 inside diameter or pretty close to that. Drilled a hole large enough to fit the tube in the glider belly, just behind the stick. Drilled the same side hole in a small wood block, maybe 2x2x1. Push the tube through the hole in the wood block and out the belly, and glue the wood block to the floor (below the seat pan). Drill a hole in the seat pan, and trim the tube so that’s it’s flush with the outside of the glider and maybe 1/4 above the seat pan. Now you have a a sturdy channel to route your “pee tube” through. Make sure your “pee tube”is long enough to extend below the glider about 6 or 8 inches. If you don’t extend the far enough below the glider everything you send out will find its way back in via the wheel well, even with the doors closed.
IGC Flight Recorders using Flarm firmware - New DLL file forvalidating IGC flight data files Ian Strachan Soaring 0 July 20th 14 07:28 PM
New 18m Class ship - First Flight - The JS1 starts proving flight phase [email protected] Soaring 2 December 14th 06 02:06 AM
NEW FLIGHT SCHOOL - Best in Flight Aviation Academy - Morristown,New Jersey Dave Vioreanu Piloting 0 April 22nd 05 02:55 AM
NEW FLIGHT SCHOOL - Best in Flight Aviation Academy - Morristown, New Jersey Guy Elden Jr Piloting 0 April 21st 05 04:37 PM
Does anybody know a link to a real picture of the X-43 in flight sans Pegasus or better yet a video clip of the flight? Scott Ferrin Military Aviation 0 April 3rd 04 08:47 PM
