Paint stripper for sgs 1-23
Old December 30th 17, 09:49 PM posted to rec.aviation.soaring
Blue Whale
Default Paint stripper for sgs 1-23
There are some environmentally friendly aircraft paint strippers that work great as long as you do small areas at a time. If necessary cover with a plastic wrap to keep the area from drying out...then scrape the residue off with a plastic scrapper...repeat if necessary. Biggest issue is always around the rivets. The 1-23 wings were profiled with a lot of body filler. Here is a resource for paint stripper: http://solventkleene.com/Dzolve15R.html
Someone once said to me "the best way to remove the paint from a Schweizer is to fly it until the paint has peeled off" because once you go down the refinishing route.....it's gonna become a multi-year project for the club.
Old December 30th 17, 10:13 PM posted to rec.aviation.soaring
Papa3[_2_]
I think our club used the Dzolve mentioned above on a 1-26D or E a few years back. I think the consensus was that it worked about the same as the ones we used in the past but without as much of the nasty stuff. You do have to keep it covered and work in relatively small patches. Overall, 90% of the paint comes off pretty easily and the last 10% is the tough stuff. Lots of plastic scrapers and scotch brite pads.
This is an ideal project for a club, since it relies on a fair amount of elbow grease. You need one or two relatively skilled people to keep an eye on things (make sure nobody grabs a household hook scraper and starts gouging aluminum), and the rest just follow orders.
We've been averaging one refinish project or another in Aero Club Albatross for the last 5-6 years, and it's done a lot to build club spirit.
Erik Mann
Old December 31st 17, 06:27 AM posted to rec.aviation.soaring
We expect to wet sand and paint most of the surface but we still are entertaining the idea of stripping some small manageable areas to the bare metal for cool visual highlights
paint ED[_2_] Home Built 1 March 23rd 07 06:15 AM
paint [email protected] Soaring 9 March 7th 06 09:22 PM
Paint Steve Owning 17 January 8th 06 08:54 AM
Paint stripper damage [email protected] Owning 10 August 23rd 05 11:49 PM
Paint Stripper? PETER H. OUELLETTE Home Built 9 November 30th 04 06:12 PM
