Debunking the Shock Cooling Myth
Old January 6th 18, 03:29 PM posted to rec.aviation.soaring
Dan Marotta
Default Debunking the Shock Cooling Myth
When confronted with the bugaboo of cylinder shock cooling, my response,
even before reading the subject article, has always been: "What about
flying through rain?"Â* There's never been a cogent reply to that.
As to my procedure before retiring from towing, I simply reduced power
(throttle and prop) as necessary to arrive on downwind, at pattern speed
as quickly as possible, from wherever the glider released.Â* It's
difficult to tell a dozen glider pilots waiting for a tow, to "Slow
down, we're not hauling the mail"...Â* BTW, I'm not aware of any cracked
cylinders in 28 years of towing.
PS - I really enjoyed the original article and, from reading the
responses, see that there are folks out there who still cling to the myth.
On 1/6/2018 8:03 AM, Roy B. wrote:
We are running 2 Lycoming 235 Pawnees (one wide deck & one narrow deck) and a Continental L-19. We went through a spate of cracked cylinders (3 - In two different aircraft as I recall) about 4 years ago but I am not sure it had anything really to do with cool down procedures. Then the problem went away with no good explanation. Our method is to hold 2000 - 2100 rpm for a minute after glider release while descending then make a normal landing. I suspect that there are other issues involved in cylinder cracking: quality control in cylinder manufacture, torque variations in cylinder installation, localized vibration caused by cylinder/piston/ring fit, front vs rear cylinders (they cool differently), valve adjustment, and plain bad luck.
ROY - GBSC Boston (where it is really cold this morning!)
Dan, 5J
Debunking Glider Spoiler Turns Causing Spin Thinking [email protected] Soaring 135 January 7th 18 03:01 AM
Debunking 911 The Endeavor Naval Aviation 0 April 22nd 09 12:23 PM
Aerodynamics acording to Myth Busters! cavelamb himself[_2_] Home Built 51 November 4th 07 06:56 PM
Avoiding Shock Cooling in Quick Descent O. Sami Saydjari Owning 32 January 21st 04 04:32 AM
The myth that won't die. Roger Long Piloting 7 December 19th 03 06:15 PM
