![]() What I should have said is I've also found an 0-320 narrow deck engine that needs cylinders. Are the 2 compadibal. Drew "Dale Larsen" wrote: O-320 series E engines are narrow deck. E's use class 6 cylinders and 150HP pistons. They should fit just fine. snip This is simply not true. O-320 E-series engines were produced in both narrow-deck (ND) and wide-deck (WD). O-320 E-series engines use either ECI class 6 cylinders or class 4 cylinders depending on whether the engine is ND or WD respectively. Some Cherokee 140's were produced with E-series ND engines and some were produced with E-series WD engines. The O-320 E3D in my Long EZ, for example, is a WD engine from a Cherokee 140 and the cylinders would definitely not fit Drew's ND engine. David O -- http://www.AirplaneZone.com |
"David O" wrote in message
news ![]() . . . O-320 E-series engines were produced in both narrow-deck (ND) and wide-deck (WD). O-320 E-series engines use either ECI class 6 cylinders or class 4 cylinders depending on whether the engine is ND or WD respectively. Some Cherokee 140's were produced with E-series ND engines and some were produced with E-series WD engines. The O-320 E3D in my Long EZ, for example, is a WD engine from a Cherokee 140 and the cylinders would definitely not fit Drew's ND engine. How does one tell the difference? Rich "The Emeraude has an ex-Cherokee 140 E3D" S. |
"Rich S." wrote:
How does one tell the difference? Rich "The Emeraude has an ex-Cherokee 140 E3D" S. Serial numbers for Lycoming wide-deck engines end with an "A" while serial numbers for Lycoming narrow-deck engines do not end with an "A". Narrow-deck cylinders are held down with internal-hex nuts (driven by a hex wrench) and sometimes, but not always, have hold-down plates. Wide-deck cylinders are held down by common-looking hex nuts and do not use hold-down plates. David O -- http://www.AirplaneZone.com |
... "Rich S." wrote: How does one tell the difference? Rich "The Emeraude has an ex-Cherokee 140 E3D" S. Serial numbers for Lycoming wide-deck engines end with an "A" while serial numbers for Lycoming narrow-deck engines do not end with an "A". Narrow-deck cylinders are held down with internal-hex nuts (driven by a hex wrench) and sometimes, but not always, have hold-down plates. Wide-deck cylinders are held down by common-looking hex nuts and do not use hold-down plates. Thanks! Rich S. |
V-8 powered Seabee | Corky Scott | Home Built | 212 | October 2nd 04 11:45 PM |
0-235 lyc cylinders needed (3) | Captain Dave | Home Built | 0 | October 8th 03 08:00 PM |
