RIP Tomas Reich - SGP Chile
Old January 25th 18, 10:39 AM posted to rec.aviation.soaring
krasw
Default RIP Tomas Reich - SGP Chile
On Thursday, 25 January 2018 02:14:48 UTC+2, wrote:
Let's be honest. If soaring were a zero-risk activity, like video games, it wouldn't have the same appeal.
Chip Bearden
I cannot agree with this. I have skipped a lot of competitions because increased risk level, and making that risk smaller would increase appeal of these events greatly, at least for me. Competition flight is always a great adventure, feeling that this might not end well does nothing to me expect decision that I do not let this same situation to happen ever again.
Old January 25th 18, 04:05 PM posted to rec.aviation.soaring
Bob Whelan[_3_]
Random post selection in action here - not intending to pick a bone with any
individual, but since the excerpted top post/point has been singled out by
several as a point of disagreement, here's a take from a slightly different
perspective.
I don't DISagree with the top post's assertion...which is far from saying that
I AGREE with an assertion that it's risk that attracted/attracts me to
soaring. However, few would argue that it's easier to summon forth personal
focus from inside a cockpit in the atmosphere than (say) from inside "the
average soaring simulator" (aka - w. wry humor - "video game proxy"). Point
being that - for me - there's no question that one of the (very, very, many)
personal satisfactions and enjoyments I derive from soaring is the
rarely-verbalized one of the *knowledge* that the activity requires unceasing
"acceptable mastery" of the risks involved in flight. That fact - while hardly
qualifying me as an adrenaline junkie - is personally undeniable, and in that
sense IS part of soaring's appeal for me. The activity unavoidably demands -
and provides positive feedback about - good judgment and one of its real-world
benefits. I find that appealing.
So while the risk didn't attract me, successfully managing it IS a continuing
attraction. Life...full of paradoxes...
Perhaps pedantically,
Bob W.
This email has been checked for viruses by AVG.
http://www.avg.com
Old January 25th 18, 06:59 PM posted to rec.aviation.soaring
Steve Koerner
Even over strictly flat flying areas, the hard deck idea has serious problems:
1. Someone here already pointed out that a pilot's motivation to not land out is partially about points, for sure, but also about the various practical hardships (plus embarrassment) that result from not making it home. The incremental difference in flying behavior would be small at best.
2. The fact that you have scored the poor SOB as landing out due to his "hard deck" altitude, does not place a safe landing beneath him. If the next turnpoint is straight ahead and the best farm field was back over there, one's problems and temptations are not magically resolved by a hard deck rule. The exercise of marginally bad judgement about where to turn back for a safe landing under hard deck rules has a very good chance of having a quite similar consequence as exercising marginally bad judgement under present rules and circumstances. To a significant degree, the problem is moved, but not eliminated.
3. There is no way for a pilot in his cockpit to know whether he has become subject to the rule or not. GPS makes only a crude estimation of altitude. Pressure based altitude works at the home airport where reference pressure is known indirectly by field elevation referencing before takeoff and after landing. The pilot is able to set his altimeter at the home airport. At a remote location late in the day, the pilot will not have a pressure reference available to him and consequently will not know his altitude accurately enough for the proposed purposes. His altimeters are not accurate and furthermore he has no ability to guess how well the scorer's interpolation of local pressure will play out over time and map position. The result will be, that for competitive reasons, he will need to assume that he is not landed out -- likely all the way until exactly the same height at which he would have otherwise committed to a landing. The idea doesn't work.
Old January 25th 18, 07:52 PM posted to rec.aviation.soaring
John Cochrane[_3_]
The idea does work. If you don't want it, that's another issue.
JC: We'll see about that. However, the point is not to stop, regulate or force pilots to do anything, to supplant pilot judgement, and so on. All we do is remove a temptation. If you choose to thermal below 500 feet, that's up to you, but you will not get any contest points for doing it. We eliminate those campfire stories about thermaling over a teacup and winning the day..
In practice, I notice most pilots on recreational cross countries are pretty good at giving up around 500 feet. The traces from contest crashes are full of much lower thermaling -- down to 150 feet in one case.
In any case, the point is not to force pilots to change behavior. The point is merely to stop rewarding such behavior with contest points. And, to remove the occasional very low save from the set of tricks that help you to do well at contests.
JC: Again, again, again, the point is not to regulate pilot judgement. Yeah, dude, you have to look out the window and not count on rules to tell you what to do. All it does is to remove a temptation that when things have gone to pot and you're under 500 feet, make your best pilot decision and we won't tempt you with points.
JC: Absolutely false. Gee, how do we handle the hard ceiling, and the start gate top? With an SUA file, pressure altitude, and a readout on your glide computer that tells you if you've busted the limit. Same here. The hard deck would be a set of stepping stone SUAs in 500 foot increments. You are over an SUA with, say 1000' MSL top. When the pressure altitude on your glide computer says 499, you're done. (US rules would likely put in a graduated penalty, but you get the idea)
Monitoring an altitude floor is no harder than monitoring an altitude top.
Again, let's get over "it can't work." It can, easily, especially at flatland sites. The real argument is "I wanna keep thermaling at 300 feet" and I don't mind if others beat me by doing so." That's one worth having.
John Cochrane
Old January 25th 18, 08:27 PM posted to rec.aviation.soaring
Lots of good comments on this thread. I'd like to address the concept of contest participation.
Folks have commented on here that many pilots are scared away from flying contests because of the risks involved. And many posts are concerned with trying to mitigate the risk factors as well as to dis incentivize risky behavior by applying penalties.
All well and good but there exists a large portion of flyers who enjoy xc but don't want to have a dang thing to do with contest flying directly because of all the rule bull**** and hasstle that exists nowadays. I am one, and I directly know of three other experienced contest flyers who still fly loads of xc and record chasing but have walked away from contest flying due to the restrictive and political nature of the sport as it exists today.
Keep pilling on more and more rules regulations requirments and mandatory equipment and watch the ranks of contest flyers shrink even more. I ditched my ventus years ago and bought a 1-26 to race with those guys. The competition is FIERCE, the rules are sensible, most everyone flies respectfully and circumspectly. The contest is a direct test of piloting skill not bank account. AND landing out is not a sign of failure nor do guys heap loads of derision on a landout guys head.
We have very very few incidents or accidents. We DO fly over rough terrain, we do take many chances ( necessary with 23/1 ld) but for the most part, the guys that are racing these ships know what the hell they are doing and they know every nuance of their ship. I can't say the same for many other classes who have become slavishly dependent upon l/d and electronics at the expense of good piloting judgement and skill.
Dan
Old January 25th 18, 09:11 PM posted to rec.aviation.soaring
Steve Koerner
John: I agree that it would be possible to set a numeric criteria and use your flight recorder like we do for other SUA numbers. I do need to state the issue in different terms...
The class A SUA is effectively set in terms of pressure measurement at nominal 17,500. It doesn't matter that one's flight recorder is reading wrong by +/- 500ft. For SUA, we simply all agree and understand that we are going by a known faulty pressure measurement. In fact, the expectation that it will read wrong by 500 ft at some probability is the reason that it's not an 18,000 ft contest criteria. When we are at the start cylinder, our altimeters have been recently referenced to field elevation; so in that case the measurement is fairly accurate. Not so out on course, 100 miles away late in the day. There will not be a suitable relationship between what is measured and where the ground actually is.
You would have to incorporate an expectable measuring uncertainty into your hard deck. The hard deck would have to be set to avoid the obvious problem that would be created by a false confidence scenario wherein the rules indicate that I'm not outside safety limits so I must be safe enough to keep circling.
You will end up with a hard deck number not very acceptable to very many people. Pilots will prefer to eyeball what is a safe circling height rather than have a faulty measurement dictate when it is not safe according to the rules. To state the problem differently: being scored as landing out due to an unreasonably high "hard deck" when you in fact, make it around without compromising your safety, will seem objectionable to most. I know it would be objectionable to me.
What's more, pilots will ultimately change their circling behavior only minisculely due to a hard deck land out rule -- they still need to get back to the airfield for plenty of good reasons.
Old January 25th 18, 09:38 PM posted to rec.aviation.soaring
krasw
Hard deck is not "lowest safe altitude". It is altitude where scoring stops..
Old January 25th 18, 10:07 PM posted to rec.aviation.soaring
You want to "dis incentivize" risky behavior and minimize "risk" in a contest, here's your new rules:
-No saves below 1500 ft AGL hard deck, your scoring stops
-fly closer than 1000 fr to any mountain surface your scoring stops
-no more than 3 planes in a gaggle, you find your own or wait till someone departs
- all thermals must be flown using left turns no matter where on task cause some idiot might enter your thermal the other way
-no flying closer than 400 ft to nearest ship
- no peeing unless you have a cathiter cause thats a distraction
-fly slower than 3knots of your ships published stall speed and your scoring stops
-on a strong convection day (500fpm+) no flight speed greater than your ships max manuver speed.
Add these to all the existing rules, and there you have it, minimum risk max dis incentives.
IF some goof wants to enact all those rules at a contest, we will STILL be having this conversation a year from now when some goof has an accident and we all moan n groan wringing our hands about how risky contest flying has become and what NEW rules we can enplace to help keep someone alive. Now see who wants to come out and fly that contest.
Old January 25th 18, 10:09 PM posted to rec.aviation.soaring
jfitch
There are two reasons for the hard deck: one is to keep idiots from being idiots. But the more important one is to keep the sensible pilots from having to be idiots to compete. I guy who frequently circles very low might continue to do so with a hard deck rule. But the more sensible pilot who stays above the hard deck and goes slower as a result would not lose to the idiot.. This isn't really about protecting the idiot, it's about protecting the responsible pilot who must otherwise become an idiot, or lose.
Modern flight computers will easily be able to warn you when you are getting close to the deck, exactly as they do now for the ceiling.
John has it exactly right that the argument is really "I want to keep circling at 300 ft". All we are doing is creating a virtual ground slightly above the real ground to insure everyone's margin for error is equal, so their chances of winning on this basis are equal. It does not change the competition at all other than this.
It as amusing that the same arguments are used by some of the same individuals against motorgliders: that the motor allows continuing low over unlandable terrain and this is unfair. All you need in a non-motorized glider to do that is a high risk tolerance, this is equally unfair. The hard deck makes both of those arguments moot.
Old January 25th 18, 10:26 PM posted to rec.aviation.soaring
As always, John makes some excellent points. As occasionally happens, I don't necessarily agree with all of them.
Bob restated my thesis much more accurately and succinctly. It's not the risk, per se, that is appealing. It's mastering and managing the risk that keep me coming back every year.
Using the rules to reduce risk isn't new. We've been doing it as long as I've been flying, including: (skip to the bottom if you don't want a walk down soaring memory lane)
1. Eliminated the risks of high-speed retrieves from an early outlanding and hurried assembly before a quick relaunch.
2. Eliminated the risk of high-speed starts.
3. Reduced the collision risk of mass starts and eliminated the scoring risk that one or more pilots might be missed in the confusion.
4. Reduced the risk of heading out on course relatively low because of the old 1,000 m start gate altitude limit.
5. Eliminated the risk of low final glides, at least to the finish.
6. Eliminated the risk of low high-speed finishes.
7. Reduced the risks of catastrophic points penalties from relatively minor rules infractions with graduated penalties.
8. Eliminated the risk of being late in the launch queue and sitting on the ground while early launches start on course (relevant for old-style distance tasks and storm days).
9. Eliminated the risk of landing out simply because tasks were called under the philosophy that only half the field should finish.
10. Eliminated the risk of landouts on straight out and early area distance tasks.
11. Reduced the risk of flying with too little sleep from long flights and equally long retrieves occasioned by more aggressive tasking, including distance tasks.
12. Reduced the risk that one or a few pilots could gain a huge advantage through luck on an uncertain day (i.e., before devaluation became widespread).
13. Eliminated the risk of committing to a task set before the pilots' meeting that might be clearly inappropriate just a few hours later, which could result in mass landouts or a gross undercall.
14. Eliminated the risk that the manually operated start/finish gate might make an error, favoring or disadvantaging a pilot unfairly.
15. Eliminated risk that a pilot might attempt to achieve an advantage by [illegally] overloading his/her glider on a strong day.
16. Eliminated the risk that a pilot might illegally benefit and/or create a collision hazard and/or invite regulatory action from an airspace violation.
17. Reduced the risk of large numbers of gliders being forced to relight nearly simultaneously after being launched before soaring is possible.
18. Eliminated the risk of having to select a takeoff time in mid morning without knowing when the weather would become soarable.
19. Reduced collision risk by encouraging--and in some cases mandating--the use of FLARM technology.
20. Reduced the risk of being unable to locate a downed pilot by encouraging--and in some cases mandating--the use of ELTs.
21. Reduced the risk of landout damage by offering point-of-furthest-progress scoring and an airport bonus to incentivize pilots to land at airports.
I'm sure there are more. The point is that it's not out of line to consider another rules change to try to reduce the risk of pilots making mistakes when they are low. But is that what we want?
When I said that soaring without any risks wouldn't be as appealing, I wasn't referring to the above (mostly; I don't want to set off another debate about final glides and finish lines!).
Nor was I referring to the risk of, say, a midair collision, an uncertain event with disastrous consequences over which we have imperfect control.
But soaring isn't a video game (Condor excepted). We preemptively manage risk every time we turn our backs on the home airport and head out cross country, accepting the higher risk of damage from a possible land out. Mastering and managing that risk by flying well enough to return home while knowing how to pick a field and land in it safely if we can't is both exciting and satisfying, at least to me.
It's the same for flying a contest task on weak days when we otherwise wouldn't even bother to launch, much less attempt a cross-country flight, and for learning how to fly safely and competitively on ridges and in the mountains.
We all fly for different reasons. But for me, soaring would not have the same appeal if all we did was call short tasks on only the best days over landable flatlands. No one is suggesting that (yet). But the trend I see is towards a more regulated contest environment where we attempt to manage risks more through rules making (OK, scoring incentives), leaving less up to the pilot. That's not always a bad thing, just as free marketplaces need certain laws and regulations to prevent shortsighted and/or unethical players from profiting unfairly at the expense of others.
But we took navigation skills off the table years ago when we allow the use of GPS, making it easier for certain pilots (you know who you are!) to place well. We're already hearing that soaring is headed toward universal auxiliary power and the end of landouts, another skill from the old days.
For the sake of discussion, what hard deck would be proposed for flatland flying? Is the fact that some pilots could safely take it down to 500' while others would be at their limit at 1,000' mean we should set the deck at the higher level? Would removing the incentives for things that expert pilots can do safely but less qualified pilots cannot do reduce the reward for such excellence and result in compressing the skills--and points--of the pilots in a contest?
And could there be unintended consequences? I know my attention is more focused on my glide computer and altimeter when I am approaching the finish cylinder to make sure I don't bust the hard deck there...and that's when all I have to do is push over more or less to make the numbers come out. I watched several of the world's best pilots bust the hard deck at the finish at the Chile SGP in their eagerness to win the race. Was that a conscious decision knowing what the penalties were, or did they just take their eyes off the ball momentarily?
As I'm struggling to stay above the floor in a marginal thermal, do I want to have to watch the ####ing altitude readout closely not just to insure I'm hanging on but that I'm not sinking through the floor? If the thermal is choppy and I'm marginal, will I be tempted to pull back slightly to maintain my altitude, thereby eroding my safety margin? Will I be forced to ignore a hawk going up fast a half mile away knowing I'm likely to drop through the hard desk on the way there?
Will we be discouraged from flying over low hills and ridge lines seeking thermals when low because although they are far more likely sources, the hard deck makes them unusable?
And since we're trying to address human frailties here, what about the subtle message that it's safe to circle just above the hard deck? I don't know about the rest of you but my decisions to keep thermaling at 500' are very, very few and far between. I don't have a single criterion for that decision; it's contextual and depends on altitude, turbulence, wind, landing options, terrain, time of day, my physical and mental condition, my standing at the time and what kind of contest it is, etc. Some pilots may subconsciously be LESS likely to worry about the risks of low thermaling so long as they remain above the hard deck...because it's within the rules. The human mind behaves in odd ways.
I agree with John that technically a hard deck could be implemented, albeit imperfectly, in the flatlands. I just don't agree (at least now) that we should do it.
But it's a thoughtful discussion. We should probably retitle this and move it to another thread, however.
Chip Bearden
de Havilland Canada DHC-6 Twin Otter pics 1 [03/11] - DeHavilland-Canada-DHC-6-100-Twin-Otter-Chile-Air-Force-Fuerza-Aerea-De-Chile-Twin-Engine-Airplane-Aircraft-940.jpg (1/1) Miloch Aviation Photos 0 September 30th 17 03:10 PM
Any news from Chile Bob Gibbons[_2_] Soaring 3 March 2nd 10 04:08 PM
Soaring in Chile [email protected] Soaring 3 February 21st 09 11:43 PM
The GP in Chile cernauta Soaring 0 January 7th 09 12:51 AM
Reich Weapons in Australia robert arndt Military Aviation 0 January 3rd 04 04:47 PM
