RIP Tomas Reich - SGP Chile
Old January 25th 18, 09:38 PM posted to rec.aviation.soaring
krasw
Default RIP Tomas Reich - SGP Chile
On Thursday, 25 January 2018 23:11:13 UTC+2, Steve Koerner wrote:
John: I agree that it would be possible to set a numeric criteria and use your flight recorder like we do for other SUA numbers. I do need to state the issue in different terms...
The class A SUA is effectively set in terms of pressure measurement at nominal 17,500. It doesn't matter that one's flight recorder is reading wrong by +/- 500ft. For SUA, we simply all agree and understand that we are going by a known faulty pressure measurement. In fact, the expectation that it will read wrong by 500 ft at some probability is the reason that it's not an 18,000 ft contest criteria. When we are at the start cylinder, our altimeters have been recently referenced to field elevation; so in that case the measurement is fairly accurate. Not so out on course, 100 miles away late in the day. There will not be a suitable relationship between what is measured and where the ground actually is.
You would have to incorporate an expectable measuring uncertainty into your hard deck. The hard deck would have to be set to avoid the obvious problem that would be created by a false confidence scenario wherein the rules indicate that I'm not outside safety limits so I must be safe enough to keep circling.
You will end up with a hard deck number not very acceptable to very many people. Pilots will prefer to eyeball what is a safe circling height rather than have a faulty measurement dictate when it is not safe according to the rules. To state the problem differently: being scored as landing out due to an unreasonably high "hard deck" when you in fact, make it around without compromising your safety, will seem objectionable to most. I know it would be objectionable to me.
What's more, pilots will ultimately change their circling behavior only minisculely due to a hard deck land out rule -- they still need to get back to the airfield for plenty of good reasons.
Hard deck is not "lowest safe altitude". It is altitude where scoring stops..
Old January 25th 18, 10:07 PM posted to rec.aviation.soaring
You want to "dis incentivize" risky behavior and minimize "risk" in a contest, here's your new rules:
-No saves below 1500 ft AGL hard deck, your scoring stops
-fly closer than 1000 fr to any mountain surface your scoring stops
-no more than 3 planes in a gaggle, you find your own or wait till someone departs
- all thermals must be flown using left turns no matter where on task cause some idiot might enter your thermal the other way
-no flying closer than 400 ft to nearest ship
- no peeing unless you have a cathiter cause thats a distraction
-fly slower than 3knots of your ships published stall speed and your scoring stops
-on a strong convection day (500fpm+) no flight speed greater than your ships max manuver speed.
Add these to all the existing rules, and there you have it, minimum risk max dis incentives.
IF some goof wants to enact all those rules at a contest, we will STILL be having this conversation a year from now when some goof has an accident and we all moan n groan wringing our hands about how risky contest flying has become and what NEW rules we can enplace to help keep someone alive. Now see who wants to come out and fly that contest.
de Havilland Canada DHC-6 Twin Otter pics 1 [03/11] - DeHavilland-Canada-DHC-6-100-Twin-Otter-Chile-Air-Force-Fuerza-Aerea-De-Chile-Twin-Engine-Airplane-Aircraft-940.jpg (1/1) Miloch Aviation Photos 0 September 30th 17 03:10 PM
Any news from Chile Bob Gibbons[_2_] Soaring 3 March 2nd 10 04:08 PM
Soaring in Chile [email protected] Soaring 3 February 21st 09 11:43 PM
The GP in Chile cernauta Soaring 0 January 7th 09 12:51 AM
Reich Weapons in Australia robert arndt Military Aviation 0 January 3rd 04 04:47 PM
