RIP Tomas Reich - SGP Chile
Old January 27th 18, 12:03 AM posted to rec.aviation.soaring
Default RIP Tomas Reich - SGP Chile
SUA space is no different than any obstacle. Your flight computer tells you if you are going to clear the far edge. If it doesn't, I can suggest about 5 flight computers that will. We already do this in Minden/Truckee/Air Sailing, overflying the Reno SUA. If you drop into it on the way you are DSQ'd. It's just like flying over a high unlandable plateau which do exist out here in the west. Before you start across, make sure you can get to the other side. Again, violating SUA gets you a penalty or no points, violating the plateau gets you death. The hard deck would not be possible without GPS and flight computers - but guess what, they're here to stay.
This GPS stuff is a fad. I still use a map and compass.
I do have a handful of electronic gadgets. And I even know how to switch them on most of the time. And we have high unlandable plateaus back east. And I've flown a Nationals out of Minden and turned at Truckee and Air Sailing, among other sites.
You've missed a big point: namely, what will my arrival height be vis-a-vis the hard deck? Say the hard deck is at 6,000 MSL. The valley is roughly 5000' MSL, more or less. I'm in the middle of the SUA so I don't care how far away the edge is. I spot a field fire (you have those out west too, at least at Uvalde) about 3-4 miles away. I'm at, say, 6,800' MSL, 800' above the hard deck and about 1,800' above the valley floor. But my glide computer is not much help because unless I can point to a specific spot on the screen and do a GoTo or otherwise see for sure that the fire lies within the amoeba (which, of course, I've reconfigured to account not just for peaks and ridges but also for SUA floors, or maybe it's two amoebas, one for reachable landing spots and another one for reachable hard deck range), I don't know whether I'll bust the hard deck getting to the fire.
It's landable here so in a contest (or even a practice flight if I don't have another thermal), I'll go for the fire, estimating I'll still be 1,000' AGL or so when I get there. But its location is uncertain and, therefore, so is my arrival altitude, especially given a jolt of sink just before I hit 10 kts up in the smoke.
Idle thought: maybe we should allow adjusting the hard deck for total energy, so if you dive down below it but can still pull up over it, you're not penalized. Just a thought!
It's the same glide calculation I have to make now based on the terrain. But I can SEE about what my projected clearance is likely to be and shave it down or augment it based on what's available nearby in which to land. Yes, it takes some experience to do so. Yes, some less experienced pilots will play it conservatively and not run for the fire. That's fine; they're safe. Others will plunge ahead without thinking and might have to land. It sounds harsh but the sensible pilots shouldn't be penalized by preventing them from exercising their experience and being rewarded for it because a few pilots don't exercise care. It's the other side of the coin of "don't penalize me because someone else stupidly flies over Lake Tahoe relying on ridge lift".
It's easier the thermal is marked by a gaggle and some gliders have FLARM because now they're depicted on my map display and I can project (with an extra step for the devices I use) what my arrival height should be.
Back East, there will a movement to convince the U.S. Fish & Wildlife Service to equip soaring birds with tiny FLARM devices so we can see them on our computer screens and judge whether those low altitude bird saves will incur a penalty.
I think the idea of a hard deck has merit. I'm worried that all of us, including me, are tossing it around without thinking through the real-world problems of implementation. I'm in the technology business. It's very seldom the technology that fails in a project; it's almost always the implementation thereof.
That's why this discussion is valuable. And that's why I think dismissing anyone who offers reasonably informed comments in good faith fashion is a mistake.
BTW, I assume your ability to overfly the Reno Class C (ceiling 8400 MSL per the latest SUA files) without a catastrophic penalty is permitted by a special waiver. SSA Rules for sanctioned contests explicitly prohibit overflying such "closed" airspace, even when transponder equipped.
Chip Bearden
Old January 27th 18, 04:29 AM posted to rec.aviation.soaring
jfitch
It's the same glide calculation I have to make now based on the terrain. But I can SEE about what my projected clearance is likely to be and shave it down or augment it based on what's available nearby in which to land. Yes, it takes some experience to do so. Yes, some less experienced pilots will play it conservatively and not run for the fire. That's fine; they're safe.. Others will plunge ahead without thinking and might have to land. It sounds harsh but the sensible pilots shouldn't be penalized by preventing them from exercising their experience and being rewarded for it because a few pilots don't exercise care. It's the other side of the coin of "don't penalize me because someone else stupidly flies over Lake Tahoe relying on ridge lift".
Chip Bearden
The Reno Class C is a waiver, and has been that way for a long time - maybe a couple of decades? No one has thought it a problem. You don't cross it unless you are high enough, if low you do so at the peril of DSQ. (The limit in races is actually 10,000 ft, so well above the true legal limit). With the computer I use, I would not have a problem determining my glide over the SUA to where ever I am going. It is clearly shown on the flight profile. In fact most of the time the hard deck is well below the working band and is a non-issue.
de Havilland Canada DHC-6 Twin Otter pics 1 [03/11] - DeHavilland-Canada-DHC-6-100-Twin-Otter-Chile-Air-Force-Fuerza-Aerea-De-Chile-Twin-Engine-Airplane-Aircraft-940.jpg (1/1) Miloch Aviation Photos 0 September 30th 17 03:10 PM
Any news from Chile Bob Gibbons[_2_] Soaring 3 March 2nd 10 04:08 PM
Soaring in Chile [email protected] Soaring 3 February 21st 09 11:43 PM
The GP in Chile cernauta Soaring 0 January 7th 09 12:51 AM
Reich Weapons in Australia robert arndt Military Aviation 0 January 3rd 04 04:47 PM
