Hard Deck
Old January 28th 18, 06:53 PM posted to rec.aviation.soaring
jfitch
Default Hard Deck
The issues are quite site dependent. Out in the west, there aren't many instances of circling at 300 ft AGL that I have seen, the issue is more typically getting down to 3000 ft AGL where there are only crashing sites within glide range. Usually the perpetrator finds lift and makes it out, and often this is a competitive advantage. Occasionally they don't find lift, land or crash at an inaccessible location.
As I understand it back east, the whole contest is run at less than 3000 AGL and often far less. In addition, the issues out west are less having to cross an SUA to get to the other side, and more typically having to stop and take a 2 knot thermal rather than pushing on, low, hoping for a 10 knot thermal. Even though mountainous, I would not envision a bunch of inverted cake steps. A simple readout of vertical clearance to the SUA you are over is sufficient and behaves exactly as your altimeter, requiring no more attention. I'm getting close to the SUA ('ground') and I'd better stop for the next thermal. You really only need to know the top of the SUA, once, for that valley - it doesn't change. You look once, see that the floor is 8000 ft, and take thermals when you get down to 8500 or so. There isn't any need to stare at instruments. The edges are rarely a concern, because they typically end at the rising terrain surrounding it, you can't drop over the edge without penetrating rock.
I'm not sure if that is really John's proposal, but that's how I had envisioned it.
Old January 28th 18, 08:45 PM posted to rec.aviation.soaring
Papa3[_2_]
Default Hard Deck
Exactly. Like Chip, I went back and looked at the BB Contest Safety Reports. If you leave aside mountain and ridge sites (technical sites), it's hard to find any crashes which would have been prevented by some sort of hard-deck. Two of the examples (Fairfield and Perry) happened near the home airport, ostensibly due to pilots trying to squeak home. We already have a rule for that (minimum arrival height). The Diana crash at Fairfield should have been a successful outlanding since the pilot did some things right (i.e. committed to a landout) but inexplicably messed up by switching fields late.
The Pegasus crash at Elmira wasn't a guy trying to extract maximum points on the day. As the report makes clear, he had already given up racing and was just trying to avoid landing out. He botched what should have been a simple field landing. Similarly, the Mifflin crash in the Stone Valley looks to have resulted from a failed ridge run, perhaps due to inexperience with ridge flying.
Now, let's consider unintended consequences in a flatlands site. Here's a very realistic scenario. Windy day. 10 mile marginal stretch with good fields on the other side (maybe even an airport). Pilot leaves with a cushion but gets slammed. 2 miles from the safer terrain and cruising at 80kts he's down to 300 feet above the "hard deck" (say 1000 feet). He's got a reasonable/safe glide to the fields, but points are on the line. He will almost certainly drop down under 1000 feet before he gets to salvation. Then, he hits a broken half knot. At least he's not going down. What does he do? The safe thing is to bounce it and proceed knowing he's almost certainly going to "virtually" land out. But points are on the line. So he stops and tries to make the half knot rotor/thermal work, only to drift back another mile while bleeding off the speed he had in the tank. After flailing around gaining on a half turn and losing on the other half, he loses the half knot entirely, but now he's got a much more marginal glide to the safe fields. In fact, he's not sure he can make it. Well that sucks.
Regarding mountain and ridge sites, can you really anticipate all of the permutations in conditions to make a one-size-fits-all hard deck? Leave aside the high ground; even the valleys have significant risks with one set of conditions and can be completely benign in others.
I don't believe that we can afford to do nothing, but I don't agree this is the solution. Couple of thoughts:
- Reading the Nadler report about the Sugarbush debacle vs. Cindy B's observations, it's clear that pilot qualifications/experience ought to be studied more carefully. CDs and CMs ought to be comfortable challenging pilots who appear to be in over their heads.
- Encourage pilot classification (e.g. Gold vs. Silver) classification rather than always grouping by glider classification at highly technical sites.. Then, ensure CDs call tasks accordingly, inlcluding being willing to cancel days (such as the rain/ridge/wave day in the Sugarbush report) for the less-experience classification.
- Encourage more sites to improve the task area briefings with more focus on never-go areas or minimum safe altitudes under specific conditions.
P3
Old January 28th 18, 09:39 PM posted to rec.aviation.soaring
Per Carlin
Default Hard Deck
Are we not trying to overcomplicate things again with this sua-file?
With this file do we remove the responsibility to fly safe from the pilot to the CD. It is the pilot who decides what is safe and what is not, anykind of rules should not take over this responibility. But it should remove the gain of stupidity. And what will happens if the CD makes the sua-file wrong. Who to blame, the pilot or the CD?
An easier solution would be to stop counting distance points from 300m(~100feet) AGL of your outlanding. If you landout do you get max distance of the logg where you are at least 300m above the landing. The hard deck can be defined i local procedures according to actuall terrain as in Big forrest areas should the level be increase compared to the flatland with large agricultures.
This would not take out the thrill of an low save, but it will stop you from making studid glides on low level to gain thoose valuble extra points as each km gives you. Thoose glides are a real problem, current rules promotes stupidity to glide as far as possible when the outlanding is unaviodable. Each extra km can be 4 points, 10km can be 40points and that can be the difference to be on the podium or not at a WGC. So how are you gonna spend your last 300m, make a pattern and loose the medal or continue and win the game?
With rules that stops giving you distance points does not remove the pilots resposibility but it take away the gain on doing something stupid.
/Per Carlin
Old January 28th 18, 10:33 PM posted to rec.aviation.soaring
jfitch
Default Hard Deck
This would not take out the thrill of an low save, but it will stop you from making studid glides on low level to gain thoose valuble extra points as each km gives you. Thoose glides are a real problem, current rules promotes stupidity to glide as far as possible when the outlanding is unaviodable.. Each extra km can be 4 points, 10km can be 40points and that can be the difference to be on the podium or not at a WGC. So how are you gonna spend your last 300m, make a pattern and loose the medal or continue and win the game?
/Per Carlin
Isn't that just a hard deck set at 300m AGL? Doesn't it have all the same critics as the SUA file version? You still can't see it, it still eliminates the 200' ridge crossings. You are still going to circle in P3's half knotter if you see yourself falling below it.
We have at least on instance of the SUA version, the Reno Class C. It's an irregular (but well known) shape, and large. It is overflown frequently in contests, and has been that way for about 20 years. There've been people DSQ'd for dropping into it. I've not heard any complaints or problems with it..
Old January 29th 18, 12:15 AM posted to rec.aviation.soaring
Steve Koerner
Default Hard Deck
/Per Carlin
It's significantly different Jon. No new rules have to be created. No new SUA files have to be created.
Because it is precisely ground referenced, it can be much lower (my suggestion 300 ft vs John's hard deck suggestion of 500 to 1000 ft). That makes for essentially no impact on all of the scenarios. For any sensible pilot a ground referred 300 ft rule does not impede or confuse any flying behavior.. It is assuredly the case that you and I would have made the chose to land before that point -- not so with an altitude based and variable 500 to 1000 ft rule.
I agree that it is not accurately knowable in the cockpit. But with a 300 ft ground referenced rule, that makes essentially no difference. Nobody will need to game a 300 ft rule.
Old January 29th 18, 12:24 AM posted to rec.aviation.soaring
Default Hard Deck
The concept of applying a hard deck for soaring competition is pure lunacy. Stop trying to pretend competition can be "ruled" free of risk. Or otherwise, lets just give every entrant "first place" like they do in kid's sports..
The undeniable fact of winning races (in any sport) is pushing one's skills and equipment to the limit of their abilities while enjoying a pinch or two of good fortune. By surpassing personal limits, one then enters the "stupid zone" where anything can happen. Is a hard deck limit not an attempt to fix stupid?
Good luck with that.
Old January 28th 18, 09:01 PM posted to rec.aviation.soaring
Jim White[_3_]
Default Hard Deck
This thread is very thought provoking. I wish to declare a principal: I am
against excessive rule making.
I am of the opinion that it is down to the director to look for and
intervene when he / she sees unsafe behaviour and then have the authority,
and balls, to sanction or disqualify the pilots that take disproportionate
risk.
Old January 28th 18, 10:30 PM posted to rec.aviation.soaring
Steve Koerner
Default Hard Deck
risk.
Precisely. I have a proposal that I think addresses BB's issue without any new rules. Here's how...
We already have the rules that we need:
10.9.1.4 Pilots must pay particular attention to safety during the process of finishing, landing, and rolling to a stop. A pilot whose
finish, pattern, landing, or rollout is deemed unsafe by the CD is subject to a penalty for unsafe operation (¶ 12.2.5.1).
12.2.5.1 Unsafe operation (including all phases of flight and ground operation) (¶ 10.9.1.4, ¶ 10.9.3.4): maximum penalty = disqualification.
In the rules guide or by declaration of the contest CD, it shall be overtly recognized that thermalling in the flats (wherever there isn't a lower escape) at or below 300 feet is defined to be unsafe.
It will be recognized that an assessment of low thermalling can be made if and only if the glider lands within 30 minutes of the time of the infraction such that the flight recorder will have a presumed to be valid pressure reference. The proposed penalty may be 200 points for a first infraction, for example; and perhaps zero for the day on a second infraction.
In practice, when the scorer has time to address the matter, he will examine the flight logs of pilots who have landed out to determine whether any low thermalling had occured within the 30 minutes prior interval. If he finds such, he brings the data to the attention of the CD. The CD makes a penalty assessment taking into consideration the data presented and any other relevant factors.
This would create a strong motivation in the cockpit to not take a chance of losing a lot of points on a low save attempt that probably won't work anyway. We all know that recovery attempts at a very low altitude are quite unlikely to succeed. The cockpit calculus changes in exactly the way that BB (and most all us) desires to reduce the occurence of spin-in accidents.
With this, we avoid a lot of new rules and complication. Our flying liberty is not grossly impacted. With a 300 foot standard, most pilots would be motivated to break off at around 500 or 600 feet because they would not be able to precisely judge where the 300 foot AGL point would be and are motivated to not take a chance on the points loss.
All of my numbers here are just for example. My numbers might be refined by more careful consideration or even adjusted at the discretion of the CD for different sites.
Old January 28th 18, 10:41 PM posted to rec.aviation.soaring
jfitch
Default Hard Deck
risk.
This would create a strong motivation in the cockpit to not take a chance of losing a lot of points on a low save attempt that probably won't work anyway. We all know that recovery attempts at a very low altitude are quite unlikely to succeed. The cockpit calculus changes in exactly the way that BB (and most all us) desires to reduce the occurence of spin-in accidents..
Steve, I don't think that addresses John's issue, and certainly not mine. Once a guy has landed out, he's taken a big points hit. This would reward even lower circling, hoping that you would get away and not be subject to scrutiny and a penalty. If you make the save at 200', you've saved the day and your contest position and are not subject to your proposed penalty. The more prudent pilot that stopped at 800' and landed, did neither and is punished for it.
Old January 28th 18, 11:34 PM posted to rec.aviation.soaring
Default Hard Deck
If the CD already has authority here, then could this be a process to use it?
It counts as landing to fly anywhere at less than X feet AGL without having enough speed to pull up to X feet and be above Y airspeed. (X = 500 feet, Y=60Knots, with a simple chart for the pullup?) The goal being to limit low thermaling and low and slow passes across ridges but still allow flight near terrain.
When you publish the IGC, you also have to publish your landing plan for the whole flight. (For each part of the flight, the area you planned to land and how you were going to get there with energy you had (as opposed to hoped to get) when you committed to that option.) Any pilot can ask for clarification on this and the CD can then access penalties.
In addition, experiment with an occasional safety SUA for specific issues.
The Melting Deck Plates Muddle - V-22 on LHD deck.... Mike Naval Aviation 79 December 14th 09 06:00 PM
hard wax application Tuno Soaring 20 April 24th 08 03:04 PM
winter is hard. Bruce Greef Soaring 2 July 3rd 06 06:31 AM
It ain't that hard Gregg Ballou Soaring 8 March 23rd 05 01:18 AM
Who says flying is hard? Roger Long Piloting 9 November 1st 04 08:57 PM
