Hard Deck
Old January 29th 18, 11:32 PM posted to rec.aviation.soaring
Ron Gleason
Default Hard Deck
On Monday, 29 January 2018 16:04:43 UTC-7, Steve Koerner wrote:
On Monday, January 29, 2018 at 1:49:35 PM UTC-7, Andy Blackburn wrote:
I sort of had a different version on all of this.
Let the scoring program calculate and flag any circling flight below XXX feet AGL. At that altitude the default is you get a 100 point penalty and at 80% of XXX' the default penalty is a landout. The pilot who gets flagged may then go to the CD and make his/her case for why his flying was safe because he was: 1) circling over high ground or 2) in a pattern for a good field landing into the wind or uphill and had arrived at an altitude to properly scout the landing. These things don't happen that often so I don't see a big burden for CDs and if the goal is to not give points benefits to deliberately irresponsible behavior, maybe that would do it. No SUA files, just use good judgement. If you did a low save off the downwind to base turn on approach to a beautiful field - good job! If you made a set of terrible choices and did a best L/D glide to a downwind straight-in to a terrible field and scraped one off the trees next to the high-tension wires, maybe you don't get the passing grade.
Just an idea. I'm sure it's fatally flawed in some way to someone.
Andy Blackburn
9B
You're wanting to penalize folks based on an unreferenced altimeter? I'd engineered a way to avoid that problem -- that is by sampling examination of only those competitors that ended up landing out (and are thereby locally referenced). That makes it so that you are able to have XXX be a tighter measure that isn't wasting altitude and actually correlates exactly with what your eyeball had said about AGL height. By my proposal there is no need to ever have concern about how your altimeter has been impacted by temperature or weather change or location. I think the use of sampling examination would be just as effective in motivating better pilotage in the area of dangerously low saves.
Your proposal requires software. My proposal can be implemented this year by any CD who chooses to do so; the rules and software are in place.
I prefer no altitude be wasted to altimeter uncertainty because that has the ultimate effect of wasting airspace thus impinging on my aviating freewill if I end up having to monitor the instruments and land from a higher altitude than I would otherwise. The measurement uncertainty also will create a problem in the mind of the CD who is assessing the penalty: "Gee sir, I'm sure I wasn't that low, I think the pressure must have been higher out to the east."
I personally do not like the hard deck idea, let pilots be pilots and compete the way they desire.
Many ideas have been made; let the scorer examine the logs, ask the CD to determine a hard deck for some area of the task, let the organizers define and create SUA file(s) for tasking are, the scoring program can etc.
I ask everyone to keep in mind that one reason the number of contests and contest sites are dwindling is that the qualified people required to organize, manage and run the contest is also dwindling or burned out. Everyone involved with a making a contest happen is over burdened, under paid and are volunteers (few exceptions I am sure). If you want new rules, guidelines, use of technology etc please make sure it is simple, automated and does not place more burdens on the contest organizers. Better yet, step aside from flying and organize and run a contest!
Ron Gleason
Sorry 9B, had to.
The Melting Deck Plates Muddle - V-22 on LHD deck.... Mike Naval Aviation 79 December 14th 09 06:00 PM
hard wax application Tuno Soaring 20 April 24th 08 03:04 PM
winter is hard. Bruce Greef Soaring 2 July 3rd 06 06:31 AM
It ain't that hard Gregg Ballou Soaring 8 March 23rd 05 01:18 AM
Who says flying is hard? Roger Long Piloting 9 November 1st 04 08:57 PM
