![]() As an LX dealer - I'll comment on a couple of the LX features as I have limited experience with ClearNav. To me the difference is the same as Windows vs Mac, some people just like one better than the other although they both do the same thing. "glide amoeba" - the LX computers also have this feature, but I find that it overly clutters the screen so I don't use it. Instead, much like SeeYou Mobile the LX system colourizes the labels for landable points within glide.. Green label if you can get there with your current MacCready setting, yellow if you can get there at MC 0 and no colour if you can't get there. (all of this taking into account your pre-programmed reserve altitude) AAT calculations - the LX has two features to help with AAT decisions. The first is a set of isospeed lines inside the AAT zone (lines of constant task speed) If you fly parallel to these lines you are not gaining extra speed, you need to fly perpendicular to them. This helps you decide which direction to fly inside the zone The second is an undertime/overtime colouring of the zone. There is a red section and a blue section inside the zone. If you turn while in the blue you will be undertime based on the currently estimated task speed. If you turn in the red area you will be overtime. If you turn at the dividing line between the two colours you will be "on time". |
Get an S100 and hook it up to an Android tablet with XCSoar over Bluetooth. No need to spend several thousands of dollars on sub-optimal software.
On Wednesday, January 31, 2018 at 6:07:50 PM UTC-8, Dave Springford wrote: As an LX dealer - I'll comment on a couple of the LX features as I have limited experience with ClearNav. To me the difference is the same as Windows vs Mac, some people just like one better than the other although they both do the same thing. "glide amoeba" - the LX computers also have this feature, but I find that it overly clutters the screen so I don't use it. Instead, much like SeeYou Mobile the LX system colourizes the labels for landable points within glide. Green label if you can get there with your current MacCready setting, yellow if you can get there at MC 0 and no colour if you can't get there. (all of this taking into account your pre-programmed reserve altitude) AAT calculations - the LX has two features to help with AAT decisions. The first is a set of isospeed lines inside the AAT zone (lines of constant task speed) If you fly parallel to these lines you are not gaining extra speed, you need to fly perpendicular to them. This helps you decide which direction to fly inside the zone The second is an undertime/overtime colouring of the zone. There is a red section and a blue section inside the zone. If you turn while in the blue you will be undertime based on the currently estimated task speed. If you turn in the red area you will be overtime. If you turn at the dividing line between the two colours you will be "on time". |
I am a big fan of the simplicity of the clearnav.
I work a lot so when I can finally take a day off to go flying, I do not want to have to relearn a flight computer, I believe the clearnav is the most simplistic instrument that gives me all the info I need. |
For me, with an LX 9000, effectively having 3 glide computers in the one instrument is a very major plus point that I had not appreciated before I got it. I have one navigating the task, the airfield one normally set for the home airfeld but I may switch to other another airfield from the LX Nav database if appropriate in flight, and the waypoint navigation page I sometimes use as a "what if" or use it to navigate towards a waypoint that steers me to avoid airspace.
As for complexity, I have long established preferences about what information I want to see on a page and how I want it displayed so after a few "fun" hours using LX Styler at home I have a profile which for me is completely simple to use yet flexible when needed. |
New LXNAV Wi-Fi Module | Paul Remde | Soaring | 13 | February 28th 18 03:34 AM |
LXNAV V7 and WinPilot Pro | [email protected] | Soaring | 6 | November 14th 13 03:35 PM |
F.S. LxNav V3 variometer | Nick Kennedy | Soaring | 1 | November 13th 13 05:00 AM |
LXNAV Flarmview | [email protected] | Soaring | 2 | September 29th 13 01:47 AM |
LXNAV V7 | Paul Remde | Soaring | 2 | November 2nd 11 12:31 AM |
