I tried that with XCSoar without success.Â* I finally bought a second k6
unit and then, using two comm ports on my Android device, was able to connect both.Â* When I upgraded to ClearNav II, I used RJ45 splitters and built cables so that I could run XCSoar on the right side of my Stemme and ClearNav on the left. There are hardware solutions available, e.g., THIS https://www.sparkfun.com/products/retired/10748 and/or THIS https://www.amazon.com/KEDSUM-Arduino-Bluetooth-Wireless-Transceiver/dp/B0093XAV4U/ref=sr_1_4?ie=UTF8&qid=1518378376&sr=8-4&keywords=bluetooth+serial or similar.Â* Build your own cables and you should be good to go. Good luck! On 2/11/2018 11:31 AM, Dan S wrote: Does anyone know how to set up lk8000 to accept FLARM data via a K6 BT2 box? I have my vario sending data to LK8000 but can't figure out to get the flarm data. My flarm classic's aux output is connected to the second port on the K6 bt2 box but there are no obvious settings for flarm in LK that I can see. Ant help is appreciated. Thanks. -- Dan, 5J |
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie | Michael Marshall[_2_] | Soaring | 3 | April 10th 16 04:13 AM |
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie | Michael Marshall[_2_] | Soaring | 0 | April 8th 16 08:57 PM |
Information for all users of Flarm, OEM FLARM supplier and Flarm PowerFlarm | [email protected] | Soaring | 28 | March 12th 16 04:31 AM |
Flarm IGC files on non-IGC certified Flarm? | Movses | Soaring | 21 | March 16th 15 09:59 PM |
Avier with LK8000 | Guy B | Soaring | 5 | July 23rd 13 11:04 AM |
