New Glider Dream Elon Musk Flow
Old February 13th 18, 01:44 AM posted to rec.aviation.soaring
Tony[_5_]
Default New Glider Dream Elon Musk Flow
You mean the tethers that keep deck lids, fenders, and the like from flying into the crowd?
Probably not needed in typical Sailplane crashes...
Old February 13th 18, 04:07 AM posted to rec.aviation.soaring
Jonathan St. Cloud
No, and spectra is way too expensive to use for deck lids, fenders... It is in a lay up.
Old February 13th 18, 04:40 AM posted to rec.aviation.soaring
WB
Spectra is a brand name for aramid fibers better know by another name: kevlar. I believe kevlar is used in the cockpits of the "safety cockpit" Schleicher gliders and probably others. A mix of carbon/kevlar seems to be common in the seatpans of new gliders these days.
Old February 13th 18, 04:52 AM posted to rec.aviation.soaring
Jonathan St. Cloud
Interesting, as in sailing we have kevlar sails, but spectra lines.
Old February 13th 18, 01:19 PM posted to rec.aviation.soaring
Kiwi User
Yes, and that 'Spectra' is a high density polyethylene, not aramid. I
used to use it as towline for F1A free flight competition models.
About 3-4 years ago my gliding club started to use it on our winches. Its
much better than steel cable: less stretch/energy storage and light
enough that two people can easily pull the end back to the launch point
if a launch was abandoned during the ground run.
Old February 13th 18, 05:56 AM posted to rec.aviation.soaring
Mike C
Spectra is a polyethylene material. Kevlar is an aramid.
Mike
Old February 13th 18, 02:07 PM posted to rec.aviation.soaring
WB
Doh! Sorry, brain fade on my part. Yes, spectra is poly, not aramid. Sorry.
Old February 13th 18, 10:59 AM posted to rec.aviation.soaring
krasw
tiistai 13. helmikuuta 2018 6.40.38 UTC+2 WB kirjoitti:
Carbon shatters to (sharp) pieces, with wowen kevlar fibers in fabric the structure does not completely disappear around you in case of crash. AFAIK carbon itself is stronger fibre that kevlar. I think most flaps and ailerons are made of 100% kevlar, though not sure why. Maybe it's lighter than carbon and still strong enough?
Old February 13th 18, 01:22 PM posted to rec.aviation.soaring
Kiwi User
I don't know whether its lighter than carbon, but its easier to get
lighter weight kevlar fabric than carbon (35 gsm vs 80gsm). Horrible
stuff to work with, though.
Old February 13th 18, 08:20 PM posted to rec.aviation.soaring
Bob Kuykendall
It's all about making a control surface that is limber enough in bending so it can deflect up and down while hinged to a bent wing, while still having enough torsional stiffness to transmit motion while resisting flutter.
Think about an early ASW20 at 2g, with the wings bent up about 1.5m. Now imagine deflecting the flaperons up on the left side and down on the right side (left stick). Because the wings and the flaperon hinge path are curved, the left flaperon trailing edge is being shortened as if the surface is being bent aft at the tip. On the right side, the trailing edge is being stretched as if the surface is being bent forward at the tip.
With the flaperons made of carbon, the result would be a control surface so stiff in bending that at any appreciable load factor the stick would spring to the center and resist flaperon deflection. This could be quite dangerous, because for example it would resist the leveling of wings while in a spiral dive.
Waibel's team at Schleicher appears to have tried several construction methods for the ASW20 flaperons before settling on sandwich construction with skins made with 2oz Kevlar on each side of Rohacell core foam. They also refined the design of the trailing edge joint so that it required a minimum of bonding paste, which helps keep the bending stiffness to a minimum. This was just one of a huge series of detail refinements required to go from a design to a functional product.
If you come to one of our Akaflieg sessions (next one is probably in late March) I'll show you all of the complexities that go into making effective flaperons.
--Bob K.
Bob Kuykendall
www.hpaircraft.com
https://www.facebook.com/HP-24-Kit-S...e-200931354951
I have a dream. A GPS/SBAS/QZSS dream ! In honour of MLK day. macpacheco Instrument Flight Rules 2 January 19th 11 12:39 AM
A Dream franck jeamourra Piloting 0 March 27th 04 07:43 PM
A dream franck jeamourra Simulators 0 March 25th 04 12:26 PM
a dream franck jeamourra Military Aviation 0 March 25th 04 06:27 AM
a dream franck jeamourra Owning 0 March 25th 04 06:26 AM
