Minimum number of flights for winch sign off?
Old February 14th 18, 05:45 AM posted to rec.aviation.soaring
Frank Whiteley
Default Minimum number of flights for winch sign off?
On Tuesday, February 13, 2018 at 8:42:33 PM UTC-7, b4soaring wrote:
On Tuesday, 13 February 2018 14:53:27 UTC, Waveguru wrote:
What would be the consensus for the minimum number of flights to get a ground launch sign off for an experienced glider pilot? How many cable breaks and at what altitude? Of course it would take more for some and less for others, but I would think at least 15 launches with 5 cable breaks at various heights?
Boggs
Basic principles of instruction:
-- ground briefing
-- instructor demonstration
-- student attempt
Winch launch failure instruction:
-- full climb, low level, land ahead
-- full climb, higher up, can't land ahead
-- full climb, random height, gradual power failure
That's a minimum of 6 launch failures. Where I'm from we also do an initial climb launch failure (pre full climb), instructor demo only (more training accidents than real accidents.) So that's an absolute minimum of 7 instructional launch failures.
The good news is that winch launching is really easy, easier than aerotowing. A competent pilot will learn to winch launch in 4 or 5 flights, so your 15 launch suggestion is do-able, but I would include more launch failures.. For ab initio training we do a lot more launch failures before and after solo, just to reinforce the "expect a launch failure every launch" mindset.
Currency is very important. The shape of the airfield will also affect safety, a nice big round grass airfield will be very different to a commercial airfield.
I PM'D Gary at first. I agree with the above, though I would suggest that about 20 is the right number. Before emergencies, 5-6 'normal' launches so that the pilot understands what they are trying to achieve consistently. Then work on the 'breaks' and post break options and gotchas. Then a few more consistency checks and speed up, slow down signalling. Wing rock is deprecated. These exercises also keep winch drivers on their toes. I can often tell from the winch who is flying the two-seaters by the way they rotate and their climb attitude to 400-500 feet.
Frank Whiteley
Old February 14th 18, 07:03 AM posted to rec.aviation.soaring
Frank Whiteley
Boggs
-- ground briefing
-- student attempt
The good news is that winch launching is really easy, easier than aerotowing. A competent pilot will learn to winch launch in 4 or 5 flights, so your 15 launch suggestion is do-able, but I would include more launch failures. For ab initio training we do a lot more launch failures before and after solo, just to reinforce the "expect a launch failure every launch" mindset.
Old February 14th 18, 07:06 AM posted to rec.aviation.soaring
Frank Whiteley
Boggs
-- ground briefing
-- student attempt
Frank Whiteley
Club syllabus. Needs some minor revision. We used flags but now use airband radios on our licensed frequency.
http://www.soarcsa.org/index.php?page=training Documents.
http://www.soarcsa.org/uploads/file/...ngSyllabus.pdf
http://www.soarcsa.org/index.php?page=winch-operations
You are welcome to borrow, adapt, or critique any of the above.
Frank Whiteley
Winch procedures manual referred to above.
http://www.soarcsa.org/uploads/file/...inchManual.pdf
The number of registered drone operators exceeds the number of manned aircraft pilots Larry Dighera Piloting 3 July 14th 16 09:41 PM
Average number of flights to solo for ab-initio students? Frank Paynter[_2_] Soaring 18 January 30th 12 01:54 PM
Best winch metrics - what is the best winch operationally? Bruce Soaring 19 July 19th 09 11:45 AM
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? Bill Daniels Soaring 20 December 27th 04 12:33 AM
Pitts Number 1 registration number Mirco Aerobatics 3 December 4th 04 11:50 AM
