New Glider Dream Elon Musk Flow
Old February 15th 18, 08:18 PM posted to rec.aviation.soaring
Kiwi User
Default New Glider Dream Elon Musk Flow
On Thu, 15 Feb 2018 05:36:39 -0800, ND wrote:
On Wednesday, February 14, 2018 at 6:19:48 PM UTC-5, WB wrote:
On Wednesday, February 14, 2018 at 2:01:41 PM UTC-6, Kiwi User wrote:
On Wed, 14 Feb 2018 11:06:11 -0800, ND wrote:
speaking of cars... this is a little nuts, but, airbags? i've
always thought that during a crash, you probably smack the **** out
of your head.
Airbags shouldn't be necessary provided that your straps are tight
and the anchor points don't pop off the hull, though your chin may
hit your chest quite hard. The stick is be short enough that your
head won't hit it and the shoulder + lap straps will stop your head
hitting the panel
Martin | martin at Gregorie | gregorie dot org
That's assuming a straight ahead impact. A friend was killed when his
glider impacted in a yawed orientating (spin). The side of his head hit
the canopy rail hard enough to kill him. It would have taken side
airbags to have protected him, or a helmet.
side airbags is basically what i was thinking, to protect your head
during a yawing or side impact. like if you were going into a ridge,
caught a wingtip first, and impacted sideways.
I'd have thought that the tip would catch, causing the glider to pivot
round it through almost 90 degrees, putting the fuselage into the ridge
nose-first. Have I got that wrong?
Martin | martin at
Old February 15th 18, 09:38 PM posted to rec.aviation.soaring
ND
of your head.
hitting the panel
Martin | martin at
yeah, it's not going to pivot on the wingtip and hit nose first. it IS going to pivot. but would probably pivot, stall, and begin to fall all while travelling sideways. the nose may be the first to touch the ground but i think the major force of the impact would be in a sideways direction, relative to the pilot.
i think you'll agree that it wouldn't be a horrible thing to have airbags deploy around the pilots head in this situation (i realize its not him catching a wingtip) :
https://www.youtube.com/watch?v=4nsXL72S9OA
Old February 15th 18, 10:58 PM posted to rec.aviation.soaring
Kiwi User
out of your head.
head hitting the panel
his glider impacted in a yawed orientating (spin). The side of his
head hit the canopy rail hard enough to kill him. It would have
taken side airbags to have protected him, or a helmet.
I don't think you can tell a lot from that: it looks more like low speed
stall-spin onto the top of a wide spur. I can just about read the ASI,
which looks to be reading in the low 30s and the yaw string also appears
to show low speed judging by the way it first flaps about, followed by a
slip toward the low wing as the spin develops.
In the ridge-running scenario we were talking about the glider should be
flying a lot faster to keep the glider responsive. I don't go near the
hill at less than 55kts in my Libelle. Catching a tip would whip the
glider round pretty fast and, if the slope is covered in scrubby stuff
the tip isn't going to pull free. Of course, if your tip touches smooth
rock, then things are rather different but thats a situation I've never
flown in. My ridge running experience, apart from one flight in a DG-1000
at Omarama, has been under 3000 ft along grass or heather-covered ridges.
In the conditions I think I understand airbags might help, but then
again, they might not. Further, consider that a glider cockpit is a very
small volume to trigger and explosive inflation in, so that could be very
harmful by itself. Think of eardrums getting ruptured.
Martin | martin at
Old February 16th 18, 01:53 AM posted to rec.aviation.soaring
Paul Agnew
Amsafe.com
Airbag seatbelts for general aviation and airlines. They already have some pretty innovative solutions. Unlike your car, these don't explode in your face. And, before you ask, there has never been an inadvertent deployment, but they have had some incredible saves - including the notorious airplane thief, the Barefoot Bandit.
I helped write my airline's MEL for our Amsafe seatbelts and the tech is solid. The slow-motion videos are amazing to watch.
Paul A.
Old February 16th 18, 09:08 PM posted to rec.aviation.soaring
WB
On Thursday, February 15, 2018 at 7:53:55 PM UTC-6, Paul Agnew wrote:
Amsafe.com
Paul A.
I'm surprised that airbag seatbelts haven't shown up in cars. Seems they would reduce some of the problems with airbags deploying into one's face. For gliders, maybe an airbag system to protect feet and lower legs. Those safety cockpits are great, but feet and lower legs are still in the crumple zone.
I have a dream. A GPS/SBAS/QZSS dream ! In honour of MLK day. macpacheco Instrument Flight Rules 2 January 19th 11 12:39 AM
A Dream franck jeamourra Piloting 0 March 27th 04 07:43 PM
A dream franck jeamourra Simulators 0 March 25th 04 12:26 PM
a dream franck jeamourra Military Aviation 0 March 25th 04 06:27 AM
a dream franck jeamourra Owning 0 March 25th 04 06:26 AM
