The typical designed probe is designed to point up which gives the intended angle to the airflow and also keeps the tip high and as close to the line of the tailplane. See Rudy Brozel's articles.
Another quite common factor is to avoid the down pointing probe interfering with a fin pitot which is often close below. Dick Johnson tested this and showed that there was significant interference. |
Prandtl multi probe receptacle used for TE only? | Matt Herron Jr. | Soaring | 12 | February 15th 18 08:32 PM |
Proper Std. Cirrus class | Jacopo Romei | Soaring | 4 | January 9th 17 07:57 PM |
I will be insert usenet | Mark | Piloting | 2 | October 10th 10 12:32 PM |
Multi - probe | KP | Soaring | 1 | March 7th 05 06:03 PM |
