On Saturday, February 24, 2018 at 8:19:50 PM UTC-5, jfitch wrote:
On Saturday, February 24, 2018 at 5:15:26 PM UTC-8, jfitch wrote: I tried updating my PowerFlarm to 6.42, expires in 11/19. It has 6.40 now, expires 2/19. It persistently does not update. The log file says it found the firmware file, confirmed its applicability, copies it to memory. But subsequently it comes up reporting 6.40, expiring 2/19. It also reports this to other things it talks to. Anybody having this problem, and any suggestions? There do seem to be some unexplained lines in the log: 00014.420 INFO Initiating non-interactive firmware update: force_adsb=0, force_pf=0... 00014.421 INFO Minimum F/W version for this device: 2.10 00014.454 INFO Found .FW file: PF_6_4~1.FW, 2 entry/entries 00014.454 INFO FW entry: Device=flarm2, version=6.4.2, Extended=DeviceName=PowerFLARM;TruncPartNo=C11A,C1 1E,D11A,D11E,C10A,C10E,D10E,P23E,P24E,P24A,Q24E,D1 0A;ADSBFwVer=0.31 00014.464 INFO Checking for applicability... 00014.464 INFO New candidate version: 6.42 00017.950 INFO FW entry: Device=ADS-B, version=0.31, Extended=bla 00017.950 INFO Checking for applicability... 00017.951 INFO Unsuitable device: ADS-B, skipping 00017.972 INFO Found .FW file: _PF_6_~1.FW, 0 entry/entries 00017.975 INFO No more files to check 00017.975 INFO Found .FW with highest version number 6.42 in file PF_6_4~1.FW 00017.976 INFO ADS-B: current: 0.31, required: 0.31 00017.982 INFO Bytes requested/free on internal FS: 531k/1866k 00017.989 INFO Copying PF firmware from PF_6_4~1.FW... 00018.425 INFO Allowing drivers to catch up... 00018.426 INFO Done. 00018.427 INFO ADS-B: No update necessary 00018.427 INFO Renaming FW temp file 00018.430 INFO Firmware update prepared, good to restart! 00018.430 INFO Allowing drivers to catch up... Decides one file isn't applicable but another is? I assume your flarmcfg.txt file is correct and came from the factory updater. |
![]() I assume your flarmcfg.txt file is correct and came from the factory updater. I have had luck with 3 things when the update is finicky; first, while off, disconnect any display or anything but power. Run the update, turn it off, connect the display, restart. If that doesn't work, rename the file pf3.42.fw and try that. As a final thing, you can do a factory reset - complete wipe. Make a flarmcfg.txt file with one line: $PFLAC,S,DEF then put it as the only file at the top level of the usb device. Update. Run that, then put your normal stick in. Run that. I do about 8 PFs for my glider and the club and friends. I now, as annual maintenance, do a factory reset annually. It seems that things can get corrupt. Starting fresh works well and hasn't failed for me yet (thanks Luke for the advice on this). Final thought - any time I have something fail on update, I destroy that USB stick. USB memory is memory that didn't make it in the big leagues (DRAM). Usually, you have no problem. I don't trust something that should work but didn't (particularly if it is old). Especially when finishing Diamond Badge and Diplomes. A stick is cheap. Dan I also assume your USB device is 2.0; 3.0 can be a problem. Tom's Hardware also has a program called Check Flash you can google for to check your USB sticks. Free. |
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie | Michael Marshall[_2_] | Soaring | 3 | April 10th 16 04:13 AM |
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie | Michael Marshall[_2_] | Soaring | 0 | April 8th 16 08:57 PM |
Information for all users of Flarm, OEM FLARM supplier and Flarm PowerFlarm | [email protected] | Soaring | 28 | March 12th 16 04:31 AM |
OLC Not Updating | [email protected] | Soaring | 4 | October 14th 10 11:04 PM |
Updating B-100 | Paul M. Cordell | Soaring | 2 | November 12th 04 02:10 AM |
