maanantai 26. helmikuuta 2018 21.12.23 UTC+2 Darryl Ramm kirjoitti:
Name one where it is not. Sorry but with "light test" you have no clue of the turtle deck material. Why an earth would factories go trough massive pain and expense of laying up turtledeck using different material instead of just rolling up carbon/kevlar? Instruments and their antennas tend to reside in the instrument panel. Routing GPS antennas to behind pilots back, who does this, and why would factories be interested in this? Please give some reference to glass turtledeck in carbon fuselage, anything will do. RF transparence is different thing, antenna on the hat shelf sees sky trough canopy as I stated earlier. |
On Monday, February 26, 2018 at 12:07:49 PM UTC-8, krasw wrote:
Sorry but with "light test" you have no clue of the turtle deck material. Dude, chill. They're trying to talk sense for ya. * Radio waves and light are both electromagnetic radiation; the only difference between them is frequency. If light goes in through the turtledeck structure, then radio waves will almost certainly to in and out as well. * It doesn't matter if the turtledeck is fiberglass or Kevlar (aramid) or basalt fiber. If light goes through it, so will radio waves. Light doesn't go through carbon or aluminum, and neither does radio waves. BTW that's one of the reasons UV-curing vinylester resins are kind of a dead-end, they won't play nice with carbon. Someday there might be x-ray-curing vinynlesters, though, so hang on to your lead apron. * When I designed the HP-24 fuselage, I surveyed the field and found that many if not most manufacturers were using radio transparent fiberglass for the portion over the wing, and I did the same. I also made the rudder out of Kevlar, and developed a tuned dipole com antenna that is a standard part of the rudder kit. * I specifically decided not to develop an internal transponder antenna for the rudder or fuselage; for that I recommend an external blade antenna. I have on my to-do list the development of a flush 1090 mHz slot antenna, but it's pretty far down the list. --Bob K. |
maanantai 26. helmikuuta 2018 21.12.23 UTC+2 Darryl Ramm kirjoitti: Name one where it is not. Sorry but with "light test" you have no clue of the turtle deck material. Why an earth would factories go trough massive pain and expense of laying up turtledeck using different material instead of just rolling up carbon/kevlar? Instruments and their antennas tend to reside in the instrument panel.. Routing GPS antennas to behind pilots back, who does this, and why would factories be interested in this? Please give some reference to glass turtledeck in carbon fuselage, anything will do. RF transparence is different thing, antenna on the hat shelf sees sky trough canopy as I stated earlier. An ASH26E has an all carbon fuselage but a fiberglass turtle deck. As does every other AS glider I have ever seen (20, 24, 25, 29, 31, etc.). Every Ventus and Discus I have ever seen has a fiberglass turtle deck. Ditto every DG and Lak. Rather, please point to a composite glider that does not. In a Pilatus, Schweizer, or Blanik you will have some trouble as they are aluminum. |
tiistai 27. helmikuuta 2018 8.33.22 UTC+2 jfitch kirjoitti:
An ASH26E has an all carbon fuselage but a fiberglass turtle deck. As does every other AS glider I have ever seen (20, 24, 25, 29, 31, etc.). Every Ventus and Discus I have ever seen has a fiberglass turtle deck. Ditto every DG and Lak. No they don't. I've maintained and repaired a bunch of gliders you mention and I'm familiar with their structure. I've been to LAK factory seeing them lay-up parts. Here is a link to fuselage lay up showing full carbon lay-ups with glass at the tail for antenna: https://photos.app.goo.gl/icyQoCCntLEBb8TI2 Your list includes gliders that have all-glass-fuselage BTW. Just calling BS, for the last time now. |
An ASH26E has an all carbon fuselage but a fiberglass turtle deck. As does every other AS glider I have ever seen (20, 24, 25, 29, 31, etc.). Every Ventus and Discus I have ever seen has a fiberglass turtle deck. Ditto every DG and Lak. Rather, please point to a composite glider that does not. In a Pilatus, Schweizer, or Blanik you will have some trouble as they are aluminum. Here is few photos from LAK factory, fuselage and tail lay-up (glass around antenna in tail): https://imgur.com/a/NoHcw Your list includes gliders with all-glass fuselage which is bit confusing. Just calling BS, for the last time. |
Le mardi 27 février 2018 11:46:42 UTC+1, krasw a écritÂ*:
list includes gliders with all-glass fuselage which is bit confusing. Just calling BS, for the last time. From the Schleicher homepage https://www.alexander-schleicher.de/werk/mitarbeiter/ Photos #1 and #10 show the glass part of the turtle deck. |
Chicago Area Glider Seminar Feb 16 | JohnDeRosa | Soaring | 7 | February 12th 13 02:17 PM |
The Arrivals Level / Baggage Claim Area YWG | Canuck[_10_] | Aviation Photos | 2 | November 13th 11 03:23 PM |
Glider location near the beach? | SF | Soaring | 21 | January 16th 09 10:54 PM |
Glider location near the beach? | Nyal Williams[_2_] | Soaring | 0 | January 15th 09 07:00 PM |
RV-7a baggage area | David Smith | Home Built | 32 | December 15th 03 04:08 AM |
