FSG71M question
Old February 27th 18, 01:10 AM posted to rec.aviation.soaring
AS
Default FSG71M question
Does someone know how to change the memory battery of a FSG71M radio? There seems to be an upper and lower cover on it, each held on by four (4) screws. Is the battery hiding under one of those?
Also, what battery type is it? Is it a type that is freely available or is it a super-special one?
Thanks,
Uli
Old February 27th 18, 02:41 AM posted to rec.aviation.soaring
Roy B.
Uli:
If you search for the post "Dittel radio servicing" you will see entries from several guys who did it.
ROY
Old February 27th 18, 12:59 PM posted to rec.aviation.soaring
AS
On Monday, February 26, 2018 at 9:41:44 PM UTC-5, Roy B. wrote:
Uli:
ROY
Thanks, Roy!
Contact info '3U' - Dittel FSG71M Morten Bach Soaring 1 February 24th 13 07:30 PM
Memory battery for Dittle FSG71M Ray Gimmey Soaring 14 December 29th 06 12:13 PM
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
