On Tuesday, February 27, 2018 at 10:16:48 AM UTC+10:30, Roy B. wrote:
Jonathan: I used the WiFi module my last time in South Africa. The initial set up is more than a little tedious as you have to put in your email address, password(s), OLC password etc. into the LX - all in a hunt & peck input method.. If you could do it on LX Styler (the LX PC program) and then import it into the module that would be great - but I am not sure that is doable. Paul Remde could comment on that. Once installed correctly (it took several tries) the module does what it says it will do and it will upload your flight to OLC or to your phone via hotspot. But honestly it all struck me as a bit of a "solution in search of a problem". It is just not that hard to download a flight to an SD card or USB and then upload it (or give it to the scorer) and frequently it is very helpful to review your flight log before you upload it to OLC -especially if you fly in different configurations (15m and 18m) as it is easy to forget to reset the configuration in the LX. There are further comments about complexity vs simplicity in the ClearNav vs LX 9000 discussion elsewhere. ROY It's just the first step to enabling new technologies. Already you can download weather forecasts (from SkySight) and see a live updating rain radar via the Wifi module too. I hope next comes a 3G module so you don't even need to tether. |
I have it in an Arcus and use it to email flights and update firmware - both of which it does very easily. The rear seat unit has to have the firmware updated in the old fashioned way.
I do not use it for weather. I generally have my phone in flight mode while flying. I think you only get a phone signal when you are uncomfortably low in the UK. |
On Tue, 27 Feb 2018 02:59:09 -0800, waremark wrote:
I think you only get a phone signal when you are uncomfortably low in the UK. Confirmed: I remember sitting smack over the centre of Huntingdon at 3000ft on a really nice, calm weekday. I was circling by myself in a weak thermal, so I Hauled out a phone to let a friend hear the vario at work but got no signal. At all. Most of England is so flat that there's no need for more than horizontal RF coverage at or below the top of the cell antenna. -- Martin | martin at Gregorie | gregorie dot org |
This seems to be more or less no longer true with 4G. Flying in England last year I observed I had 4G 80-90% of the time using my phone mounted on the canopy. With an antenna that's not in carbon bucket I imagine you'll get it all the time.
On Wednesday, February 28, 2018 at 5:42:12 AM UTC+10:30, Kiwi User wrote: On Tue, 27 Feb 2018 02:59:09 -0800, waremark wrote: I think you only get a phone signal when you are uncomfortably low in the UK. Confirmed: I remember sitting smack over the centre of Huntingdon at 3000ft on a really nice, calm weekday. I was circling by myself in a weak thermal, so I Hauled out a phone to let a friend hear the vario at work but got no signal. At all. Most of England is so flat that there's no need for more than horizontal RF coverage at or below the top of the cell antenna. -- Martin | martin at Gregorie | gregorie dot org |
Can the WiFi module be used with Condor so we can learn to use LX system over the winter?
New LXNAV S8 vario | Paul Remde | Soaring | 5 | October 12th 15 04:14 PM |
LXNAV V7 - Reviews? | David Reitter | Soaring | 10 | October 21st 14 12:41 AM |
LXNAV Flarmview | [email protected] | Soaring | 2 | September 29th 13 01:47 AM |
New vario by LXNAV | [email protected] | Soaring | 6 | May 22nd 13 11:15 PM |
LXNAV V7 | Paul Remde | Soaring | 2 | November 2nd 11 12:31 AM |
