GPS anetenna location OK in baggage area of a fiblerglass glider?
Old February 28th 18, 05:44 AM posted to rec.aviation.soaring
Darryl Ramm
Default GPS anetenna location OK in baggage area of a fiblerglass glider?
On Tuesday, February 27, 2018 at 5:26:55 PM UTC-8, jfitch wrote:
On Tuesday, February 27, 2018 at 4:20:51 PM UTC-8, Matt Herron Jr. wrote:
On Tuesday, February 27, 2018 at 7:16:13 AM UTC-8, Ross wrote:
Not sure how many Discus 2 and Ventus 2 fuses I made, but none of them have a glass turtle deck.
Radio antenna located in the fin which is glass, except the Nimbus 4 where it is located in the rudder.
This however doesn't help your issue
Has anyone tried putting a transponder antenna like the T2glued to the inside the turtle deck? does the antenna require a downward view? 250 watts of RF too close to your head? This would make install on an ASW27 MUCH simpler than a fin or stinger on the outside behind the gear, not to mention more aerodynamic.
Can't you put it in the nose of the 27? I mounted an L2 there on my 26, ahead of the rudder pedals. The nose it also not carbon, it's kevlar and glass. I believe the antenna wants to be vertical for the correct polarization, that might add to the problems putting it in the turtle deck. I have the L2 transponder antenna on one side and the Flarm A on the other, works fine..
I think the '27 is different from the '26 there and does not have the clear spots in the nose.
Chicago Area Glider Seminar Feb 16 JohnDeRosa Soaring 7 February 12th 13 02:17 PM
The Arrivals Level / Baggage Claim Area YWG Canuck[_10_] Aviation Photos 2 November 13th 11 03:23 PM
Glider location near the beach? SF Soaring 21 January 16th 09 10:54 PM
Glider location near the beach? Nyal Williams[_2_] Soaring 0 January 15th 09 07:00 PM
RV-7a baggage area David Smith Home Built 32 December 15th 03 04:08 AM
