WalterM140 wrote:
It would have been quite easy to stop P-38 escorts in 1943, just attack them early, and force them to jettison their external tanks, they were carrying about as much or more fuel externally than internally. It was -shown- that even a few dozen P-38's had a very delerious effect on the tactics of the German day fighters. There's no "it would have been quite easy to..." to it. What you suggest was not a factor. Only because the Germans rarely did so. U.S. fighter commanders were surprised that they didn't try it more often, because it was so obviously a good idea. Indeed, the Luftwaffe had tried to do so for a while, but heavy singl-engine fighter losses (against P-47s) had resulted in an order from either Goring or Schmidt (I forget which) sometime in the late-43 early '44 period (I forget) to cease such attacks and move the fighters back. A bad decision. BTW, ISTR for Geoffrey's info that the early J models were all retrofitted with leading edge tanks either shortly before or shortly after achieving IOC in the ETO. Also P-38 numbers grew from 302 in December 1942 to 567 in May 1943 then declined to 372 in October 1943 before rapidly expanding to 1,063 in April 1944. The numbers are for the USAAF deployed against Germany and include reserves etc. Thanks for the minutia. Not minutia in this case, but very germane, as the lack of P-38 numbers was a factor. Production was very limited at the time. Then there's the extra training time for multi-engine, which would add some additional delay to getting units operational/providing replacement pilots. The point is that Eaker and Hunter, 8th BC and 8th FC CGs respectively could have stressed long range escorts and pushed P-38 enhancements, stressed solving the technical problems, and so forth in 1942. P-38's were available in England in 1942. Eaker and Hunter didn't do that. While Eaker and Hunter were doctrinally blind to the need for far too long, the need for a long-range fighter in the ETO in 1942 was hardly obvious given the shallow penetrations we were making at the time. Arnold ordered Giles to increase the internal fuel of the fighters around June '43 IIRR (don't have the reference, "To Command The Sky" by McFarland and Newton, handy), giving him six months to achieve it. Besides the P-38 was only in the ETO for a couple of months before they were all sent to the Med. I consider one of the great historical "what ifs" to be what if at least some P-38s had remained in the 8th from November 1942 until September '43 (we'd have to assume that P-38 production was sufficient that the 78th FG wouldn't have had its P-38s stripped from it and sent to the Med as attrition replacements, so they weren't forced to transition to the P-47). Would we have been able to fix the P-38's high altitude/cold and wet climate problems prior to the availability of the P-51? As it is, we know from Zemke that turbosupercharger control freeze-up was still an issue in August _1944_ (IIRR he was flying a J-15), despite the problem being identified no later than when the 55th FG had gone operational in mid-October '43. Even assuming that the problems (engines, turbo controls, cockpit heat, dive flaps; the boosted ailerons were a 'nice to have') had been fixed earlier, was it possible to produce enough P-38s in that period to supply the needs of the PTO, MTO _and_ ETO? It seems unlikely, given the relatively low production totals of the P-38 compared to the single-engine a/c, and cost -- both the P-47 and P-38 cost about double the P-51 to build in money, materiel and man-hours; fuel requirements were also about double. Eaker was not the only one and he did ask for long range tanks on his fighters. It is not a simple good guy/bad guy situation. Eaker dawdled on it. It wasn't important to him. Eaker thought the B-17's could defend themselves until very late in the game. He -was- sacked, after all. True. Eaker even suggested that the first Mustang groups go to the 9th AF. He didn't understand the problem. He didn't allow for improvements and reinforcments of the German AF. P-38's of longer range and better reliability could have been provided well before they were. An all P-38 force could have done what a mixed P-47, P-51 and P-38 force DID do-- wreck the German day fighter force. -- if it had been stressed earlier. But it was not. Assuming that the numbers had been available, which seems questionable, but I agree with your basic idea. Now, you'll dispute this of course. I doubt Geoffrey will, as he's been mostly agreeing with you. But the problems the long range escorts gave the Germans rested on this: The Germans had to up-armor and up-arm their single engine fighters and add twin engine bomber destroyers to the mix, in order to kill B-17's in large numbers. -Any- of the three main US fighters on the scene (P-38, P-47, P-51)could have made that up-armoring and use of the twin engine bomber destroyers impractical. Assuming they had the internal fuel capacity, and that took time to get into production and service even after it was given top priority by Arnold. Guy |
Guy Alcala wrote:
WalterM140 wrote: It would have been quite easy to stop P-38 escorts in 1943, just attack them early, and force them to jettison their external tanks, they were carrying about as much or more fuel externally than internally. It was -shown- that even a few dozen P-38's had a very delerious effect on the tactics of the German day fighters. There's no "it would have been quite easy to..." to it. What you suggest was not a factor. Only because the Germans rarely did so. U.S. fighter commanders were surprised that they didn't try it more often, because it was so obviously a good idea. Indeed, the Luftwaffe had tried to do so for a while, but heavy singl-engine fighter losses (against P-47s) had resulted in an order from either Goring or Schmidt (I forget which) sometime in the late-43 early '44 period (I forget) to cease such attacks and move the fighters back. A bad decision. BTW, ISTR for Geoffrey's info that the early J models were all retrofitted with leading edge tanks either shortly before or shortly after achieving IOC in the ETO. Also P-38 numbers grew from 302 in December 1942 to 567 in May 1943 then declined to 372 in October 1943 before rapidly expanding to 1,063 in April 1944. The numbers are for the USAAF deployed against Germany and include reserves etc. Thanks for the minutia. Not minutia in this case, but very germane, as the lack of P-38 numbers was a factor. Production was very limited at the time. Then there's the extra training time for multi-engine, which would add some additional delay to getting units operational/providing replacement pilots. The point is that Eaker and Hunter, 8th BC and 8th FC CGs respectively could have stressed long range escorts and pushed P-38 enhancements, stressed solving the technical problems, and so forth in 1942. P-38's were available in England in 1942. Eaker and Hunter didn't do that. While Eaker and Hunter were doctrinally blind to the need for far too long, the need for a long-range fighter in the ETO in 1942 was hardly obvious given the shallow penetrations we were making at the time. Arnold ordered Giles to increase the internal fuel of the fighters around June '43 IIRR (don't have the reference, "To Command The Sky" by McFarland and Newton, handy), giving him six months to achieve it. Besides the P-38 was only in the ETO for a couple of months before they were all sent to the Med. I consider one of the great historical "what ifs" to be what if at least some P-38s had remained in the 8th from November 1942 until September '43 (we'd have to assume that P-38 production was sufficient that the 78th FG wouldn't have had its P-38s stripped from it and sent to the Med as attrition replacements, so they weren't forced to transition to the P-47). Would we have been able to fix the P-38's high altitude/cold and wet climate problems prior to the availability of the P-51? As it is, we know from Zemke that turbosupercharger control freeze-up was still an issue in August _1944_ (IIRR he was flying a J-15), despite the problem being identified no later than when the 55th FG had gone operational in mid-October '43. Even assuming that the problems (engines, turbo controls, cockpit heat, dive flaps; the boosted ailerons were a 'nice to have') had been fixed earlier, was it possible to produce enough P-38s in that period to supply the needs of the PTO, MTO _and_ ETO? It seems unlikely, given the relatively low production totals of the P-38 compared to the single-engine a/c, and cost -- both the P-47 and P-38 cost about double the P-51 to build in money, materiel and man-hours; fuel requirements were also about double. Given the production totals achieved with other aircraft, the US COULD have ramped up production of the P-38, but the war production board didn't approve second source production until very late (IIRC about 120 P-38s were eventually produced by Vultee-Nash, but likely none of them ever made it to the combat theaters). If the engines had been swapped out for two-stage Merlins, the turbo and early intercooler problems would have been eliminated, at the cost of some fuel efficiency, and Lockheed submitted a proposal for this, although politics prevented this. That the P-38 was developed to US specifications before the war resulted in the Allison engine use, and the US focused on turbosupercharging for inline engines. Of course, at that time, the Merlin didn't have two-stage supercharging either, so the turbo was really the only practical way to go for high altitude performance at the time. The Allies had their share of bad production decisions, but the greater industrial capability tended to make these decisions less than critical to the final outcome and not as noticed in the overall picture. Mike Williamson |
Mike Williamson wrote:
Guy Alcala wrote: snip Even assuming that the problems (engines, turbo controls, cockpit heat, dive flaps; the boosted ailerons were a 'nice to have') had been fixed earlier, was it possible to produce enough P-38s in that period to supply the needs of the PTO, MTO _and_ ETO? It seems unlikely, given the relatively low production totals of the P-38 compared to the single-engine a/c, and cost -- both the P-47 and P-38 cost about double the P-51 to build in money, materiel and man-hours; fuel requirements were also about double. Given the production totals achieved with other aircraft, the US COULD have ramped up production of the P-38, but the war production board didn't approve second source production until very late (IIRC about 120 P-38s were eventually produced by Vultee-Nash, but likely none of them ever made it to the combat theaters). that production could havebeen increased I dont deny. that it could have been increased to the extent posible with the p-51 and to a lesser extent the P-47 seems unlikely, given that the P-38 wasnt originally designed for mass production. I realize that Lockheed had done considerable re-design to improve its mass producibility, but the a/c manhours required are still far higher than a single. The P-47 being an exception, but then Republic never seems to have had management as good as their designers - their a/c were always expensive, heavy and late, but generally excellent. If the engines had been swapped out for two-stage Merlins, the turbo and early intercooler problems would have been eliminated, at the cost of some fuel efficiency, and Lockheed submitted a proposal for this, although politics prevented this. Assuming the Merlin swap would have solved the major problems, it still would have taken considerable time to do. Look how long it took between the Mustang X and the P-51B achieving IOC. That the P-38 was developed to US specifications before the war resulted in the Allison engine use, and the US focused on turbosupercharging for inline engines. Of course, at that time, the Merlin didn't have two-stage supercharging either, so the turbo was really the only practical way to go for high altitude performance at the time. The Allies had their share of bad production decisions, but the greater industrial capability tended to make these decisions less than critical to the final outcome and not as noticed in the overall picture. True, although in this case the lack of sufficient numbers of long-range escorts available earlier was most definitely noticeable. Guy |
May 1943 then declined to 372 in October 1943 before rapidly expanding to 1,063 in April 1944. The numbers are for the USAAF deployed against Germany and include reserves etc. Thanks for the minutia. Not minutia in this case, but very germane, as the lack of P-38 numbers was a factor. Gee, that is -my- point. And the reason they were not there is because Eaker and Hunter didn't stress it. Was it beyond normal human kin in 1942 to devine the fact that the self defending bomber was not going to work, even with the heavy armament, high altitudes, tight formations and toughness of the B-17's and their crews? Maybe so. I am not necessarily blaming Eaker and Hunter, just pointing out the fact that a strong force of P-38's (provided that the technical problems were addressed aggressively) could have been available a year before the pioneer Mustang group arrived. It's also true that some of the B-17 group commanders didn't care much about escorts in the early part of the campaign. All that rendesvouzing made things more complicated, don't you know. But as the Germans realized the threat and acted to meet that threat, the B-17 bomber boxes met their match and were overborne. Production was very limited at the time. Yes, I am providing a what-if. If the guys in England had been screaming for P-38's the production could have been ramped up. Then there's the extra training time for multi-engine, which would add some additional delay to getting units operational/providing replacement pilots. That doesn't seem that big an issue to me. I recently got DVD's with the B-17 and P-38 flight operation films. The B-17 flight ops were relatively simple. And the actor (Arthur Kennedy, who later was the journalist in "Lawrence of Arabia", among many other roles) who was the B-17 instructor pilot tells the trainee -- "you will -never- fly a better bird than this." [paraphrased]. On the other hand, the P-38 film is filled with cautions and 'insert shots' of "turn this handle if this happens" and don't forget to do this "if that happens." The one speaker in the film is the Lockheed chief test pilot. He says some thing like -- "hey, don't worry if you get a runaway propeller, it happens all the time." Whoa. I am not sure when exactly this film came out -- maybe in early in 1944. The very first thing discussed is proper bail-out procedure in the P-38. Don't worry, you won't hit the tail, you'll pass below it. "But don't worry about that -- your job is to make the other guy bail out." I wonder if perhaps ol' crazy George Patton saw this film and modified that line and made it immortal. The point is that Eaker and Hunter, 8th BC and 8th FC CGs respectively could have stressed long range escorts and pushed P-38 enhancements, stressed solving the technical problems, and so forth in 1942. P-38's were available in England in 1942. Eaker and Hunter didn't do that. While Eaker and Hunter were doctrinally blind to the need for far too long, Thats all I am saying, my friend. the need for a long-range fighter in the ETO in 1942 was hardly obvious given the shallow penetrations we were making at the time. It wasn't obvious perhaps. That's why kudos go to those who see beyond the obvious. Arnold ordered Giles to increase the internal fuel of the fighters around June '43 IIRR (don't have the reference, "To Command The Sky" by McFarland and Newton, handy), giving him six months to achieve it. Besides the P-38 was only in the ETO for a couple of months before they were all sent to the Med. Yes, Eaker could have been screaming bloody murder -- "hey, don't take my long range escorts!" But he didn't, for whatever reason. Yes, it might to pure hindsight to blame him for this in 1942. Definitely. But Eaker persisted in supporting the self-defending bomber after 17 August, '43 and even after 14 Oct. '43. Walt |
WalterM140 wrote:
Also P-38 numbers grew from 302 in December 1942 to 567 in May 1943 then declined to 372 in October 1943 before rapidly expanding to 1,063 in April 1944. The numbers are for the USAAF deployed against Germany and include reserves etc. Thanks for the minutia. Not minutia in this case, but very germane, as the lack of P-38 numbers was a factor. Gee, that is -my- point. And the reason they were not there is because Eaker and Hunter didn't stress it. No, the reason they weren't there is because there weren't enough to go around, owing to the need to redesign the a/c for mass production, and a delayed development due to the crash of the prototype. Was it beyond normal human kin in 1942 to devine the fact that the self defending bomber was not going to work, even with the heavy armament, high altitudes, tight formations and toughness of the B-17's and their crews? We're not interested in 'divining' anything, what was needed was empirical evidence, and early British unescorted raids by far more lightly armed, slower twin-engined Wellingtons flying in looser formations at much lower altitudes weren't necessarily indicative of US efforts. As it turns out, they _were_ indicative, but we didn't know that at the time. Maybe so. I am not necessarily blaming Eaker and Hunter, just pointing out the fact that a strong force of P-38's (provided that the technical problems were addressed aggressively) could have been available a year before the pioneer Mustang group arrived. 3 months maybe six months possibly, but a year? I think not. Production was still ramping up, and the P-38 was still suffering from many of the same problems in August 1944 as it had in October '43, 10 months after the 55th achieved IOC in the ETO. It's also true that some of the B-17 group commanders didn't care much about escorts in the early part of the campaign. All that rendesvouzing made things more complicated, don't you know. But as the Germans realized the threat and acted to meet that threat, the B-17 bomber boxes met their match and were overborne. Certainly, and after Aug. 17th 1943 you can make a good case for accusing Eaker of remaining wedded to doctrine over experience. You might even make that case by June 1943 - Arnold had already reached that conclusion. But not in the Fall/Winter of 1942/43. Production was very limited at the time. Yes, I am providing a what-if. If the guys in England had been screaming for P-38's the production could have been ramped up. Everyone in every theater other than the ETO (where there were no P-38s because they were all sent to the MTO) was screaming for more, and yet production was what it was. I very much doubt that more screaming would have increased the pace any more than it was. Then there's the extra training time for multi-engine, which would add some additional delay to getting units operational/providing replacement pilots. That doesn't seem that big an issue to me. It was for P-38 units and replacements, especially those that were originally supposed to get single-engined a/c. Lots of accidents when losing an engine on t/o. snip The point is that Eaker and Hunter, 8th BC and 8th FC CGs respectively could have stressed long range escorts and pushed P-38 enhancements, stressed solving the technical problems, and so forth in 1942. P-38's were available in England in 1942. Eaker and Hunter didn't do that. While Eaker and Hunter were doctrinally blind to the need for far too long, Thats all I am saying, my friend. So far we agree. the need for a long-range fighter in the ETO in 1942 was hardly obvious given the shallow penetrations we were making at the time. It wasn't obvious perhaps. That's why kudos go to those who see beyond the obvious. Arnold ordered Giles to increase the internal fuel of the fighters around June '43 IIRR (don't have the reference, "To Command The Sky" by McFarland and Newton, handy), giving him six months to achieve it. Besides the P-38 was only in the ETO for a couple of months before they were all sent to the Med. Yes, Eaker could have been screaming bloody murder -- "hey, don't take my long range escorts!" But he didn't, for whatever reason. It wouldn't have made the slightest bit of difference if he had. With our focus on the ETO air war and D-Day et. seq., we forget that in 1942 and 1943, the ETO wasn't the highest priority theater - the Med was. the P-38 was consuidered absolutely vital there, so that's where they went. Eaker screamed repeatedly to Arnold about diversions to the MTO reducing the rate of the 8th's buildup throughout 1943; a fat lot of good it did him prior to October or so. And as others have mentioned, the P-38 wasn't all that much more long-ranged than the P-47 at the time. P-38 internal fuel prior to the J with leading edge tanks, was 300 gallons. A P-47D-23 or earlier with somewhat less total power had 305 gallons internal (the D-25 through M had 370 gal.). The P-38 would outclimb it, but the P-47 was faster, so range was fairly close. The P-38's big advantage was that it had large external tanks early, but the 165 gallon tanks weren't pressurized (and never were), so couldn't have been used above 20,000 feet or so in any case, which is where the escorts needed to be. Let's instead postulate that the P-47 got big pressurized external tanks, either a 150 (actual cap. 165 gal.) or 200 gallon for the C/L, or a pair of 108 gallons underwing, in August or September 1943 rather than February/April 1944. Historically, note that despite high priority and the best efforts of Cass Hough and Co. at Bovingdon, the first P-47 mission using drop tanks, the 200 gallon, unpressurized and very draggy ferry tank only half loaded, was only in July 1943, with the 75 gallon (actual cap. 84 gal.) metal pressurized tank becoming available in August 1943, and the 108 gallon paper tank in October IIRR. According to Zemke the 150 gal.C/L tank allowed the 56th to get to the Hanover region, while the twin 108 gallon tanks only increased the radius a bit further (limited by internal fuel for combat and return), but did increase the endurance. Sure, they still can't go all the way to Berlin, but they can sure as hell take the heavies a lot further in and meet them further in as well, decreasing the time the Luftwaffe has to attack them. And the P-47 is a better high altitude escort fighter than the P-38 anddoesnt suffer from all its problems, it just needs bigger fuel tanks (external and then internal, in that order). Yes, it might to pure hindsight to blame him for this in 1942. Definitely. But Eaker persisted in supporting the self-defending bomber after 17 August, '43 and even after 14 Oct. '43. Not after Second Schweinfurt. That made him a convert. Even so, he still made the (apparently) cognitively dissonant decision to give the P-51s to the 9th, but Kepner fixed that, before Doolittle replaced Eaker. It made undoubted sense from a logistic perspective, but none from a tactical perspective. Guy |
around, owing to the need to redesign the a/c for mass production, and a delayed development due to the crash of the prototype. "The production in mid-1940 of 30 P-38's saw signifcant design changes instituted to help mass production. For the first time, the fuselage was split into left and right halves, and the nose section was built up independently. The aft booms also were divided into two pieces with the skins adjusted to accomodate this....The XP-38A was a converted P-38 with pressurization; next production variant was the P38D of late summer 1940. The ever indeasing orders for Lightnings prompted more design changes, both to improve performance and to faciliate mass production." --Warbird Tech Series vol 2, Lockheed P-38 Lightning pp. 22-26 by Frederick A Johnsen Sounds to me like the needed changes were in hand well before 1941, let alone 1942. snip 3 months maybe six months possibly, but a year? I think not. Production was still ramping up, and the P-38 was still suffering from many of the same problems in August 1944 as it had in October '43, 10 months after the 55th achieved IOC in the ETO. That might have been alleviated earlier the generals in England had pushed it. But they did not. It's also true that some of the B-17 group commanders didn't care much about escorts in the early part of the campaign. All that rendesvouzing made things more complicated, don't you know. But as the Germans realized the threat and acted to meet that threat, the B-17 bomber boxes met their match and were overborne. Certainly, and after Aug. 17th 1943 you can make a good case for accusing Eaker of remaining wedded to doctrine over experience. You might even make that case by June 1943 - Arnold had already reached that conclusion. But not in the Fall/Winter of 1942/43. They should have. Production was very limited at the time. Yes, I am providing a what-if. If the guys in England had been screaming for P-38's the production could have been ramped up. Everyone in every theater other than the ETO (where there were no P-38s because they were all sent to the MTO) was screaming for more, and yet production was what it was. Yes, production was what it was. I find it hard to believe it couldn't have been increased. I very much doubt that more screaming would have increased the pace any more than it was. I can't help what you doubt. The 8th AF was the premier USAAF organization in the world. Arnorld was clearly ready to provide anything needed by his close friend Eaker. But Eaker didn't ask for it. Then there's the extra training time for multi-engine, which would add some additional delay to getting units operational/providing replacement pilots. That doesn't seem that big an issue to me. It was for P-38 units and replacements, especially those that were originally supposed to get single-engined a/c. Lots of accidents when losing an engine on t/o. The source I quote above says accidents for P-38's were less for the P-38 than for the P39, P-40 and P47 in 1942. ibid p. 14 Yes, it might to pure hindsight to blame him for this in 1942. Definitely. But Eaker persisted in supporting the self-defending bomber after 17 August, '43 and even after 14 Oct. '43. Not after Second Schweinfurt. That made him a convert. Even so, he still made the (apparently) cognitively dissonant decision to give the P-51s to the 9th, but Kepner fixed that, before Doolittle replaced Eaker. It made undoubted sense from a logistic perspective, but none from a tactical perspective. Guy Second Scheinfurt was late in the game. Walt |
WalterM140 wrote:
No, the reason they weren't there is because there weren't enough to go around, owing to the need to redesign the a/c for mass production, and a delayed development due to the crash of the prototype. "The production in mid-1940 of 30 P-38's saw signifcant design changes instituted to help mass production. For the first time, the fuselage was split into left and right halves, and the nose section was built up independently. The aft booms also were divided into two pieces with the skins adjusted to accomodate this....The XP-38A was a converted P-38 with pressurization; next production variant was the P38D of late summer 1940. The ever indeasing orders for Lightnings prompted more design changes, both to improve performance and to faciliate mass production." --Warbird Tech Series vol 2, Lockheed P-38 Lightning pp. 22-26 by Frederick A Johnsen Sounds to me like the needed changes were in hand well before 1941, let alone 1942. Sure they were in hand, but they also caused a lot of delay, which is why the a/c was so slow in getting into mass production and why the numbers remained so low relatively late. The P-38F, the first full-up combat-capable version was available for combat in August 1942; the first flight was made in January 1939, so roughly 3.5 years elapsed. Even allowing for a fairly leisurely development prior to the war, the P-38's development was unusually prolonged, especially when compared with its single-engined stablemates. And then in 1943 the wing leading edges, turbos, radiators etc. all had to undergo a major redesign to fit leading edge tanks in, then they had to re-tool before they could produce them. snip 3 months maybe six months possibly, but a year? I think not. Production was still ramping up, and the P-38 was still suffering from many of the same problems in August 1944 as it had in October '43, 10 months after the 55th achieved IOC in the ETO. That might have been alleviated earlier the generals in England had pushed it. But they did not. Can't push what you don't know you need, and since they didn't have ANY P-38s in the late fall of 1942, winter, spring or summer of 1943, there was no opportunity for them to work out the bugs. The 1st, 14th and 82nd FGs had all been sent to the MTO, while the 78th had been stripped of a/c to replace losses, and transitioned to the P-47. Sending all the P-38s to the MTO was a decision made well above Eaker's pay grade, and there wasnt anything he could do about it. It's also true that some of the B-17 group commanders didn't care much about escorts in the early part of the campaign. All that rendesvouzing made things more complicated, don't you know. But as the Germans realized the threat and acted to meet that threat, the B-17 bomber boxes met their match and were overborne. Certainly, and after Aug. 17th 1943 you can make a good case for accusing Eaker of remaining wedded to doctrine over experience. You might even make that case by June 1943 - Arnold had already reached that conclusion. But not in the Fall/Winter of 1942/43. They should have. Why? The Luftwaffe was still working out tactics, had barely started to attack the heavies, hadn't yet begun to augment their fighter defenses in the west, and were inflicting only light to moderate casualties. We were still flying shallow penetrations, and didnt even hit a coastal target in Germany (Wilhelmshaven) until January 30th, 1943. We were flying few missions every month owing to the poor weather, and we only had four heavy bomb groups available (none with Tokyo tanks that allowed us to go really deep), so no conclusive test of doctrine was possible. Production was very limited at the time. Yes, I am providing a what-if. If the guys in England had been screaming for P-38's the production could have been ramped up. Everyone in every theater other than the ETO (where there were no P-38s because they were all sent to the MTO) was screaming for more, and yet production was what it was. Yes, production was what it was. I find it hard to believe it couldn't have been increased. And yet it wasn't, despite screams from the MTO and PTO asking for every single P-38 they could get. The MTO was the highest priority theater in late 1942 and most of 1943 (at least until after Salerno), so if any one was going to get them it was the MTO. Guadalcanal got a single squadron (339th) in December 1942 while that outcome was still in dispute, and the PTO wanted more. The ETO was well down the list, because there was no ground combat underway, and the base was safe. I very much doubt that more screaming would have increased the pace any more than it was. I can't help what you doubt. The 8th AF was the premier USAAF organization in the world. Arnorld was clearly ready to provide anything needed by his close friend Eaker. But Eaker didn't ask for it. Arnold was a member of the Joint and Combined Chiefs of Staff, who determined allocations after their respective governments had decided which theaters had priority. Throughout the period in question, the MTO had priority, and Arnold gave them first choice, often re-directing units which had originally been planned to go to the ETO. Eaker got what was left. Only after Salerno, when it became clear that the necessary air superiority required for D-Day had not yet been established, and the commanders started to relocate to the UK from the Med, did the ETO move to first priority. Then there's the extra training time for multi-engine, which would add some additional delay to getting units operational/providing replacement pilots. That doesn't seem that big an issue to me. It was for P-38 units and replacements, especially those that were originally supposed to get single-engined a/c. Lots of accidents when losing an engine on t/o. The source I quote above says accidents for P-38's were less for the P-38 than for the P39, P-40 and P47 in 1942. And for units trained from the start for multi-engine, that may be correct. But there's still the extra training time factor, and in 1943 you're talking about transitioning single-engine pilots to twins, if you want to crew these P-38s that are supposed to magically become available. The 55th's experience with hastly transitioned pilots was apparently less than wonderful. ibid p. 14 Yes, it might to pure hindsight to blame him for this in 1942. Definitely. But Eaker persisted in supporting the self-defending bomber after 17 August, '43 and even after 14 Oct. '43. Not after Second Schweinfurt. That made him a convert. Even so, he still made the (apparently) cognitively dissonant decision to give the P-51s to the 9th, but Kepner fixed that, before Doolittle replaced Eaker. It made undoubted sense from a logistic perspective, but none from a tactical perspective. Second Scheinfurt was late in the game. Sure. OTOH, it was entirely possible to write off Regensburg/Schweinfurt as everything going wrong that could go wrong (it did). It was hardly a typical mission, so Eaker probably felt that a sustained effort was necessary, with the large size force he believed was necessary to succeed. And of course, although he knew that the German fighters were inflicting damage on the bombers, he still believed that the bombers were badly attriting the fighters. Hence October 10th-14th. After that, there could be absolutely no doubt. Eaker was wrong, but he wanted to win just as much as anyone did. As one of the prime apostles of the very doctrine he was employing (Hansell being another), no one was in a better position to give it a full test. Guy |
http://www.p-38online.com/p38j.html
In spite of all the advances and improvements, the P-38 J would suffer in the European Theater of Operations. Lockheed did all the testing in the United States, and were never tested in conditions similar to those in Britain. Once the P-38 J arrived in Britain, problems were encountered immediately. In addition to the new problems, many new, inexperienced pilots were beginning to fly. The problems would take time to work out, but the 8th Air Force was not able or willing to wait. At this time, P-51 D Mustangs and new versions of the P-47 Thunderbolt were available to perform long-range escort and strike missions. This was the beginning of the end of the P-38 in the ETO. -HJC |
around, owing to the need to redesign the a/c for mass production, and a delayed development due to the crash of the prototype. "The production in mid-1940 of 30 P-38's saw signifcant design changes instituted to help mass production. For the first time, the fuselage was split into left and right halves, and the nose section was built up independently. The aft booms also were divided into two pieces with the skins adjusted to accomodate this....The XP-38A was a converted P-38 with pressurization; next production variant was the P38D of late summer 1940. The ever indeasing orders for Lightnings prompted more design changes, both to improve performance and to faciliate mass production." --Warbird Tech Series vol 2, Lockheed P-38 Lightning pp. 22-26 by Frederick A Johnsen Sounds to me like the needed changes were in hand well before 1941, let alone 1942. Sure they were in hand, but they also caused a lot of delay, which is why the a/c was so slow in getting into mass production and why the numbers remained so low relatively late. If someone had said, "hey, we are going to need long range escorts, and the only aircraft even remotely capable is the P-38," then these problems might have been overcome. The P-38F, the first full-up combat-capable version was available for combat in August 1942; the first flight was made in January 1939, so roughly 3.5 years elapsed. Even allowing for a fairly leisurely development prior to the war, the P-38's development was unusually prolonged, especially when compared with its single-engined stablemates. And then in 1943 the wing leading edges, turbos, radiators etc. all had to undergo a major redesign to fit leading edge tanks in, then they had to re-tool before they could produce them. snip 3 months maybe six months possibly, but a year? I think not. Production was still ramping up, and the P-38 was still suffering from many of the same problems in August 1944 as it had in October '43, 10 months after the 55th achieved IOC in the ETO. That might have been alleviated earlier the generals in England had pushed it. But they did not. Can't push what you don't know you need, They could have known they were going to need a lot more P-38's. The kernal of this whole issue is that Eaker and Hunter didn't divine that they needed a long range escort, and remained blind to this fact after pretty much everyone else had tumbled onto it. and since they didn't have ANY P-38s in the late fall of 1942, winter, spring or summer of 1943, there was no opportunity for them to work out the bugs. Now that doesn't seem fair, because a P-38 group WAS in England in December 1942. That was the 78th FG. According to Freeman in "The Mighty Eighth", most of the aircraft and pilots were sent to North Africa. Also, at the start of 1943, the B-17 groups were dealing fairly well with the German fighters. By the summer the Germans would modfy the equation in their favor. Freeman does note that the P-38 was "a complicated aircraft to build and production was unable to meet the demands both the demands of attrition and equipment of new units." Perhaps what it comes down to is this: Even if Eaker and Hunter had been strongly seeking P-38's for escort, could those demands have been met by say, "Blitz Week" in 1943, when the GAF really started to hurt the Fortresses? You're suggesting that production could not possibly have met the need. I'll grant that possibility. It's a what-if, and we'll never know. The 1st, 14th and 82nd FGs had all been sent to the MTO, while the 78th had been stripped of a/c to replace losses, and transitioned to the P-47. Sending all the P-38s to the MTO was a decision made well above Eaker's pay grade, and there wasnt anything he could do about it. As I say above, the B-17's at the start of 1943 were seen to be coping with the Luftwaffe defense. But it's also true that the 8th AF was the premier force in the world as far as Arnold was concerned. If the 8th had been seen as needing long range escorts, surely they could have been provided. It's also true that some of the B-17 group commanders didn't care much about escorts in the early part of the campaign. All that rendesvouzing made things more complicated, don't you know. But as the Germans realized the threat and acted to meet that threat, the B-17 bomber boxes met their match and were overborne. Certainly, and after Aug. 17th 1943 you can make a good case for accusing Eaker of remaining wedded to doctrine over experience. You might even make that case by June 1943 - Arnold had already reached that conclusion. But not in the Fall/Winter of 1942/43. They should have. Why? Because they got their asses handed to them. The Luftwaffe was still working out tactics, had barely started to attack the heavies, hadn't yet begun to augment their fighter defenses in the west, and were inflicting only light to moderate casualties. That's right. It's all a big what if. All I am saying is, "what if Eaker and Hunter had seen the need for a long range escort?" But they didn't. And they didn't see the need either of them, until after it was plain to everyone else that the bombers needed help. It's tragic, but there it is. We were still flying shallow penetrations, and didnt even hit a coastal target in Germany (Wilhelmshaven) until January 30th, 1943. We were flying few missions every month owing to the poor weather, and we only had four heavy bomb groups available (none with Tokyo tanks that allowed us to go really deep), so no conclusive test of doctrine was possible. Production was very limited at the time. Yes, I am providing a what-if. If the guys in England had been screaming for P-38's the production could have been ramped up. Everyone in every theater other than the ETO (where there were no P-38s because they were all sent to the MTO) was screaming for more, and yet production was what it was. Yes, production was what it was. I find it hard to believe it couldn't have been increased. And yet it wasn't, despite screams from the MTO and PTO asking for every single P-38 they could get. Do you know that? Maybe they were straining every sinew to turn out P-38's. I've gotten the impression that no particular stress was put on. They were surely working as dilligently as anyone in war production, but did anyone say, this is the most important fighter we have? The USAAF was sold on the Thunderbolt. Development of the Merlin Mustangs lagged also. If someone had said, "yes we are handling the GAF now but they might produce new tactics, new equipment and strongly reinforce," then it might have been a different story beginning in the summer of '43. You make some very good points and I appreciate them. Walt |
WalterM140 wrote:
snip Sounds to me like the needed changes were in hand well before 1941, let alone 1942. Sure they were in hand, but they also caused a lot of delay, which is why the a/c was so slow in getting into mass production and why the numbers remained so low relatively late. If someone had said, "hey, we are going to need long range escorts, and the only aircraft even remotely capable is the P-38," then these problems might have been overcome. But the P-38 wasn't "the only aircraft even remotely capable" of long range escort, especially not in 1943. Remember that the longest-ranged US escort fighter of the war wasn't a P-38 or P-51. As I pointed out in another post, the P-38 prior to the J had 300 gallons of internal fuel, and the P-47 prior to the D-25 had 305. Go he http://www.zenoswarbirdvideos.com/More_P-38_Stuff.html and here http://www.zenoswarbirdvideos.com/P-47.html And click on the links for the "Flight Operation Instruction Chart" for both a/c (it helps if you save them and then tile them side by side). This is for a P-38L w/410 gallons internal instead of 300, vs. an early model P-47 w/o water injection, but just compare the cruise ranges and gal/hr. fuel flows in say Cruise Condition IV at 25,000 or 30,000 feet, with each a/c assumed to have 250 gallons of fuel for cruise. You'll note that the range is identical at 700 statute miles, with the P-38L cruising slightly faster (an earlier version without the extra internal fuel would probably cruise a bit slower for max. range) but burning about 3-4 gal./hr. more than the P-47. The need was for a longer-range fighter, and the P-38, P-47 and P-51 could all be modified to increase theirinternal/ and/or external fuel carriage. And they all were. The P-38's original perceived range advantage was due to its large external, unpressurized 165 gallon ferry tanks, which was fine in the low/medium overwater cruise conditions typical of the PTO and MTO, but unacceptable in the ETO owing to the need to be above 20,000 feet relatively soon to avoid flak on crossing the occupied Dutch/Belgian/French coasts. Otherwise the P-47's 200 gallon ferry tank would have been reasonably acceptable in the ETO, and histories would be describing the P-47 as a long-range fighter from the get go. Instead, the tank was carried only half full so that all the fuel would be burned by the time the a/c reached about 22,000 feet or so, above which no fuel could be drawn. Better than nothing, but the a/c had to pay the drag for 200 gallons of fuel while only receiving the benefit of 100 gallons. The same would have been the case with the P-38, and there would have been no point in carrying more than a single 165 gallon tank for ETO high altitude escort missions. The P-38F, the first full-up combat-capable version was available for combat in August 1942; the first flight was made in January 1939, so roughly 3.5 years elapsed. Even allowing for a fairly leisurely development prior to the war, the P-38's development was unusually prolonged, especially when compared with its single-engined stablemates. And then in 1943 the wing leading edges, turbos, radiators etc. all had to undergo a major redesign to fit leading edge tanks in, then they had to re-tool before they could produce them. snip 3 months maybe six months possibly, but a year? I think not. Production was still ramping up, and the P-38 was still suffering from many of the same problems in August 1944 as it had in October '43, 10 months after the 55th achieved IOC in the ETO. That might have been alleviated earlier the generals in England had pushed it. But they did not. Can't push what you don't know you need, They could have known they were going to need a lot more P-38's. The kernal of this whole issue is that Eaker and Hunter didn't divine that they needed a long range escort, and remained blind to this fact after pretty much everyone else had tumbled onto it. Summarizing from Freeman, the first RFI for availability of drop tanks for fighters was sent from the 8th back to Air Materiel Command on 3 October 1942, which certainly implies that improved range was on someone's mind quite early. After it became clear that the 8th would only be dealing with the P-47 for some time, arrangements were made in January 1943 to ship Republic 200 gallon paper composite ferry tanks to the UK. A few arrived in February and were evaluated by VIIITH AFSC at Langford Lodge and by Cass Hough's 8th Air Technical Section at Bovingdon, numerous operational deficiencies being noted, including poor aerodynamics, lack of pressurization so fuel couldn't be drawn above 22,000 feet, the tank tended to impact the a/c upon release, and if fuel was left in the tanks for more than a few hours it started to leak. The tank also lacked the strength to be pressurized. Changes were designed and tested to improve the jettison behavior. Simultaneously 8th AFSC was requested to design a 100 gallon steel tank that could be attached under a P-47, and which wouldn't suffer from the faults of the Republic tank. Prototype testing was successful in March, and an order was placed to deliver 1,000/month starting in June, but shortages of sheet steel in England delayed production. Meanwhile, In May 8th ATS had managed to modify the P-47's instrument vacuum system to pressurize a drop tank, which meant that fuel could be drawn as high as 35,000 feet. Further improvements were made to the design as well as to the tank pipe connections to ensure a clean break on jettison. Production delays with the steel 100 gallon tank caused ATS to look at the British 108 gallon paper composite tank as a substitute. It had been examined earlier but was insufficiently strong to be pressurized. Investigation found that it was possible to strengthen the tank to withstand 17psi, and it was cleared for production on 7 July 1943. The first was delivered on 12 July. Meanwhile, because the need was so obvious, 8th FC decided to use the 200 gallon Republic tank despite its deficiencies, as being the only tank available in any quantity (1,150 on hand on 24 July 1943) at the time. It was only filled halfway owing to the lack of pressurization, and they were dropped at 23,000 feet. As an additional stopgap, in July 4,000 nominally 75 gallon (actually 84 gallon) P-39 tanks which had been ordered from the US had also arrived. These provided about as much radius increase as the half-full 200 gallon tanks owing to their far lower drag, and could be pressurized. However, modifications had to be made to the tanks and the P-47s to fit them to belly shackles. First mission use followed in late August 1943, after the 56th FG's a/c had been modified. At the beginning of September the first cylindrical 108 gallon steel tanks (the production version of the ATS 100 gallon design) started delivery, and the same month the strengthened 108 gal. cylindrical paper tanks began delivery, seeing first use on the 27 September mission to Emden. A problem with these tanks was that there was only 4 inches of ground clearance when mounted on the P-47's centerline, making them unusable on rough airfields. A request for a flat 150 gallon steel tank to avoid this problem was made in August, with the tanks being delivered starting in the following February. Meanwhile more 75 gallon P-39 steel tanks had been arriving, but further deliveries were cancelled in December, at which time 7,500 108 gallon tanks had been delivered. The 75 gallon tanks were then restricted to P-51 units until used up. In early 1944, P-47s had wing pylons added (a production change), which allowed a pair of 108 gallon (or even 150 gallon) tanks to be carried underwing, although some delay ensued owing to the need to improve sway braces. Only when this point was reached was the P-47's combat radius limited by its internal fuel capacity. The P-47D-25 with increased internal tankage and a bubble canopy was in production, but deliveries would obviously take some time to make it to the operating theaters. That was less of a problem than it might have been, as the P-51 and P-38J which had been going through much the same range improvement process (but without the big fuselage redesign also underway on the P-47D-25) were available in increasing numbers to provide the TARCAP, while the P-47s provided ingress and egress escort. Ultimately the P-47N became the longest-ranged escort fighter of WW2, but it took a near total wing redesign to do it, and the a/c just barely made it into the war in the Pacific. The point of all this is that the 8th was aware of the range issue and was doing what it could to improve it with the a/c (P-47) and resources available to it, from a very early stage. They were forced to utilize many stopgaps and work-arounds, but with two possible exceptions, it seems to me that the 8th was doing everything in their power to fix the problem (along with thousands of others). The first exception was Eaker's placing improved fighter range 4th on his priority list (and I've never seen what Nos. 1-3 were, so am not in a position to judge if the order should have been changed). The second exception was the relatively long time between the request for a 150 gallon flat tank and its availability. I assume this was probably due to materiel shortages, but don't know. Alternatively the P-47 could have been given wet wing pylons earlier, but that's probably requires a production mod (for wing strengthening at least), not a field retrofit. and since they didn't have ANY P-38s in the late fall of 1942, winter, spring or summer of 1943, there was no opportunity for them to work out the bugs. Now that doesn't seem fair, because a P-38 group WAS in England in December 1942. That was the 78th FG. According to Freeman in "The Mighty Eighth", most of the aircraft and pilots were sent to North Africa. The 78th arrived in Nov. - Dec., and the a/c and pilots were sent down to North Africa in February. In the meantime, few bombing missions were flown owing to the poor weather, and I'm not even sure if the 78th flew any combat missions at the time - they may well have been training, or rectifying equipment deficiencies. Also, at the start of 1943, the B-17 groups were dealing fairly well with the German fighters. By the summer the Germans would modfy the equation in their favor. Freeman does note that the P-38 was "a complicated aircraft to build and production was unable to meet the demands both the demands of attrition and equipment of new units." Perhaps what it comes down to is this: Even if Eaker and Hunter had been strongly seeking P-38's for escort, could those demands have been met by say, "Blitz Week" in 1943, when the GAF really started to hurt the Fortresses? You're suggesting that production could not possibly have met the need. I'll grant that possibility. It's a what-if, and we'll never know. The 1st, 14th and 82nd FGs had all been sent to the MTO, while the 78th had been stripped of a/c to replace losses, and transitioned to the P-47. Sending all the P-38s to the MTO was a decision made well above Eaker's pay grade, and there wasnt anything he could do about it. As I say above, the B-17's at the start of 1943 were seen to be coping with the Luftwaffe defense. But it's also true that the 8th AF was the premier force in the world as far as Arnold was concerned. But not as far as the rest of the JCS, CCS and the respective governments were concerned, and Arnold was going to go along with them. If the 8th had been seen as needing long range escorts, surely they could have been provided. And they were, but only from about Nov. - Dec. 1943, as early as it was possible to do so, and six months after the requirement was identified. And the same holds true for every other theater, except that they got their long-range escorts even later. The P-38F/G/H was a useful interim "long-range fighter" in those theaters where altitude and climate performance wasn't the issue it was in the ETO, but it wasn't inherently any longer-ranged than the contemporary P-47. As far as long-range and combat radius goes, the best 1943 medium and high altitude fighter was the early Corsair, with 361 gallons internal and a 150 gallon tank. But the 124 gallons in the wings was a bit dangerous (not self-sealing, but inerted), and was deleted from later versions. Now there's a 'what if' for you, but it suffers from similar production number limitations as the P-38 in that timeframe. snip Certainly, and after Aug. 17th 1943 you can make a good case for accusing Eaker of remaining wedded to doctrine over experience. You might even make that case by June 1943 - Arnold had already reached that conclusion. But not in the Fall/Winter of 1942/43. They should have. Why? Because they got their asses handed to them. Not prior to mid-43 they hadn't, so why should they be expected to be clairvoyant in late '42? snip Yes, production was what it was. I find it hard to believe it couldn't have been increased. And yet it wasn't, despite screams from the MTO and PTO asking for every single P-38 they could get. Do you know that? Maybe they were straining every sinew to turn out P-38's. I've gotten the impression that no particular stress was put on. They were surely working as dilligently as anyone in war production, but did anyone say, this is the most important fighter we have? In the MTO and PTO, you bet they did. Which were the only theaters they were being used in at the time. The USAAF was sold on the Thunderbolt. And was doing everything possible to improve it, in the theaters it was being used in. Development of the Merlin Mustangs lagged also. snip Not that I've seen, once the performance of the Mk.X conversion was known. But it took NA quite a while to a production design and then get it into production and service, and the Mustang was the fastest US fighter development program in the World War 2 period. I've seen no indication that there was unnecessary delay in that period; the delay seems to have been in the Mustang I era, when the USAAF was so dilatory in testing it. Guy |
regaining night currency but not alone | Teacherjh | Instrument Flight Rules | 11 | May 28th 04 02:08 PM |
Did the Germans have the Norden bombsight? | Cub Driver | Military Aviation | 106 | May 12th 04 07:18 AM |
Why was the Fokker D VII A Good Plane? | Matthew G. Saroff | Military Aviation | 111 | May 4th 04 05:34 PM |
Night of the bombers - the most daring special mission of Finnishbombers in WW2 | Jukka O. Kauppinen | Military Aviation | 4 | March 22nd 04 11:19 PM |
Why did Britain win the BoB? | Grantland | Military Aviation | 79 | October 15th 03 03:34 PM |
