Guy Alcala wrote:
WalterM140 wrote: It would have been quite easy to stop P-38 escorts in 1943, just attack them early, and force them to jettison their external tanks, they were carrying about as much or more fuel externally than internally. It was -shown- that even a few dozen P-38's had a very delerious effect on the tactics of the German day fighters. There's no "it would have been quite easy to..." to it. What you suggest was not a factor. Only because the Germans rarely did so. U.S. fighter commanders were surprised that they didn't try it more often, because it was so obviously a good idea. Indeed, the Luftwaffe had tried to do so for a while, but heavy singl-engine fighter losses (against P-47s) had resulted in an order from either Goring or Schmidt (I forget which) sometime in the late-43 early '44 period (I forget) to cease such attacks and move the fighters back. A bad decision. BTW, ISTR for Geoffrey's info that the early J models were all retrofitted with leading edge tanks either shortly before or shortly after achieving IOC in the ETO. Also P-38 numbers grew from 302 in December 1942 to 567 in May 1943 then declined to 372 in October 1943 before rapidly expanding to 1,063 in April 1944. The numbers are for the USAAF deployed against Germany and include reserves etc. Thanks for the minutia. Not minutia in this case, but very germane, as the lack of P-38 numbers was a factor. Production was very limited at the time. Then there's the extra training time for multi-engine, which would add some additional delay to getting units operational/providing replacement pilots. The point is that Eaker and Hunter, 8th BC and 8th FC CGs respectively could have stressed long range escorts and pushed P-38 enhancements, stressed solving the technical problems, and so forth in 1942. P-38's were available in England in 1942. Eaker and Hunter didn't do that. While Eaker and Hunter were doctrinally blind to the need for far too long, the need for a long-range fighter in the ETO in 1942 was hardly obvious given the shallow penetrations we were making at the time. Arnold ordered Giles to increase the internal fuel of the fighters around June '43 IIRR (don't have the reference, "To Command The Sky" by McFarland and Newton, handy), giving him six months to achieve it. Besides the P-38 was only in the ETO for a couple of months before they were all sent to the Med. I consider one of the great historical "what ifs" to be what if at least some P-38s had remained in the 8th from November 1942 until September '43 (we'd have to assume that P-38 production was sufficient that the 78th FG wouldn't have had its P-38s stripped from it and sent to the Med as attrition replacements, so they weren't forced to transition to the P-47). Would we have been able to fix the P-38's high altitude/cold and wet climate problems prior to the availability of the P-51? As it is, we know from Zemke that turbosupercharger control freeze-up was still an issue in August _1944_ (IIRR he was flying a J-15), despite the problem being identified no later than when the 55th FG had gone operational in mid-October '43. Even assuming that the problems (engines, turbo controls, cockpit heat, dive flaps; the boosted ailerons were a 'nice to have') had been fixed earlier, was it possible to produce enough P-38s in that period to supply the needs of the PTO, MTO _and_ ETO? It seems unlikely, given the relatively low production totals of the P-38 compared to the single-engine a/c, and cost -- both the P-47 and P-38 cost about double the P-51 to build in money, materiel and man-hours; fuel requirements were also about double. Given the production totals achieved with other aircraft, the US COULD have ramped up production of the P-38, but the war production board didn't approve second source production until very late (IIRC about 120 P-38s were eventually produced by Vultee-Nash, but likely none of them ever made it to the combat theaters). If the engines had been swapped out for two-stage Merlins, the turbo and early intercooler problems would have been eliminated, at the cost of some fuel efficiency, and Lockheed submitted a proposal for this, although politics prevented this. That the P-38 was developed to US specifications before the war resulted in the Allison engine use, and the US focused on turbosupercharging for inline engines. Of course, at that time, the Merlin didn't have two-stage supercharging either, so the turbo was really the only practical way to go for high altitude performance at the time. The Allies had their share of bad production decisions, but the greater industrial capability tended to make these decisions less than critical to the final outcome and not as noticed in the overall picture. Mike Williamson |
regaining night currency but not alone | Teacherjh | Instrument Flight Rules | 11 | May 28th 04 02:08 PM |
Did the Germans have the Norden bombsight? | Cub Driver | Military Aviation | 106 | May 12th 04 07:18 AM |
Why was the Fokker D VII A Good Plane? | Matthew G. Saroff | Military Aviation | 111 | May 4th 04 05:34 PM |
Night of the bombers - the most daring special mission of Finnishbombers in WW2 | Jukka O. Kauppinen | Military Aviation | 4 | March 22nd 04 11:19 PM |
Why did Britain win the BoB? | Grantland | Military Aviation | 79 | October 15th 03 03:34 PM |
