Once air superiority was available the RAF flew their
daylight missions in loose gaggles of 2-4 aircraft staggered in height to minimise flak damage. That might have been influenced by the fact that no other aircraft type could fly in the tight formations used by the B-17. I've heard that B-26s could also fly in very tight formations, but I shouldn't think as at high an altitude as the B-17. B-17's could maintain formation at heights almost twice as high as the altitude at which Bomber Command usually operated, either by day or by night. Walt Walt |
Subject: Night bombers interception in Western Europe in 1944
From: (WalterM140) Date: 7/17/2004 1:12 PM Pacific Standard Time Message-id: Once air superiority was available the RAF flew their daylight missions in loose gaggles of 2-4 aircraft staggered in height to minimise flak damage. That might have been influenced by the fact that no other aircraft type could fly in the tight formations used by the B-17. I've heard that B-26s could also fly in very tight formations, but I shouldn't think as at high an altitude as the B-17. B-17's could maintain formation at heights almost twice as high as the altitude at which Bomber Command usually operated, either by day or by night. Walt Walt No trick maintaining formation at high altitudes. The trick is hitting the target from high altitudes. Arthur Kramer 344th BG 494th BS England, France, Belgium, Holland, Germany Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer |
WalterM140 wrote:
Once air superiority was available the RAF flew their daylight missions in loose gaggles of 2-4 aircraft staggered in height to minimise flak damage. That might have been influenced by the fact that no other aircraft type could fly in the tight formations used by the B-17. That's a question of stability and control forces. The B-17 was easier to fly in formation than the B-24, but I have no idea how the British heavies stacked up. I've heard that B-26s could also fly in very tight formations, but I shouldn't think as at high an altitude as the B-17. Not even close, owing to the engine supercharging. B-17's could maintain formation at heights almost twice as high as the altitude at which Bomber Command usually operated, either by day or by night. Again, due to the superchargers. Both US mediums and the British heavies used single-stage two-speed superchargers while the B-17 and B-24 used turbochargers (feeding superchargers). That generally gave them max. power and top speeds ain the range of 13,500 - 15,000 feet. A couple of years ago a few of us decided to find out what it would take to boost RAF heavies to B-17 or B-24 formation cruise heights. Given the available British engines, they could only have used two-stage two-speed Merlins, 60, 70 or 80 series. Those were all being used by Spit 8/9/16s, late model Mossie bomber/recon a/c, and of course Merlin P-51s. Major changes in production lines (and the a/c) would have been required to provide enough for the heavies as well. Our conclusion was that the simplest and quickest method for the Brits to go over to US style daylight bombing against well-defended targets in the fall of 1943 was to use B-24s diverted from US groups in training (the 8th preferred the B-17), at least until they could produce a high altitude bomber engine (preferably a Bristol Hercules air-cooled radial, either turbocharged or with a two-speed supercharger) in adequate numbers. By night most of them were able to cruise individually in the 19 - 23,000 foot range, but formation flying limits the performance to the worst a/c, and also requires some power in hand for throttle jockeying and formation turns. So we figured they were likely restricted to tight formation flying at altitudes of around 18,000 or at most 20,000 feet for Lancs or Halifax IIIs, although we knew we'd have to lighten the bombloads to get them that high (owing to the need to increase the defensive armament, armor, crew, and fuel loads). Guy |
Aargh! Need to correct some brain farts.
Guy Alcala wrote: WalterM140 wrote: snip B-17's could maintain formation at heights almost twice as high as the altitude at which Bomber Command usually operated, either by day or by night. Again, due to the superchargers. Both US mediums and the British heavies used single-stage two-speed superchargers while the B-17 and B-24 used turbochargers (feeding superchargers). That generally gave them max. power and top speeds ain the range of 13,500 - 15,000 feet. 'Them' in the above sentence refers to the US mediums and British hevies, not the B-17 and B-24, which put out max. power up to 25 or 30,000 feet, owing to the turbochargers. snip Our conclusion was that the simplest and quickest method for the Brits to go over to US style daylight bombing against well-defended targets in the fall of 1943 was to use B-24s diverted from US groups in training (the 8th preferred the B-17), at least until they could produce a high altitude bomber engine (preferably a Bristol Hercules air-cooled radial, either turbocharged or with a two-speed supercharger) in adequate numbers. "two-speed" should of course be "two-stage," usually two-stage, two-speed. snip rest Guy |
![]() formation turns. So we figured they were likely restricted to tight formation flying at altitudes of around 18,000 or at most 20,000 feet for Lancs or Halifax IIIs, although we knew we'd have to lighten the bombloads to get them that high (owing to the need to increase the defensive armament, armor, crew, and fuel loads). Guy That's interesting. Didn't the RAF typically operate at @ 15,000 feet over German targets? On at least one occasion, B-17' were briefed to attack Berlin at 27,000 feet; once to beat the clouds a group bombed from 30,000. Walt |
WalterM140 wrote:
formation turns. So we figured they were likely restricted to tight formation flying at altitudes of around 18,000 or at most 20,000 feet for Lancs or Halifax IIIs, although we knew we'd have to lighten the bombloads to get them that high (owing to the need to increase the defensive armament, armor, crew, and fuel loads). Guy That's interesting. Didn't the RAF typically operate at @ 15,000 feet over German targets? Depends on the period, the target and the individual crews, but in general not the heavies, although Stirlings and squadron dogs might be that low or lower. For the Nuremberg raid (except for Mossies, all Halifax and Lancaster) a/c were assigned one of four cruise heights, 20, 21, 22, or 23 thousand feet, although 1 Group were given dispensation to cruise lower, 13-16,000 feet IIRR until they reached the Rhine or some other river, in the hope of hiding in forecast cloud, climbing to the same height as everyone else after that. The cloud wasn't there, and they were hit hard. Once the attacks started, anyone who could went higher -- one Halifax crew in a new a/c were delighted to find that they could get up to 26,000 feet, and cruised safely above the carnage below. Others jettisoned some of their bomb load to improve their ceiling. Crews flying average a/c, or those with less experience or more determination to follow orders stayed at the assigned altitude bands, and were the main targets of the fighters. Dog a/c were stuck even lower, and on that particular mission it actually saved many of them -- one crew couldn't get their Lanc above 12,000 feet and in this case were fortunate, as the fighters were going after the main stream above them. On at least one occasion, B-17' were briefed to attack Berlin at 27,000 feet; once to beat the clouds a group bombed from 30,000. That's the effect of the turbos. Two-stage two-speed supercharged Merlins (or other) would have given similar altitude performance for the British heavies. I have a vague memory that at least one small group of B-17s dropped from close to 35,000 on one occasion, but that must have been very late war with the B-33 turbos. I've got the navigator log data for one B-24 crew's entire 35 mission tour in 1944-45, and the highest bombing altitude recorded (for the plane) is 29,000 feet. One run was at 28,000, another at 26,700, but the majority of runs were in the low 20s. For lightly defended targets they might drop down a few or even several thousand feet - the lowest recorded is 9,000 feet, with another at 12,000. Guy |
![]() "WalterM140" wrote in message ... Once air superiority was available the RAF flew their daylight missions in loose gaggles of 2-4 aircraft staggered in height to minimise flak damage. That might have been influenced by the fact that no other aircraft type could fly in the tight formations used by the B-17. It has more to do with the doctrine of the self defensing bomber that was adopted by the USAAF. You'll find that B-24's also flew in such formations. I've heard that B-26s could also fly in very tight formations, but I shouldn't think as at high an altitude as the B-17. B-17's could maintain formation at heights almost twice as high as the altitude at which Bomber Command usually operated, either by day or by night. True but irrelevant since bomber command didnt fly defensive formations by day after 1941. Keith |
Keith Willshaw wrote:
"WalterM140" wrote in message ... Once air superiority was available the RAF flew their daylight missions in loose gaggles of 2-4 aircraft staggered in height to minimise flak damage. That might have been influenced by the fact that no other aircraft type could fly in the tight formations used by the B-17. It has more to do with the doctrine of the self defensing bomber that was adopted by the USAAF. You'll find that B-24's also flew in such formations. I've heard that B-26s could also fly in very tight formations, but I shouldn't think as at high an altitude as the B-17. B-17's could maintain formation at heights almost twice as high as the altitude at which Bomber Command usually operated, either by day or by night. True but irrelevant since bomber command didnt fly defensive formations by day after 1941. I believe they did from 1944 on, but it was a somewhat looser formation than the US flew. The RAF apparently preferred to allow a little more room for minor evasive action. Guy |
regaining night currency but not alone | Teacherjh | Instrument Flight Rules | 11 | May 28th 04 02:08 PM |
Did the Germans have the Norden bombsight? | Cub Driver | Military Aviation | 106 | May 12th 04 07:18 AM |
Why was the Fokker D VII A Good Plane? | Matthew G. Saroff | Military Aviation | 111 | May 4th 04 05:34 PM |
Night of the bombers - the most daring special mission of Finnishbombers in WW2 | Jukka O. Kauppinen | Military Aviation | 4 | March 22nd 04 11:19 PM |
Why did Britain win the BoB? | Grantland | Military Aviation | 79 | October 15th 03 03:34 PM |
