Pawnee air-oil bear strut pressure
Old March 6th 18, 09:27 PM posted to rec.aviation.soaring
Default Pawnee air-oil bear strut pressure
That may be worthwhile on this and other models (no, I'm not a A&P....).
I believe, due to other gear failures on a Cub and a Pawnee, the routine is to just replace some major gear bolts every few years.
Can't really check them every day, history has shown they wear out over time. When they wear out, broken bolt, then gear collapse follows right after.
On both of our normal towplanes, we have droop tips. This means we get a "wee bit more clearance" before a prop strike.
No, not perfect.
Yes, may be quite a bit cheaper.
To Pawnee or not to Pawnee...that is the question... Travis Beach Soaring 56 March 24th 14 06:21 AM
To Pawnee or not to Pawnee...that is the question... Travis Beach Soaring 4 October 17th 07 01:31 PM
Granville's Strut Seal - Or Other Strut Maintenance Techniques zatatime Owning 4 August 31st 05 04:30 PM
Cherokee Strut Lower Strut Seal Replacement Report Mike Spera Owning 3 July 23rd 05 07:07 PM
High Oil Pressure (was: Low oil pressure, high oil temp?) Thomas Ploch Owning 4 October 5th 04 04:34 AM
