cockpit exit assist for older pilots
Old March 12th 18, 03:41 AM posted to rec.aviation.soaring
Tony[_5_]
Default cockpit exit assist for older pilots
https://www.dg-flugzeugbau.de/en/lib...ilout_aid-noah
Old March 12th 18, 05:38 AM posted to rec.aviation.soaring
bumper[_4_]
I wasn't planning to announce the new MKII Glider Egress System until the few remaining technical problems are resolved.
Our system provides vertical assistance for rapid egress, ground or in-flight. We call it the Omni-Upward Cockpit Hoister, or OUCH for short. Using a reliable cluster of four 12 gauge shotgun blanks, We have egressed sand bags with only very minor burn damage and leakage. However, we are experiencing difficulty locating persons willing to test the system. This, in spite of a rather generous two-figure post-launch bonus. Well, we did have one volunteer, an altogether suboptimal tester if you ask me, as he refused to stop screaming and calmly explain what he did wrong to cause his injuries.
A previous idea of using a small compressed air or CO2, with a 90 degree ball valve to inflate a rubberized nylon (or similar) lift bag under the cockpit cushion, was rejected as being either too reliable or boring.
OLDER PILOTS PERFORM BETTER, STUDY FINDS Larry Dighera Piloting 16 March 21st 07 02:11 AM
How do you exit a F-22 cockpit? John Dallman Naval Aviation 1 May 28th 06 02:51 PM
How do you exit a F-22 cockpit? Mike Naval Aviation 11 May 25th 06 08:01 PM
Older Pilots and Safety Bob Johnson Soaring 5 May 21st 04 01:08 AM
Glass Cockpit in Older Planes Charles Talleyrand Owning 2 May 20th 04 01:20 AM
