HVLP Paint Sprayer Recommendations
Old March 14th 18, 02:53 PM posted to rec.aviation.soaring
Tony[_5_]
Default HVLP Paint Sprayer Recommendations
The last few fabric covered gliders i've been involved with have been done with Stewart Systems covering process. They strongly recommend the DeVilbiss Finish Line IV HVLP gun. My previous experience was on cheap HVLP guns from NAPA auto parts or Harbor Freight. I recommend the DeVilbiss Finish Line IV.
Old March 14th 18, 04:01 PM posted to rec.aviation.soaring
I use the same Finish Line gun when spraying with compressor supplied air.
The turbine system can be beneficial but won't pay unless you will be doing a lot of painting. Ours took about 4 years to pay for itself.
UH
Old March 15th 18, 04:06 AM posted to rec.aviation.soaring
LongJourney
Thanks, Tony. It looks like the DeVilbiss is standalone? I see good reviews of it, but I'm kinda looking at some of the $200 range HVLP guns that come with a compressor and a long length of hose. Our big standard air compressor always has a bunch of water in it, and even decent filters only do so much.
I know that the HVLP compressors heat the air more than desired, but I've read that a decent length of hose will help cool it. I'm using Poly-Fiber, and plan on adding reducer to help counter the heat, as well. I have read that it's best to stay away from the Harbor Freight HVLP tools, as they don't deliver an accurate pattern and fail after a short life.
Again, thanks for the help!
Jeff
Old March 15th 18, 03:47 PM posted to rec.aviation.soaring
jfitch
Jeff
A refrigerated air dryer can fix almost all moisture problems. You can find small ones on ebay frequently for not a lot. I have a 5 hp compressor running pretty much all day feeding the CNC machines, tried all kinds of filters without much success, after installation of the refrigerated dryer everything downstream of that is bone dry.
Old March 16th 18, 03:36 AM posted to rec.aviation.soaring
LongJourney
Jeff
Thanks. Is a refrigerated air dryer electric? Not that that is a problem, I'm just not familiar with the device.
Jeff
Old March 16th 18, 03:47 AM posted to rec.aviation.soaring
Darryl Ramm
Yes it’s a electric powered refrigerator.
Axis Products Citation HVLP Filter Change Andy[_7_] Restoration 0 May 29th 08 06:07 PM
Recommendations for paint shops & avionics shops near NW Ohio [email protected] Owning 0 May 20th 06 12:23 PM
corrosion x sprayer paul Home Built 0 July 31st 05 07:52 PM
paint shop recommendations wanted (SE) Stephen N Mills Owning 0 January 29th 04 03:44 PM
Cleaning the sprayer Michael Horowitz Home Built 2 August 26th 03 03:12 AM
