Op vrijdag 16 maart 2018 16:02:13 UTC+1 schreef Tom BravoMike:
After having spoken to a few DG/Libelle/Cirrus owners I am really considering the Libelle. What would be the points to look out for when buying one, in your opinion? In the Wikipedia article: https://en.wikipedia.org/wiki/Glasflügel_H-201 it says:"they are quite sensitive to sideslipping and have relatively ineffective air brakes that make short landings tricky for inexperienced pilots". I wonder what 'sensitive to sideslipping' means in this case. From what I've heard is that performance decreases very fast when you slip it. So you must fly it pretty accurate with the string in the middle. |
On Fri, 16 Mar 2018 08:29:10 -0700, Senna Van den Bosch wrote:
From what I've heard is that performance decreases very fast when you slip it. So you must fly it pretty accurate with the string in the middle. True enough, but the same applies to all gliders. You'll soon learn to fly a Libelle with the string straight because it that: its no harder to fly straight than any other glider, and it does like the string to be pointing out slightly in a thermal turn. -- Martin | martin at Gregorie | gregorie dot org |
How to Buy a Glider Afordably, or Euro vs ContraFund | [email protected] | Soaring | 22 | December 1st 05 09:01 PM |
How to Buy a Glider Afordably, or Euro vs ContraFund | keithw | Soaring | 0 | December 1st 05 04:07 AM |
Euro vs Contrafund Update, or How to Buy a Glider Affordably | [email protected] | Soaring | 6 | July 7th 05 05:07 AM |
Euro vs Contrafund, or how to buy a glider (affordably) | [email protected] | Soaring | 2 | March 27th 05 07:46 AM |
Euro-fighter? | Bryan | Military Aviation | 2 | October 29th 03 04:01 PM |
