On Wed, 28 Mar 2018 04:59:51 -0700, JS wrote:
On Wednesday, March 28, 2018 at 3:38:09 AM UTC-7, Martin Gregorie wrote: On Wed, 28 Mar 2018 02:45:59 -0700, Senna Van den Bosch wrote: Do you happen to have experience with the ASW19 and how they differ to the Pegase? I've never flown one, but the Peg, ASW-19 and ASW-20 cockpits are identical for all practical purposes. If you like one, you'll like the rest: if you look carefully under the Peg wing you can see where the ASW-19/20 NACA duct for cockpit ventilation has been filled in. This dates from when Centraire were building ASW-20s under license: the Peg fuselage is a minimally modified ASW-20 one (slightly larger diam tail boom, cockpit ventilation intake on the nose, some have a lifting panel. What scares me about owning a Pegase or Libelle is maintenance. Not a Libelle problem. Glasfaser hold the type cert, and have done ever since Glasflugel folded. They give excellent support. During this tear's annuals we discovered damage the the rear u/c axle and a non-approved (solid 20mm shaft) front u/c axle, ovbiously from a hard landing, but no mention in the log book. Glasfaser airmailed replacement axles + bolts & washers which arrived within a week. Situation isn't so clear for the Peg. -- Martin | martin at Gregorie | gregorie dot org The Pegase cockpit has a panel that tilts up with the canopy, which the 19, 20A and early B did not have unless modified. Many (all?) ASW-20Fs, which were license built by Centrair before they ended the license and started to make the Pegase, had a lifting panel with the canopy attached to it, though I'm uncertain whether they all had it or just the later ones. Are there any ASW-20F on your side of the pond? -- Martin | martin at Gregorie | gregorie dot org |
How to Buy a Glider Afordably, or Euro vs ContraFund | [email protected] | Soaring | 22 | December 1st 05 09:01 PM |
How to Buy a Glider Afordably, or Euro vs ContraFund | keithw | Soaring | 0 | December 1st 05 04:07 AM |
Euro vs Contrafund Update, or How to Buy a Glider Affordably | [email protected] | Soaring | 6 | July 7th 05 05:07 AM |
Euro vs Contrafund, or how to buy a glider (affordably) | [email protected] | Soaring | 2 | March 27th 05 07:46 AM |
Euro-fighter? | Bryan | Military Aviation | 2 | October 29th 03 04:01 PM |
