DG-100 vs Std Libelle - opinions wanted
Old April 1st 18, 04:44 PM posted to rec.aviation.soaring
SoaringXCellence
Default DG-100 vs Std Libelle - opinions wanted
On Sunday, April 1, 2018 at 7:27:01 AM UTC-7, wrote:
The DG will perform better, about 2 L/D points especially so when ballasted, has a higher max wing loading.
Libelle
LD 34.5
Max loading 35.7kg/sq M at
Empty weight 200Kg
Max weight 350kg
DG 100
LD 36.5
Max loading 38kg/sq m
Empty weight 230kg
Max weight 418kg
Libelles suffer from a lack of rudder authority when rolling quickly at low speed, but are easy to rig.
They also have balsa core wings, rather than foam.
Only a the H301 Libelles were Balsa core and perhaps a few of the early 201s. All I have seen have been foam core.
Its worth reading Richard Johnsons flight test of the DG100.
https://scalesoaring.co.uk/GLASS/Doc...%20DG-101G.pdf
Fixed tail and elevator is the best model.
The fuselage is 800mm longer on the DG, the longer tail and larger rudder and elevator moment imparts good stability
If you fly a lot in weak conditions, lean towards the lighter weight Libelle.
Regards
Dave L
Libelle seat pan wanted David MacVeigh Soaring 3 February 14th 12 03:43 PM
Wanted Libelle 201b Canopy Fish Soaring 2 June 1st 06 07:10 PM
Paint Opinions Wanted! John S Home Built 9 May 2nd 05 03:25 PM
Wanted: Libelle 201 (USA) Tim Hanke Soaring 0 February 8th 05 07:14 PM
Opinions wanted ArtKramr Military Aviation 65 January 21st 04 04:15 AM
