DG-100 vs Std Libelle - opinions wanted
Old April 2nd 18, 01:27 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
Default DG-100 vs Std Libelle - opinions wanted
On Mon, 02 Apr 2018 00:19:37 -0700, davidlawley wrote:
I thought the change ftom balsa was with the 201b, but wasnt certain.
The ones ive seen have all been balsa, with under over brakes. Regards
Dave L
I don't remember exactly where I found that list detailing the change-
over stages from H.201 to H.201B, but it was almost certainly the
Technical notes list on the Glasfaser website. That has been revised
recently. The general sequence of the modifications that converted the
H.201 into an H.201B Std Libelle was correct, but the werk nrs at which
the changes were introduced have been revised. I've just updated my notes
to match Glasfaser's TN list. My notes are at:
https://www.gregorie.org/gliding/lib...201_notes.html
Martin | martin at
Gregorie | gregorie dot org
Old April 4th 18, 01:07 AM posted to rec.aviation.soaring
Hi Martin, read your notes, under handling point 3, you suggest that differential makes the down going aileron travel further than the upgoing one.
That is the opposite of normal differential, which has the upgoing aileron travel more than the downgoing one. The downgoing aileron produces more drag than the upgoing one.
This is why rudder is required to prevent adverse yaw.
Just sayin.
Regards
Dave L
Old April 4th 18, 01:13 PM posted to rec.aviation.soaring
upgoing one.
Yep - and I was wrong. Just looked at the data sheet, which shows a lot
of differential, but in the other direction: 20 degrees up, 12 down.
Moral: trust the data sheet, not ones imperfect recollection.
Thanks for spotting it. I've just updated the page by removing the
reference to aileron differential, but the rest of the comment about the
occurrence of aileron stalls matches my experience.
Indeed, and its still needed because even a 12 degree downward deflection
adds more drag than 20 degrees of upward deflection.
However, I still think that this year I'll fit a set of 35mm wingtip
skids. Mine has 12mm rubber blocks fitted which are a bit too short: a
fully deflected aileron can touch the ground.
Martin | martin at
Old April 4th 18, 01:24 PM posted to rec.aviation.soaring
If you think of differential in terms of a ratio, yours is a bit less than 2:1, my DG202 is 2:1.
In my days of F3B model flying, I used up to 4:1 for thermalling, and still got adverse yaw, reqiring rudder mixed in.
For the speed task, flown at a very low angle of attack, no differential. With electronic control mixing, a lot of options open
such as flap to elevator (cruising) and elevator to flap (Thermaling) mixing.
Old April 4th 18, 10:57 PM posted to rec.aviation.soaring
You were obviously involved with another part of the model world than I
was. Flew C/L when I was a kid and then moved in to single channel RC. I
gave up RC just about the time that proportional radios appeared because
I'd got involved with competitive Free Flight, mostly F1A gliders and
1/2A / F1J power.
Martin | martin at
Old April 5th 18, 10:35 AM posted to rec.aviation.soaring
Senna Van den Bosch
Op woensdag 4 april 2018 23:57:57 UTC+2 schreef Martin Gregorie:
1/2A / F1J power.
Martin | martin at
I have no clue where this is going to be honest
Old April 5th 18, 12:01 PM posted to rec.aviation.soaring
AS
To bring this back to the original thread: before settling on the DG, look into the service contract aspect surrounding older DG/LS models. Streifeneder still provides service, advise and parts to Libelle owners without a binding service contract.
I know because I owned a H301 for 30 years....
Uli
'AS'
Old April 5th 18, 12:04 PM posted to rec.aviation.soaring
I gave up RC just about the time that proportional radios appeared
because I'd got involved with competitive Free Flight, mostly F1A
gliders and 1/2A / F1J power.
Martin | martin at Gregorie | gregorie dot org
Just a slightly technical model flying discussion, mainly about the
differences in desirable control response between remotely flown models
and full-size gliders. Adverse yaw is something that is easy to deal with
in full-size if your rudder is powerful enough: by and large we just do
it without needing to concentrate on flying a coordinated turn, but when
you're flying an RC glider thats almost specked out above you, its easier
if you can thermal using just one stick instead of juggling both of them.
OTOH, my view, with my F1A freeflight hat on, is that since the model is
doing its own thing (no external control allowed or closed-loop control
systems) I must set it up to automatically centre and stay centred in the
thermal I launched it in. Fortunately, we know how to do this (CG at 55%
chord, minimal fin area, crossed controls with the rudder balanced
against wash-in on the inner wingtip in the turn, trimmer to fly at min.
sink).
Martin | martin at
Libelle seat pan wanted David MacVeigh Soaring 3 February 14th 12 03:43 PM
Wanted Libelle 201b Canopy Fish Soaring 2 June 1st 06 07:10 PM
Paint Opinions Wanted! John S Home Built 9 May 2nd 05 03:25 PM
Wanted: Libelle 201 (USA) Tim Hanke Soaring 0 February 8th 05 07:14 PM
Opinions wanted ArtKramr Military Aviation 65 January 21st 04 04:15 AM
