Source of green donuts for instrument tubing installation?
Old April 7th 18, 04:50 AM posted to rec.aviation.soaring
bumper[_4_]
Default Source of green donuts for instrument tubing installation?
On Friday, April 6, 2018 at 4:55:52 PM UTC-7, wrote:
I dont use the docking rings anynore, after a few years they deteriorate to mush. I now use a short length
of silicon tube that fits over the instrument tube, a much better lasting material, and cheap.
Dave
Silicone is a good choice. If you prefer O-rings, though you cannot always go by color, green ones are used in auto air conditioning system seals and indicate HNBR. This would be a particularly good rubber for glider tubing "clamps" as well. See the link for HNBR characteristics:
http://www.mantaline.com/capabilitie...e/hnbr-rubber/
bumper
Old April 9th 18, 07:44 AM posted to rec.aviation.soaring
krasw
Is there a particular reason to use donuts or anything similar at all for instrument installation? Just push the tube to pneumatic port and go flying.
Old April 9th 18, 08:05 AM posted to rec.aviation.soaring
Using them prevents leaks later on, clamping the tubes.
Old April 9th 18, 08:39 AM posted to rec.aviation.soaring
krasw
I have fixed two leaks in pitot static systems over the years. Both were caused by clamped fitting. That's when I started to take seriously the instruction to never clamp pneumatic tubes with anything. Silicon tubes are idiot-proof, PVC tubes age and may become loose if fitting is connected frequently, the fix is to shorten the tube few centimeters and then plug it back.
Old April 10th 18, 09:45 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
krasw wrote on 4/9/2018 12:39 AM:
Yep, use silicone tubing. It doesn't age like the clear plastic stuff, and remains
easy to push on and pull off. My glider came with the plastic lines for the pitot,
static and TE, so I shortened them, then added back the length needed with a
barbed plastic fitting and silicone tubing. No more tubing problems, and easy to use.
- "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm
http://soaringsafety.org/prevention/...anes-2014A.pdf
Old April 10th 18, 01:44 PM posted to rec.aviation.soaring
AS
Has anyone ever tried a short piece of shrink-sleeve - no longer than the barbed fitting on the instrument - over the tubing? Slip it into place and hit it with a hot-air gun. Should shrink uniformly before doing damage to the tubing.
Uli
'AS'
pvc tubing/sleeve source? Jim Burns Owning 4 September 28th 06 03:36 AM
pvc tubing/sleeve source? Jim Burns Home Built 4 September 28th 06 03:36 AM
Recommended source for 4130 sheet and tubing? Michael Horowitz Restoration 3 April 16th 06 07:23 PM
source for clear+red instrument tubing John W Soaring 8 November 1st 04 01:19 PM
source for aluminum tubing with rounded corners? Kyler Laird Home Built 3 June 1st 04 03:07 PM
