Easy and affordable IGC logger
Old April 17th 18, 05:09 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
Default Easy and affordable IGC logger
On Tue, 17 Apr 2018 07:11:33 -0700, Senna Van den Bosch wrote:
My FLARM is older and doesn't have an SD card slot yet.
If you have an LX Red Box I think its worth getting an SD card reader
(and installing it in your panel if you have the space). Quite apart frpom
using the FLARM as a logger, the other two reasons for doing this a
- it makes the mandatory annual firmware upgrade a lot easier
- FLARM logs can be downloaded and submitted to the FLARM website in
order to see how good the coverage round your glider is, and maybe
find a better position for the FLARM antenna if the coverage is only
short range or has a poor pattern.
Martin | martin at
Gregorie | gregorie dot org
A path to an affordable trainer? Wallace Berry[_2_] Soaring 13 August 3rd 13 04:43 PM
Looking for an affordable glider.... xTrainwrecKx Soaring 4 August 17th 11 12:03 PM
Looking for an affordable glider.... xTrainwrecKx Soaring 1 August 9th 11 05:07 PM
Affordable Glider K Smith Soaring 20 July 23rd 09 07:13 AM
Affordable planes Tom Home Built 4 November 6th 08 08:59 PM
