LxNav USB hub?
Old April 26th 18, 03:12 PM posted to rec.aviation.soaring
Dan Marotta
Default LxNav USB hub?
Amazon has 400 pages of USB hubs.Â* I found THIS
https://www.amazon.com/C2G-Cables-Go-29525-Chromebooks/dp/B006QB1QVO/ref=sr_1_61?s=electronics&ie=UTF8&qid=1524751799&s r=1-61&keywords=usb+hub
one on page 3...Â* BTW, what's wrong with having extra ports, and why do
you need more than one?Â* Just curious.
On 4/25/2018 7:20 PM, Jonathan St. Cloud wrote:
Just purchased the Wifi option for the LXNAV 9070. Currently I have a USB extension plugged into the only USB port on LX, then mounted on the panel fairing by my legs. This way I have access to the USB and all the data transfer without removing canopy to access port.
My question is, can anyone recommend a small two port USB hub that will work for both data transfer and the Wifi dongle. I asked the factory if they had a cable hub that would work and their recommendation was " You can use USB Hub. If you are lucky, the first one will work. If not, buy another type, that will work."
Anyone know which ones that will work, or what specs I should look for?
Dan, 5J
LXNAV V3 Issues [email protected] Soaring 20 April 14th 15 05:49 AM
LXNAV V7 and WinPilot Pro [email protected] Soaring 6 November 14th 13 03:35 PM
F.S. LxNav V3 variometer Nick Kennedy Soaring 1 November 13th 13 05:00 AM
New vario by LXNAV [email protected] Soaring 6 May 22nd 13 11:15 PM
LXNAV V7 Paul Remde Soaring 2 November 2nd 11 12:31 AM
