On Thursday, April 26, 2018 at 7:40:06 AM UTC-4, Bryce Sammeter wrote:
I annual two different LS3’s and both have a boom mike mounted there. Hope that helps. I sawed it off. I always thought it was for a boom mike. But in a crash involving my head slamming back onto the soft headrest, the bracket could have penetrated my skull (as nearly happened with a U.S. Team member at the World Championships in 1972, IIRC). Chip Bearden |
Just in case you crash tail first at high speed huh? Sounds likely.
On Thursday, April 26, 2018 at 6:25:29 PM UTC-7, wrote:
Just in case you crash tail first at high speed huh? Sounds likely. Or you come to a sudden stop. Ever heard of whiplash? |
Yep, whiplash happns when you are hit from behind, just like I said....
Not exactly...to be more accurate...
Running into something that stops your forward motion (the ground) causes your head to whip forward, then whip back after reaching the forward limits of your spine. (RIP Dale Sr.) That's whiplash and it's what messed up my neck in 1985. (Totalled my TR-7...) Any collision, from front or rear, causes whiplash. Ask your local neurosurgeon or chiropractor. Paul A. |
On Thursday, April 26, 2018 at 9:25:29 PM UTC-4, wrote:
Just in case you crash tail first at high speed huh? Sounds likely. Not that likely, but I know of two occasions. "On this landing the pilot's head, on first impact, quartering to the front, went through the canopy with little damage because the mounting rails and quarter-inch steel canopy retaining rods bent at extreme angles ( and the plastic broke) to absorb most of the energy. However, on the second impact, traveling backwards, the pilot's head was driven back into the headrest. Fortunately, dead on center. The leather cover and padding were driven back into the headrest and two steel mounting brackets, 1 x 1/8-inch plate and 5 or 6 inches long came slicing out through the front of the headrest. They made significant bruises on either side of the pilot's head and could have penetrated had the head been slightly turned." A.J. Smith writing about the crash of his Nimbus II on the last day at the Worlds in Vrsac in 1972 (Soaring magazine, Apr 1973). I'm also unfortunately very familiar with a fatal crash where the fuselage impacted in a relatively flat position, sinking at high speed, and the pilot's head snapped back hard because there was no headrest (early ASW 20). As I said: I sawed it off. Just in case. If we could plan when and how we crash, we could save a lot of money on unneeded insurance, parachutes, etc. ![]() Chip Bearden |
DG-100 Headrest | [email protected] | Soaring | 8 | April 30th 18 10:24 PM |
WTB: Headrest for ASW-20,19, etc. | GeneReinecke | Soaring | 3 | August 1st 16 04:54 AM |
Discus B Headrest | Kurt[_3_] | Soaring | 4 | November 24th 15 02:23 AM |
Ka-6 Headrest | vontresc | Soaring | 1 | May 15th 08 10:28 PM |
Grob headrest | nmskies | Soaring | 3 | May 18th 06 04:56 AM |
