Wanting to start a new glider club
Old April 28th 18, 05:22 AM posted to rec.aviation.soaring
John Foster
Default Wanting to start a new glider club
On Tuesday, April 24, 2018 at 3:17:43 PM UTC-6, john firth wrote:
On Monday, April 23, 2018 at 4:56:24 PM UTC-4, John Foster wrote:
Hi everyone
I just started glider flying lessons and I'M HOOKED!!! Unfortunately, the closest glider club is 3:45 hr drive away. I also live in an area that looks to me to be perfect for ridge soaring, with a range of mountains facing the west that runs for at least 85 miles, and possibly longer. We have an airport close by with a 4800' runway, about 2-3 miles west of the mountains. A friend is a CFI and A&P, and is interested in getting his "glider ticket" as well. There are a few other folks in the area that have expressed varying interest in flying gliders as well. But as it currently stands, no one (except one possible individual that I haven't yet talked to) in the area actually flies gliders. My friend and I have talked about the possibility of starting a local club. What would be the best way to go about doing this?
Car tow might be the most economical way to launch, if the a/p mgt.. will let you; looks like 5000ft of hard top, which is more than adequate.
Moreover, driver training is easier than starting a newbie on a winch.
JMF
I spoke to the airport manager today, and he indicated he would need to discuss it with the board, but didn't see why we wouldn't be able to do auto tow here. Our runway is about 4800', oriented parallel to the mountains, but about 2.5 to 3 miles to the west of the mountains. It would be nice to be able to get as high as possible in order to get over to the mountains, particularly with a low-performance bird like a 2-33 or a 2-22. The idea of the reverse auto tow using a pulley really sounds appealing, and to me this more closely approximates the action of a winch (other than the acceleration). Anyone know where one could get a lead on the rope used to string high-voltage cables? That sounds ideal for a tow rope.
One of my objectives in this endeavor is to keep it as affordable as possible. There is a lot of poverty around here, and if there was a way to keep launching cost down to a minimum, that would be ideal.
Old April 28th 18, 06:00 AM posted to rec.aviation.soaring
son_of_flubber
You only need to get high enough to have a couple minutes to find and catch a thermal. Once you gain a bit of altitude in that first thermal, you can fly upwind to find better thermals (and get away from the pattern). Eventually you get high enough to fly downwind over to the mountains with enough reserve altitude to fly upwind back to the airport.
The good news is that pilots at winch and auto tow operations get a lot of launching and landing practice, and when you do finally catch a thermal, it is a hoot.
The other good thing about winching (and autotow?) is that launch and land practice/training is great fun even on days with no lift. Winching is much more fun than aerotow, and for the price of a single aerotow, you can do 5-6 winch launches.
Old April 28th 18, 07:33 AM posted to rec.aviation.soaring
John,
I hope you can get this operation off the ground. I did some power plane flying in that area some years back and it looks spectacular for glider flying. Montana's nickname is "big sky country" after all.....
Best of luck,
Ron Clark
LS3
Evergreen Soaring Club
Old April 28th 18, 04:14 PM posted to rec.aviation.soaring
Paul T[_4_]
Some useful links. I was a member of a club that did straight reverse
pulley autotow off grass, just a pulley on a rotating shackle on a chain
staked into the grass, and we used to launch a 22M Kestrel with that
system. You have to be carefull with initial rotation as acceleration is
not as fast as a winch - using a 2:1 and 3:1 pulley system might help
with that.
http://www.ukmsg.co.uk/wp-content/up.../SG-Dec-2013.-
Expedition-pilots-guide-to-aunching.pdf
https://www.youtube.com/watch?v=Q0rv1zOmyWg
http://www.pas.rochester.edu/~cline/...und-launch.pdf
http://www.coloradosoaring.org/think...launching/reve
rse_pulley/default.htm
Old April 28th 18, 09:43 PM posted to rec.aviation.soaring
Chris Rowland[_2_]
I did most of my ab initio training and learning to be an instructor on
autotow.
I'd suggest avoiding reverse pulley because it's difficult for both the tow
car driver and pilot to know when to finish the launch. With straight
autotow it's easy, stop sufficiently before the end of the runway that you
can drive forward and lay the cable out.
Another issue is cross winds. The cable will drift downwind and looking at
Ronan on Google Earth there are fields with irrigation equipment there. The
farmers will take a dim view of the launch cable being dragged through
their irrigation kit.
Chris
with that.
Old April 29th 18, 10:19 AM posted to rec.aviation.soaring
Paul T[_4_]
o
autotow.
the to
straigh
that yo
looking a
there. Th
throug
Chris
Don't see what the problem is at all with reverse pulley - had many
launches that way - the other end of the runway is just as easily
visible to the tow car driver and as speed decays the glider pilot
pulls off - think you creating an issue where none exists.
If you have a straight reverse pulley system and set it up properly,
with removable strops t both ends the cable is waiting for the next
glider, the car drives back and connects to the other end of the cable
and your ready to launch again.
Some reverse pulley systems where just way over the top -KISS is
the answer. Doubt these guys will be doing hundreds of launches a
day.
Crosswinds are something every ground launching site has to
contend with and 1000's of sites around the world seem to manage
ok with proper training - seem to remember the advice was to have
at least 80m width of clear land to launch from.
Old April 29th 18, 11:22 PM posted to rec.aviation.soaring
Frank Whiteley
o
autotow.
the to
straigh
that yo
looking a
there. Th
throug
Chris
day.
http://coloradosoaring.org/thinking_...ey/default.htm
I've had a couple of chats with John Foster. There are raised runway lights. Reverse pulley allows a lot more control of the line than direct auto tow, so could be an option. Today, UHMWPE ropes, spectra, dyneema, or polyolefin drag line might work for reverse pulley, though I'm unaware of an operation doing so.
Frank Whiteley
Old April 29th 18, 05:01 AM posted to rec.aviation.soaring
2G
Hi everyone
JMF
I would be surprised if the board would agree to an auto towing operation for one simple reason: liability. Long cables and general aviation just don't mix. You already indicated that you had a friend with with a C180. If he got his CFIG and you got a G103, you could do commercial rides, which are the real revenue generator. You really need to talk to a few other clubs to get a handle on the finances, which will either make you or break you. You also might consider going to a commercial site where you can get your training by total immersion. You could then give rides to prospective club members.
You asked, again, about how to attract club members after I gave you a good suggestion. I will give you one mo advertise, it's tried and true.
Somebody is going to have to provide startup money for the club in the way of a loan. That would be you in combination with whomever else you can find.. You can get aircraft loans, but you will need money for all these other expenses.
Tom
Best Club class glider Paul T[_4_] Soaring 37 July 27th 14 11:17 PM
Janus 2-seat glider as a club glider? K_Miller Soaring 35 February 3rd 13 10:43 PM
Which glider club ran over the cop? Karen Soaring 1 July 22nd 10 10:11 PM
Club Glider Hangar? noel.wade Soaring 33 January 14th 08 10:47 PM
Littlefield Glider Club Jack Soaring 3 October 23rd 05 01:16 AM
