![]() "Mark" wrote in message ... Hi All, thanks for the responses, was not meant to be a trick question but definately a newbie question. I was curious after reading about people using mazda 13b engines for various homebuilts, and porting them, adding on various components to boost the hp from 200 to 260+. Seems at a point that it's overkill if the 200 hp engine is going to provide you with the needed ponies and rpms to accomplish the same as the 260 hp engine. What would the advantge be of having the extra horsepower ? Thanks, Mark "Mark" wrote in message ... Does a prop turning at 2300 rpm on a 150hp motor produce more thrust than a prop spinning 2300 rpm on a 100 hp motor ? Mark, A "typical" 13b (non-turbocharged) for aircraft is closer to 180-200 Hp. A turbo will get you to that 250 hp mark, if you need it. Without the right prop, the power is not usable. Phillip |
Stupid super cub question | Robert Loer | Home Built | 9 | November 22nd 03 05:28 PM |
Tecumseh Engine Mounting Question | jlauer | Home Built | 7 | November 16th 03 01:51 AM |
question about EZRocket | David O | Home Built | 6 | October 1st 03 06:03 PM |
Question on Pulsejets/Ramjets??? | DarylG1532 | Home Built | 3 | August 16th 03 03:20 AM |
Question - Regarding Canard Pushers... | Tilt | Home Built | 33 | August 10th 03 11:07 AM |
