A Simple Question About LiFePO4 Batteries
Old May 17th 18, 03:37 PM posted to rec.aviation.soaring
Papa3[_2_]
Default A Simple Question About LiFePO4 Batteries
On Tuesday, May 15, 2018 at 11:59:54 PM UTC-4, wrote:
I have a friend that built several, 4 two for him and two for me 13.2 volt 11AH lifepo4 that used round cells and a bms circuit. for about $50 each that was the same size as the standard 12volt 7ah agm. They went with my Ventus but was a great system. Now I have to talk him into building a few more for my 27 although the 27 came with two lifepo4's one K2 and one bienno both look a few years old and have great capacity so far.
CH
The first "actual" answer to the specific question - and it only took 20 some-odd messages to get it :-)
I took apart a commercially built "drop in replacement" LiFePo4 battery a couple of years ago, and my sense was that there was a bit of wasted space. I suspect the idea was to provide a capacity and footprint that was identical to the SLA batteries they replaced. I did the same googling when I was in the market, and I didn't find anything with significantly more than 10ah stated capacity in the same footprint.
FWIW, I run a load test of my LiFePo4s at the beginning of every season. My K2s currently show about 9.4-9.5 Ah at 0.1c discharge rate. What is remarkable is how flat the voltage drop is in comparison to the old SLA/AGM batteries. (Dick's post above shows a graph).
My K2s are both 4 years old. I did have one go south, but it was stored fully/deeply discharged after a long end-of season ridge mission. K2 gave me a partial credit for a replacement even though it was stored against their recommendations.
FWIW
P3
  #32
Old May 17th 18, 03:57 PM posted to rec.aviation.soaring
CH
FWIW
P3
Not sure how that answered the original question. But I am intrigued with the possibility of building my own pack. Not sure I'd trust that for flying, but perhaps for earthly pursuits. It's easy to wrap up the cells in a sloppy mess of tape. But can one get a ready-made casing that is similar to the SLA batteries? Or, can somebody with a dead LiFePO4 battery send it to me so I can put new cells inside?
  #33
Old May 17th 18, 04:31 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
If you're reasonably handy with a 'Junior hacksaw' or similar fine-
toothed tool and with using rapid setting epoxy, then making a container
with the same dimensions as the SLA you're replacing is fairly easy. Make
it from 1/16" (1.5mm) epoxy plate), possible with hardwood of epoxy rod
in the corners. If you can't find it locally, epoxy plate can be sourced
http://www.cstsales.com/
Martin | martin at
Gregorie | gregorie dot org
  #34
Old May 17th 18, 04:44 PM posted to rec.aviation.soaring
JS[_5_]
If you'd like to build your own, BatterySpace.com seems a good place to start.
  #35
Old May 18th 18, 01:31 AM posted to rec.aviation.soaring
The wasted space issue is overcome by using prismatic shaped cells, at least in the quality units.
  #36
Old May 18th 18, 02:10 AM posted to rec.aviation.soaring
Greg used two flat clear pvc plates for top and bottom hot glued the round cells, 8 I believe, in stagared with two end clear pvc and bms board large shrink tubing over it all for the long sides and . It has held up now for two seasons without problems. He also bought a battery welder to connect the cell together.
  #37
Old May 18th 18, 04:29 AM posted to rec.aviation.soaring
2G
On Thursday, May 17, 2018 at 5:29:29 AM UTC-7, wrote:
I want to concur with Dan.
I fly out of Minden and we cruise between 15,000 and 17,999. It is COLD at that altitude.
My lead batteries would lose voltage as the temp dropped. After three hours at altitude they were lucky to put out 11 volts. Of course, when the batteries warmed up alter landing they had full voltage.
The LiFePO4 batteries do not seem to affected by cold soak. They work the whole flight at full voltage.
This LiFPO battery shows a significant a temperature dependence of voltage:
https://www.batteryspace.com/prod-specs/9055.pdf
Basically, all chemical reactions are very temperature dependent.
Tom
  #38
Old May 18th 18, 01:24 PM posted to rec.aviation.soaring
However, I can't find a LiFePO4 equivalent for it. Does such a thing exist?
How about this one?
https://www.batteryspace.com/lifepo4...assed-dgr.aspx
  #39
Old May 18th 18, 04:05 PM posted to rec.aviation.soaring
Interesting - the discharge voltage goes down with lower temperatures - isn't that the opposite of lead-acid? At the least, lead-acid needs higher CHARGING voltages when it's cold.
How well does a microAir radio, which is finicky at low SLA voltages, do with a "12V" LFP battery, which offers a slightly higher voltage on the discharge curve?
  #40
Old May 18th 18, 04:21 PM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
I have a MicroAir and it works great with a LIFEFO4 battery.
Richard
www.craggyaero.com
LifePO4 batteries for motorgliders - are we there yet? Chris Soaring 13 January 9th 16 03:43 PM
LiFePO4 Batteries on sale. [email protected] Soaring 20 December 9th 15 05:34 PM
K2 vs. StarkPower LiFePo4 batteries Fox Two[_2_] Soaring 36 April 16th 15 05:14 PM
LiFePO4 Batteries vontresc Soaring 56 June 27th 14 07:25 PM
LiFePO4 batteries JS Soaring 26 October 15th 12 02:51 PM
